Question about Garden
On the device it has 1, 2, 3, for the terminals. Where do I land the line and the nuetral.?
  • 32 Answers
What type of device? Can you attach photo. Need details
Posted on May 27, 2011
I just wired my hot tub into my new house. And GFCI keeps tripping?
Still would go with Miswired.
if this is an auxiliary GFCI Spa Disconnect,
240 VAC, 50 Amp, then...
All of the following needs to be this way:
  • 4 wires from MAIN Circuit panel, into GFCI disconnect box, 2 hots, 1 Neutral, 1 ground
    • 2 hots go onto the disconnects Power Bus Bar for breaker
    • 1 white Nuetral goes to Isolated nuetral bus bar
    • 1 green Ground goes to ground lug directly on the box
  • 1 GFCI in the auxiliary disconnect box
    • The White Pigtail of the GFCI Breaker goes onto the Isolated Nuetral bus bar. There are now two wires there.
  • 4 wires come into box from Spa. (Unless the spa is Specifically a 3 Wire Connection Spa!)
    • 2 Hot/Line wires will go into the L1 & L2 lugs of the breaker respectively.
    • 1 White Nuetral Wire will go into breaker as well at the "Load Nuetral lug, usually marked as 'LN'.
      • It will NOT go on the Isolated Nuetral bus bar.
    • Green Ground wire will be connected to ground lug, 2 wires are now connected there.
  • Connections at spa will be respectively connected: the 2 hots on line 1 and line 2. White wire goes to Nuetralnd green ground will go to a Ground Lug, most likely to metal control box.
If it's not wired in this manner, it is wired WRONG.
May 27, 2015 | Electrical Supplies
Just wired up the gp24 ,connected mains,switch and nuetral, working on manual mode but clock not turning
Reverse wires on terminals 3 and 4
1) GP24 appears to be 24-Hour version of Greenbrook T100 series mechanical timer, with Grasslin analog time dial.
http://waterheatertimer.org/pdf/Green-brook-T100_CInstructions.pdf
http://waterheatertimer.org/How-to-set-timers.html
2) If clock is not rotating, then probably your wires are reversed.
Reverse wires on terminals 3 and 4.
3) Power from Mains, and wire to Load each have 2 wires.
Hot live from Mains connects to terminal 3
Neutral from mai9ns connects to terminal 1
Neutral going to load connects to terminal 1
Hot going to load connects to terminal 4
Dec 08, 2012 | Hardware & Accessories
Hayward super II wiring
move so both terminals are used sometimes they don't line up put on 220 then move to other position
Jul 24, 2012 | Hayward Super Pump 1 1/2 - Hp for In...
I wired a TORK #1103 - hot (black) from the panel to terminal 1 - neutral (white) from the panel to terminal X - hot to the GFCI recepticle terminal 2 - neutral to the GFCI recepticle terminal X. The GFCI...
If you look at your diagram, the neutral connects to the box with no number on it. This also supplies the nuetral to the timer motor. There is no need to switch the neutral conductor (white)
Connect line (incoming hot) to terminal L connect the load(black) out to the GCI on terminal X. Put both neutral white wires on the terminal with the square box.(this terminal should have the other timer motor wire already connected to it.
Aug 11, 2010 | TORK Digital Interval Timer Ssa100r-24
How can in connect the timer intermatic T 103
nuetrals go under the same terminal, power in goes on the LINE terminal, power out goes on the LOAD terminal, pull out disk gently and set to time of day and release back in, set on/off settings and turn on power. make sure the manual leaver is on the OFF position for timing mode to work.
Dec 01, 2009 | Intermatic T103 Indoor 120-Volt 40-amp...
T101 R Clock will not turn
The "Line" is the power source. The "load" is the device that is being powered.
typically the green wire is the ground wire. I strongly urge you to verify your assumption that is is the common wire. If the green is indeed the ground, and it gets hooked up to common, you will be energizing the cabinet of the unit and posing a serious shock hazzard.
Your curcuit will be as follows.
The power source "Line" will have wires going to the timer. (hooked to the "line" terminals on the timer.)the timer then is supplying the power to the pool pump, and we will reffer to it as the "line".
The two black wires from the pump would be hooked up to the "load" side of the timer.
Typically they would be labled line 1 and line 2 or "L1" and "L2"
If yours are not labled so, describe exactly what terminals you have in detail in both the pump and the timer.
Oct 03, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
Clock does not turn on
make sure the small white wires coming from the clock itself are installed on the "line" side of the terminals, those power the clock. If not, the switch will power the pump but the clock will not run.
Sep 15, 2009 | Intermatic & Indoor/Outdoor Rain Tight...
I have a 3 prong wire but dont know how to tell which one goes where
3 prongs, are as follows live wire-- nuetral--- live wire.. the middle terminal is always the nuetral line.. so normal color codes are red(live)-white(nuetral)- black(live), or black(live)--whiite(nuetral)-red(live). so long as you nuetral hooks to center post either live wire can go to either side
Oct 31, 2008 | Dryers
Amana Dryer
there should be instructions on the cord that you purchased. if not here it is, on your dryer, the 3 prongs are L1-N-L2.. and the green is a ground L1 line 1, L2 line 2, and N nuetral. L1 and L2 dont make a diff. as long as the whie(nuetral) is in middle terminal and the green screws to hte ground screw
Mar 18, 2008 | Amana DLE330RAW Electric Dryer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
