Question about iLO V27DMBX Television
ILO troubles Power comes on red light.. then the gree light... but no picture or sound. had about 12 months.. used very little.. Purchased at Wal-Mart.. They do not carry them now... i understnad why... Any suggestions on repair.... **** in West V irginia...
  • Anonymous Aug 27, 2008
    I have the exact same problem red light comes on but no picture or sound
  • iLO Master
  • 5,568 Answers
(Bad news from Grantsville, WV)
Failing power supply-
Nearly all modern electronics uses a 'switched mode power supply.'
They are more efficient, also much more prone to failure but offer the added benefit of being designed so a 'downstream' fault will cause the supply to enter a cyclic state to avoid setting fire to your home.
The supply itself will also cycle if it has an internal problem; once again, to prevent destroying itself or anything dependent on its outputs.
Supplies built a couple decades ago could only do this by blowing a fuse and there are conditions that can occur that would not blow the fuse but would allow overheating and further damage as well as fire.
The most common failure is of electrolytic capacitors which sometimes will show their illness by causing a bulging top or depositing a crystaline trace around their base.
Often though, they show no outer signs of failure but their value can shrink to tenths of a percent of the specified due to poor seals and defective chemicals. These can only be found through measurement with a capacitance meter with a DF (dissipaton factor - loss) capability.
They will be in size from ~ 3/8" to 2" in height, ~1/4" to 1 1/4" in diameter, cylindrical, perpendicularly mounted on the board.
They will have markings on their shrink-wrapped sleeves (color can be any) and range from ~ .1 to several hundred uFd. with voltages from 3-4 volts to hundreds.
Power supplies are often mounted on a separate board (since they are often outsourced) so if you are adventurous, take the back panel off and take a look.
Posted on Oct 06, 2008
When the TV is plugged in the screen is black,little red power light bottom right corner blink 5x then you hear the sound of power on pause then power off. This continues to repeat and no picture.
Repairing Flat Screen TV - Blacked out with blinking red light
? 12:00
https://www.youtube.com/watch?v=3GmtBthpzDk
Mar 15, 2012 - Uploaded by n1bpd
Repairing Flat Screen TV - Blacked out with blinking red light ...Capacitors are little cylinders with a flat top with an X. If they have failed the X .... picture, no sound, totally black just the red power light blinking on the corner ... hello i have a dynex dx-lcd42-09 the red light blinks as soon as i plug it in i opened ...Missing: 5x
comments on EASY HOW TO FIX SAMSUNG TV- NO POWER
https://www.youtube.com/all_comments?v=hgcmWO7mqmo
Dec 16, 2015 | Samsung 55" UN55D6420 3D LED TV Smart TV
ILO DPD4210, no picture or sound. It appears to be stuck in stand by mode. The LED lights are solid Green or Red. It just stopped showing the picture and sound. Any suggestions of what might be the...
Sounds like an ordinary power supply failure. You just have to desolder and semiconductors that are bolted to heat-sinks and or look for electrolytic capacitors that are bulged or not the correct reading. A lightning strike or power surge could have blown a thermistor.
Oct 17, 2013 | iLO 3200 32 in. LCD Television
Power Issue
Now,u plug in the tv u get a solid red standby power red LED light in the front of the LCD panel right?When u push the power button on the remote u hear a clicking sound?Only one clicking sound,not the power supply board problems.It the Tuner board problems.But u can make sure it the power board problems or not.By taking the tv aparts check the power board,that board where the a/c power cord goes into it.Look all around the power supply board check for these leakage capacitors,they alway bulges up it top or puff up it top.No bad leakage capacitors,then it not the power supply board problems.
May 14, 2010 | Haier HLH406BB 40 in. LCD HDTV
The TV has no picture or sound but the red light on the front comes on?
The red light on the front is part of the system control (computer) in your television it indicates likely your power supply and computer are functioning. There are a multitude of problems that can cause no picture and no sound. Power supply troubles are most likely. The system control will have it's own little power supply which is always on so it can listen to the front panel or your remote. It will continue to operate when the heavy duty power supply might not. This suggests a shop repair would be in order. House calls can't fix something like this unless they are VERY lucky and find something obvious. You will still pay for the house call even if they can't fix it.
Mar 31, 2010 | Hitachi 51F59 51" HDTV Projection...
The sound comes on but it was taking the picture
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Dec 16, 2009 | iLO LCT32HA36 Television
MODEL HLC 22 R TV/DVD COMBO
This is the best solution for your problem as a 40 year experience with wires etc. Go to the source of your cable signal connector . Open it and clean the terminals with emery paper , sand the end of the cable shiny clean from corrosion , get a new barrel connectors with gold terminals if possible lengthen the ends of the cable , insert and tighten good, use thick rg-16 or rg 40 cable with good insulation ends crimped professionally with a crimpier or buy ready made , not from dollar store. Get a gold plated professional splitter if you need one or two , it will cost about 15 or more each . Make the cable runs as short as possible, using the thick good cables. If needed get a signal magnifier. From radio shack or the source etc. Connect them good and tight . Ground the splitters . Problem solved , you will get crystal clear channel 2 to 7 including 3 and 4 . Isolate the TV cable from other cables and power wires.Switch input mode Vitally
Mar 26, 2009 | Haier HLC19R 19 in. LCD TV/DVD Combo
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
Dead tv :-(
ai have the same fault on my tv will not swith on any help any1
Mar 22, 2008 | Televison & Video
Problem turning on
Check that the large fan in the back is working when you turn it on. If not, the set will shut itself off
Sep 20, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
iLO V27DMBX Television Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
