We have a black line from top to bottom on all copies we just change the ink.
  • Office Equip... Master
  • 812 Answers
You do not say what machine you have but in general look as the glass plate where you lay your document. If your machine has only and adf (automatic document feeder) then lift this up and you will see a glass plate under it. there will be something mucky on it or tippex. Clean these glasses and now your copies will be ok again.
Posted on May 27, 2011
My kyocera km-20- 30 have a problem. when i make copies it appears two dark line in the bottom and on the top of the paper
It seems the problem of Spacer. in your Ink Unit. In INK Unit there are two black bearing (called spacer) are used at the both end of INK Unit. Try to replace those spacers. or send me the print out of your machine.
Jan 19, 2011 | Copystar CS-1510 Copier
A black vertical line appears on all copies, even after changing the ink cartridge - how do I remove this black line?
hello, if this is happening on copies only, try just putting in the glass, if image is clear, then problem is small **** glass on the left of the copy glass, my guess there is some ink or white out or something on that **** glass, you should be able to clean with alcohol, and test again.
Oct 04, 2010 | HP LaserJet M1522n MultiFunction Printer
Ink is on the back of my printed pages
open the printer and clean all rollers you find. should fix your problem if the line goes from top to bottom
Jul 20, 2009 | OKI C3200n Led Printer
I just changed the black and the cyan inks. Now I have two stripes across the top horizontally and two across the bottom. The printing is not aligned properly. It is leaving some copy out. It was...
generally , 1-2 cleanings will solve the problem. However, if you waited too long when the printer said to replace the inks, you may have actually clogged up the nozzes.
so try some cleanings, if that does not work, it will most likely need to be sent in for repair.
Apr 24, 2009 | Office Equipment & Supplies
Photosmart C3180 not copying properly
mke sure there is no sticky tape on your inkjets
Apr 20, 2009 | HP Photosmart C3180 All-In-One InkJet...
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
Copying anything comes out sketchy
I replaced the black ink cartridge....alls well
Mar 22, 2009 | HP PSC 2210xi All-In-One InkJet Printer
Installed new drum
dark lines is probably caused by the thin glass of the copier. test by making copy on glass, does it have lines? if no look carefully at the small 1" glass there is probably some ink dots or white out or something on it, clean with alcohol and try.
fish scales uniformly are coming from the fuser, ( where it gets hot as its coming out) check.You already changed drum which was a posssibility.
Also check the toner and see if it is solid black.
Dec 03, 2007 | Sharp AL-1655CS Copier
26 people viewed this question
jasbo
jasbo
