Question about Samsung SCX-4725FN All-In-One Laser Printer
When I make a copy of something there is a black line about 2" from right side of paper (only when I use the auto feeder to copy) If I lift the lid and place the paper on the glass it does not do this. I have cleaned the small exposure glass (to the left of main glass) and problem still persists.
  • 817 Answers
Yes you may have cleaned the adf's glass but i can assure you there is still something stuck on it. Shine a torch onto the glass from different angles and you will see it.
Posted on May 27, 2011
I keep getting a black line about 2 inches along the right side of the paper if copying as well any faxes sent are also getting that blac line. Brother fax machine intel 4750e
Well you said the Lines are present when you are copying and when you are sending from the fax unit. Copying and sending functions both uses the scanning unit. What you lift open the document feeder for original documents. In there you should see rollers and a glass. clean this glass with cotton swab and alcohol for left to right the entire glass. Close the unit and try copying or sending, documents should now be clean.
Apr 04, 2011 | Office Equipment & Supplies
Big black line on paper
clean the scanner, lift the auto doc feeder and underneath is a scanner, look to see if there is white out or some other obstruction and clean with a rag soaked with alcohol
May 21, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
IT IS GIVING BLACK LINE .1 INCH THICK ON RIGHT SIDE OF PAPER REST EVERY THING WORKS FINE. WE DID NOT CHANGE TONER.
if you have a feeder on the top of copier, lift feeder and try making a copy off of the glass. if line is not there anymore, you need to clean the little narrow piece of glass that is to the left of your big glass.
hth,
razors
Feb 04, 2010 | Copystar CS-2030 Copier
Brother Intellifax 1" black line on right in send & copy modes
lift up your document feeder and check for something on the **** glass
Nov 16, 2009 | Brother IntelliFAX 4100 Laser Fax
It works great in all aspects, but when I make a copy of something there is a black line about 2.5" from right side of paper (only when I use the auto feeder to copy) If I lift the lid and palce the paper...
You need to lift the document feeder and clean the small **** exposure glass located to the left of the main exposure glass.Any foreign substance on this glass(ink, glue, correction fluid,etc.)will cause lines on copies when you use the feeder.
Oct 08, 2009 | Samsung SCX-4725FN All-In-One Laser...
Black line down one side of paper
Lift the auto feeder cover and clean the narrow glass that the originals are scanned across...sounds like you have some dirt there -maybe correction fluid? That's the most common.
Please rate me :)
Jun 23, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
My printer is putting a line about 2" from the Left side of the copy only when I use the ADF.
"Inka" is right.
Lift the auto feeder, and on the left side of the main scan glass, there is a narrow "filter glass" that is only used with the auto feeder. It only takes a spec of dirt to cause a solid line. Clean it, and all will be good!
Apr 24, 2009 | Dell 962 Photo All-In-One InkJet Printer
Black lines on copies when run thru fax feeder
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Jan 18, 2008 | HP LaserJet 2840 Printer
Black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
Nov 05, 2007 | HP Photosmart C6180 All-In-One InkJet...
Samsung SCX-4725FN All-In-One Laser Printer Logo
73 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
