Question about GE GSH22JFT Side by Side Refrigerator
Opened freezer door and not only was the temp was about 45, I felt heat. As I was removing the food, the cooling cycled on. My son then told me that it had happened the day before also.
    Sergeant:
  • 231 Answers
It may be the result of a faulty defrost timer.
Check this link http://www.partselect.com/refrigerator+freezer-is-warm+repair.htm
Posted on May 27, 2011
Rm4400 freezer working fridge not
move temp sensor that's mounted in coils down or let hang if same replace sensor
Jan 19, 2014 | Dometic Refrigerators
The freezer won't run so how us it that the compressor is very hot after several hours?
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Sep 10, 2012 | Danby 3.6 cu. ft. / 102 liter Chest...
Ge monogram not cooling
You can fool with this and loose all your food to spoilage or get a service tech out to fix it or just replace it.
Jul 25, 2017 | Refrigerators
Samsung RSH1 power onto unit ok as lights working but no cooling in either fridge or freezer. This followed a power trip to the main electrics.
Let's start by diagnosing the freezer;
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food
As for the fridge, the same solution but for more details. If refrigerator is not cooling properly can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for refrigerator to come out of defrost cycle. If the timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. This is difficult to test, though, because it takes a prolonged, very-cold temperature to turn it on. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat.
1. Remove the lower fan duct work from the evaporator cover.
2. Remove the 1/4-in. evaporator cover screws and remove the evaporator cover.
3. Disconnect the defrost thermostat wiring connector.
4. Remove the defrost thermostat from the evaporator.
I hope the above helps.......
Regards.
May 02, 2011 | Samsung Freezers
Maytag MFF2258VEM French Door bottom freezer not cooling
Your model will and may take extensive diagnostics. You know there is no simple answer to this question and I will not guess. Do you have the sevice manual availible? I do if you need but from the length of your message it appears to me that you want and will need help. Let me know, Sea Breeze
Mar 12, 2010 | Refrigerators
Refrigerator runs, cools (freezer too), then stops cooling for a few days (freezer stays somewhat cool), then starts cooling again. Help...:(
In these new fangled ice boxs is what you call adaptive defrost control. Instead of the old tried and true defrost timer, brainiacs have decided to use artificial intelligence to determine defrost.
The basic pattern of adaptive defrost is:
COOLING,PRE-CHILL,DEFROST,DWELL,and POST-DWELL.
Hey I ain't making this up. The ADC (adaptive defrost control) Counts the number of times the doors are opened, the total compressor run time, and the length of time the defrost heaters were on during the last defrost. This method supposedly enables the adc to work nice in all kinds of conditions, whether hot and humid or cold and frigid climates. COOLING Mode will remain for an indefinite time or until defrost is determined by the micro-processor. When all systems are go for defrost the adc makes the jump to light speed by going into PRE-CHILL, this brings down the temps in the freezer to off set the defrost operation so that the food temp does not suffer dramatic temp rises. Pretty cool ain't it? If the ice box is in pre chill and the door gets opened then a DEFROST HOLD OFF will jump in and not do a defrost for several hours. If the door is continually opened at the end of 16 hours the adc is gonna defrost that ice box anyway. The defrost period varies but is a maximum time of 45 minutes including when the DWELL kicks in. Dwell is the length of time the ice box stays off AFTER the heater is terminated.
Then The POST DWELL will kick in. The post dwell will fire up the compressor and condenser fan but the inside fans will not run allowing the coils inside to cool down before them fans kick in and she jumps back into Cooling mode. I bet you would like to have a copy of GE's adc repair manual wouldn't you?
TECHNICAL SERVICE GUIDE
Dec 22, 2009 | Kenmore Refrigerators
Do the kenmore refridgerators have a daily defrost cycle? If so, how long does it last and what is the temperature fluctuation? The freezer is empty right now, and the temperature fluctuation seem to go...
All refrigeration products have a defrost set point. Most residential units defrost about every six to eighteen hours. This process should take about 30 minutes to 1 hour. The temp goes up so high inside because there is a heating element in the coils to thaw any residual ice. The temp should not exceed about 45 degrees though. If it does the the compressor is signaled to come back on and start cooling again. This is perfectly alright. The time at higher temp is not enough to spoil the food. Hope this helps. Good luck.
Nov 18, 2009 | Kenmore Refrigerators
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The freezer section of my fridge freezer side by side has broken down and will not freeze. The fridge side seems fine. Is it worth getting repaired? Prior to this I often heard like a clicking/ tapping...
So your refrigerator section is cooling fine ? When the compressor motor is running and you open your freezer, is the fan running ? You might need a simple fan replacement - The most costly repairs to a refrigerator is usually the compressor - as long as your compressor is running and you have cooling, the other most common problems are control board faults, evap fans, defrost timers, all of which can be fixed.
Is your freezer iced up when this happened - turning the refrigerator off and unplugging it, try removing the back panel of your freezer and locate the fan - look for anything obstructing the blades - maybe ice or other......otherwise you may need this serviced.
Is it worth it ? It depends - how much did you nitially pay for this ? How long have you had it ? How much are estimated costs for the repair - if the problem is one thing needing replaced and doesn't cost you a lot of money, yes it is worth it.
Aug 17, 2009 | Whirlpool GS6NBEXR Side by Side...
American fridge/freezer, over the last week the freezer compartment has melted ice? Today decided to remove all food from the freezer compartment - cleaned it out leaving the freezer and fridge...
  • yes, refrigerators have heaters in them to defrost the buildup of frost around the coils
  • they defrost approx. every 12-16 hours
  • if the defrost cycle gets stuck then it will continue to heat
  • i have seen it melt the plastic inside the refrigerator
  • possible causes:
  1. bad defrost timer
  2. bad thermo switch in freezer
  • i would replace both as they are not expensive
Jun 29, 2008 | Refrigerators
GE GSH22JFT Side by Side Refrigerator Logo
52 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
