Question about Haier BC112G Wine Cooler
Cooler constantly runs - Haier BC112G Wine Cooler
    Sergeant:
  • 231 Answers
It sounds like it could be a thermostat problem. If it is a faulty thermostat, you will have to replace it as it will burn out the motor (compressor).
http://www.google.ca/search?hl=en&safe=off&client=firefox-a&hs=DMy&rls=org.mozilla%3Aen-US%3Aofficial&q=Haier+BC112G+Wine+Cooler+thermostat&aq=f&aqi=&aql=&oq=
Posted on May 27, 2011
Whirlpool 22" wine refrigerator wwc287bls. Makes a high pitched sound pretty much constantly (compressor seems to run constantly too)
Howard, We're sorry to hear about your Wine Cooler making a high pitched noise. Our Wine Coolers are handled by a different department. Please call 800-263-2629 for assistance.
Jun 13, 2017 | Whirlpool Refrigerators
My plumber says the pump should not run constantly, but should switch on and off. It come on for about 15secs and then off. I want it to run constant, will it create problems?
Assuming you do not build up really excessive pressures and the motor is not straining, running the motor constantly is better than having it cycle periodically. Every time a motor turns on a tremendous amount of juice goes into the motor windings until the motor speeds up and the back emf reduces the current. A constantly running motor will run cooler and last longer.
Oct 20, 2015 | Plumbing
Unit will not stay cool. Is it a thermostat, compressor?
Small refrigeration units like this one like to fail to cool by developing a small leak and slowly
leaking refrigerant.
THERMOSTAT FAILURE CHECK:
A technician will check the thermostat using using a DMM (digital multimeter). But you can suspect the thermostat if you set the thermostat high and the compressor motor does not run,
then set thermostat low, and the compressor motor also doesn't run - in other words, the thermostat is failing to start the refrigerator's refrigeration system no matter what its setting - an obvious failure of the thermostat.
COMPRESSOR FAILURE CHECK:
If the compressor is dying, you would hear the compressor running almost constantly, but not
sounding quite right (uneven noise, clunking, tapping).
REFRIGERANT LEAK CHECK:
If you unit is low on refrigerant (due to a leak), the compressor motor will be running
almost constantly, but it will sound Ok.
Mar 24, 2011 | Danby DWC513BLS Wine Cooler
Replaced control on u-line 75WC wine cooler now runs constantly
If the sensor of the thermostat is not on the evaporator plate then yes the thermostat will never be satisfied. Because it is not reading air temp only the evaporator plates temp. should be clamped onto the bottom of plate.
Sep 13, 2009 | U-Line 75WC Wine Cooler
I have a beverage air kegerator that seems to work fine, but the evaporator fan runs constantly. Is it supposed to run constantly, or is it supposed to cycle on and off with the compressor, etc.?
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
Aug 13, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
I have a True GDM 33 model is it possible tochange the temperatur
If your cooler is constantly running too cold the thermostat is probably bad. I can hook yu up with a thermostat. ;) www.northeastcooling.com
Nov 18, 2008 | True GDM-33-SSL-54 Refrigerator
Short maybe?
check voltage on outlet is grounded properly try another outlet
Nov 03, 2008 | Haier BC112G Wine Cooler
Haier BC112G Wine Cooler Logo
284 people viewed this question
Top Haier Furniture Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
jasbo
jasbo
Are you a Haier Furniture Expert? Answer questions, earn points and help others
