Question about Dishwashers
TEKA Dishwasher TDW 59.2 FI Error lights Light 1 = off Light 2 = on Light 3 = off Light 4 = on Light 5 = flashing
5 Suggested Answers
SOURCE: teka dw6 55 FI, error
its not draining
Posted on Sep 22, 2008
abhishek33
  • 1239 Answers
SOURCE: Teka Dishwasher DW6 59 FI
hi Because the timer controls many operations, a faulty timer can cause many problems. The timer is a complex component, so you shouldn't attempt a do-it-yourself repair. Test the timer with a VOM set to the RX1 scale. To gain access to the timer, remove the front control panel. The timer is directly behind the main timer control knob. Disconnect one of the timer's terminal wires and clip one probe of the VOM to each terminal. If the meter reads zero, the timer is working. If the meter reads higher than zero, the timer is faulty and should be replaced.
If possible, use the same procedure to test the selector and cycle switches. The wiring hookup, however, may be too complicated to figure out on either of these switches. If you aren't sure you can deal with these switches, call a professional service person. Replace a faulty timer -- or a faulty control switch -- with a new one made for the dishwasher.
The timer is connected to several wires that supply power to operate the various functions of the dishwasher. To replace the timer, have a helper hold the new timer next to the old one. Connect the wires of the new timer one by one, removing the old wire and connecting the new, to make sure you connect the wires correctly. The wires may be friction-fit on the terminals. If they are, use long-nosed pliers to remove the wires. Don't pull up on the wires, or you may break the connection between the wires and the clips.
After connecting the wires, set the new timer in position, secure it the way the old one was secured, and replace the control panel and knobs.
Posted on Oct 13, 2008
  • 3247 Answers
SOURCE: Teka DW6 59 F1 Lights 4&5
I am slightly unclear if lights 4 & 5 are counted left to right or right to left when facing the dishwasher.
If you are counting right to left - then lights 4 & 5 flashing implies E3 fault - heater failing to heat.
am suspecting the heater unit is failing. Try to run dishwasher on a colder program like DELICATE and see if goes through.
If the flashing does not go away by turning power off and back on then the heater or the thermostat has failed and will need replacement.
Hope this helps fix the problem. Please post a comment if this is not helpful.
Posted on Mar 17, 2011
SOURCE: need an english manual for
By maggiegardne on Nov 20, 2010
need an english manual for teka dishwasher dw6 59 f1 please
Posted on Mar 30, 2011
My Teka DW7 57 FI VRO2 dishwasher shows the error code E4.
E4 means it is overfilled because of too much inlet water. Turn off the main supply. Remove excess water from the base pan and restart the dishwasher. DW7 57 FI Teka official website Bathroom Kitchen Professional Kitchen and...
Apart from using the manual instructions, you can get technical help from the company directly too.
Hope this helps!
May 15, 2016 | Dishwashers
Hi my teka dishwasher dw7 56 fi makes a noise when first switched on .
what is it supposed to do . be so quiet you can not hear it working .
Dec 07, 2015 | Dishwashers
How do I fix a Teka DW6-59 dishwasher thermostat problem
If it heats and fills, would not think thermostat, tstat checks that the temp is ok, then prog moves on, If tstat, would never move on. think more after that, maybe, does the pump work, could be broken wire power to pump, can you hear the pump working, if continuois cycle, at what point does it stop and start at beginning, does it pump water out? if not water level sensor.
Jul 29, 2014 | Dishwashers
All five lights are flashing on teka dishwasher
The control board could be at fault
Mar 26, 2013 | Dishwashers
The dishwasher will not come on and the clean light is flashing.. We have hit the cancel button but the light is still blinking. We have also un plugged the dishwasher to try to reset it and the light is...
I have wrote a tip about resetting the control which i have posted below. My question though is how many times in a row does the light flash,depending on the consective times it flashes before pausing them flashes the same number of times indicates what error code it is...example if it flashes 7 times in a row that is error code 7 if it flashes 4 times that is error code 4 and so on
here is that tip of what ya need to do to reset the control board
http://www.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
please reply with how many times it flashes then pauses then flashes again and i will determine what error code is being displayed
GENE
Sep 17, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Need an english manual for teka dishwasher dw6 59 f1 please
Nov 20, 2010 | Dishwashers
The fi light is flashing constantly when trying to fire up.there is no spark.when tested the fi light gives one long flash and 3 short flashes. thankyou.my zx12r is a uk 2000 model.a1
FI stands for Fuel Injection. The fuel system sensors have detected a problem. It could be anything > a dirty air filter restricting airflow, a plugged injector, an error in fuel mapping, any number of things. Serious problems can trigger the computer to prevent starting until the problem is fixed. You will need to take the bike to a Kawasaki dealer to have them plug in a code reader. The code reader will tell you exactly what the problem is. Please rate my answer. Thanks.
Aug 18, 2010 | kawasaki ZX-12R Motorcycles
How do u clean the pump and drain hose on a teka dishwasher? please help
buy Finish dishwasher cleaning kit from the super market and follow the instructions on how to use it. The cleaning kit should be run with empty dishwasher.
THis should help clean the pump and drain hose.
It would help if you mention the model number of your dishwasher. It is hard to get an english manual for Teka.
I tried this site
http://instructionsmanuals.com/lista2-20-49-en-Dishwashers-Teka.htm
but they all seem to be in European languages.
May 25, 2010 | Dishwashers
Dishwashers Logo
754 people viewed this question
Top Dishwashers Experts
Owen Barnes
