Computer sound output devices
Please I need your help in the following issue:
i want to use sound from computer through home theatre equipment, when i tried this I am not getting the correct sound clarity. Please give me the solutions for this.
  • van8977 Aug 16, 2008
    I badly need your assistance to solve this problem this is my long time wish to hear the sound of internet streaming radio through my home theatre system with good clarity.
    Problem Solver:
  • 14 Answers
The sound you get would depend on the sound card from your computer. In general you can use the standard Mini Plug output from your sound card into the Aux input of your receiver. You would need a head phone extension cable ( one using a mini plug, not 1/4 type ) then you will need a head phone to RCA Y adapter to split out the R & L channels for your receivers input. It is also a common item. Plug the Y adapter RCA side into one of the open inputs on your receiver and the other end into your headphone extension cable, then to the speaker output on your sound card.
This will give you standard output to your receiver, if the signal out is Dolby encoded, then you should be able to get the Surround sound that you are after.
John
Posted on Aug 20, 2008
Sound issue through Home theatre when pulling up applications
Smart TV's make up the audio output for your smart tv apps. You will need to use the Optical output of the TV and plug it into an available Optical input to the home theater receiver. Make note of the name of the input on the home theater receiver (i.e. CD/DVD, TV, DVD, etc) because that is the input you'll have to select on the receiver to hear the App audio. Hope that helps
Dec 03, 2014 | home Audio Players & Recorders
I am having 21 inch onida black 200 tv .I have recently bought philips home theatre. please let me know how to turn off internal speakers of onida tv and how to turn on external speakers to send audio...
By the looks of it, the only output you can use from the tv will be using the 2.5mm jack plug headphone socket, get a cable to convert this into twin phone (red/white) for stereo sound to your amplifier. (they are very cheap £2 or so) The Home theatre system should be able to give you a psuedo surround but you wont get full surround.
May 02, 2011 | Audio Players & Recorders
Lg plasma 50 trying to configure hdmi to play tv sound through panasonic home theater.
You will only be able to use the HDMI if you tv has an output for it(for other things beside built in DVD player of home theatre). It can not be an input. If you want everything that plays through your tv to then play through your home theatre the easiest way is to use white and red composite audio cables(some call them rca cables) More than likely you tv will have this output.They will go from the output of the tv to the input of home theater. If your home theater has a Blu-ray or DVD player you need to use the HDMI from home theatre out to in on the tv. If you tv happens to have and OUTPUT for fiber optic audio or digital coaxle audio on your tv and your home theatre has same but as inputs that will work as well with a better quality sound. However this is very rare.
Dec 13, 2010 | LG 42PB4D 42 in. Plasma HDTV
Connect home theatre to 32" lcd to ps3
Depending on the year of your model of VIZIO your digital optical output may be tied to the DTV input only. Meaning the only time you will have audio coming out of the digital optical output is when your using the tuner and your on a digital channel. If your television is newer and the digital optical output is in white on the back of the television than it is tied to HDMI and the DTV Tuner and you will pass audio through the digital optical output when using HDMI or the Digital Tuner.
Now to get connect the HT: Normally you would run a digital optical cable from the source device to the home theatre system. Meaning if it was a PS3 you would run a optical cable from the Digital Out on the back of the PS3 to the Digital In on the Home Theatre receiver. If it was a DVD player than you would run the optical cable from the DVD player to the HT receiver. If you have a newer VIZIO and the optical output is in white and not black than you can run HDMI from the PS3 to the VIZIO and then run a optical cable from the VIZIO to the Home theater receiver.
You will have to adjust the audio setting in the PS3 to run audio out of the HDMI port if it is set to run audio out of the Digital Out or AV out. Also, if your going to run audio from the PS3 to the HT receiver through the Digital Out then you need to change the audio setting in the PS3 to Digital Out.
1. Select (Sound Settings) under (Settings) in the home menu.
2. Select [Audio Output Settings].
3. Select the input connector on the audio device.
Channel numbers and audio formats that are supported vary depending on the connector in use. AV is 2 ch. only, Digital Out is 2 ch. & 5.1 ch, and HDMI is upto 7.1.
Apr 05, 2009 | Vizio L32 32 in. LCD HDTV
LG HTD302SG-A2 Home theatre Audio problem
Sound like bad amp, however many new devices are computer controlled... first step is to unplug from power for a minute, and check again. Bad conectors are a next best look.
Apr 10, 2008 | Audio Players & Recorders
How to redirect the sound of my new LG 52" HDTV LCD to my LG home theatre?
There sould be audio outputs on the back of it, and the manual should clearly show how to set up a home theatre with an external sound system and all.
I don't know what kind of sound system you have, but I think it might be best to connect your video source (typically DVD player) to your sound system, as it usually can be done better that way. No need to introduce another link in the chain (your TV) that could degrade sound. Also any external tuner could (should) be connected to your sound system directly.
If you use the internal tuner in your TV to watch TV the audio out is your option. Best way to get this right is to consult the manual. They usually have some diagrams that shows a few options of how to do it.
Dec 05, 2007 | LG 42LC2D 42 in. LCD HDTV
70 people viewed this question
 Grubhead
Grubhead
