Question about Craftsman Garden
I have a tractor model 917.259820. The engine turns over by will not start up. The gas filter is not clogged. I have not checked for spark yet. What steps would you suggest I take, and what is your educated guess on what may be wrong. Thanks
SOURCE: craftsman lawn tractor wont start
your fuel filter could be plugged
Posted on Jan 19, 2009
  • 79 Answers
SOURCE: no spark
hi is this a point less ignition or electronic? check that your ground wire from ign. coil is not grounded causing no start.( last ign coil shot) good luck.
Posted on Apr 06, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Posted on Jul 05, 2009
SOURCE: DYT 4000 Lawn tractor won't start
I solved the problem after buying carb and fuel pump rebuild kits.The carb kit didn't fit anyway, but didn't need it. The problem was in the fuel filter. I had forgotten the problem happened when I ran out of gas. Inside the fuel filter is a washer held in place by a spring. Without fuel it apparently lost pressure and the washer slipped out of place about 1/2", which was enough to let all the gas through that could. The rebuild kit had a new rubber gasket. I won't let it run out of gas again.
Posted on Aug 11, 2009
  • 143 Answers
SOURCE: I have a craftsman lawn tractor that has an
Try blowing air back through the pipe into the tank, sometimes this works and its easier than removing the tank. Stephen.
Posted on Nov 10, 2009
Mower was starting but quit after it runs for a while but know it just turns over but start
Simple Reasons Your Mower Won't Start Out of Gas tale Gas Leads to Clogged Carburetor Clogged Fuel Filter Dead battery Bad Starter Solenoid Disconnected or Dirty Spark Plug Dirty Air Filter
Sep 28, 2016 | Garden
I have the Craftsman GT5000 24 OHV tractor lawn mower. It's been in storage for a while, I have replaced the battery, spark plugs, fuel filter, and oil. I can't get it to start. Does the engine have a pump...
Sounds like the carburetor needs a good ultrasonic cleaning as old gas will leave behind varnish and gum deposits clogging the carburetor fuel passages up.
Mar 29, 2015 | Craftsman Garden
YTH1842 96013000201 18.5hpB&S will not turn over.
By "turn over" my assumption is that you mean that the engine cranks but will not start. The engine must have both ignition spark and fuel to start. Check spark first by carefully removing a spark plug, leaving it attached to the wire. Use a pair of insulated pliers to hold the plug and ground against the engine block while cranking the motor. If you see a bright blue spark you know you have ignition spark. If not, you must further diagnose the problem. Assuming you have spark, you would turn to make certain the engine is getting fuel. Make certain tank fuel shutoff valve is in the open position. If you have fuel filter assume it is clogged and install new filter. If you see gas passing through the new filter when cranking engine and the engine still does not start make certain that the choke is operating correctly. It should be fully closed to start and fhen move to 1/2 open, then fully open as engine starts. If engine still does not start it is probable that the carburetor will need to be removed, disassembled, cleaned and reinstalled. As a final note each mower or rider has safety switches and devices that can prevent an engine from starting if they are not working correctly.
Nov 04, 2013 | Husqvarna Garden
Craftsman LTS 1500 lawn mower - model # 917.28903 started sounding funny while i was cutting VERY high grass. I turned it off immediately and it backfired as it shut off. Wouldn't restart. Waited til next...
I would check the big three first of all. Spark, compression and fuel. Sounds like you have spark and fuel. I would get a compression tester to check actual amount of compression. If all three of those things are good I would check valve lash. You will need make, model and serial number of engine. If you post these I can help find specs for you. Good luck.
Sep 14, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My 12 year Craftsman lawn tractor with 20.5 hp B/S engine and 42" blades will not start. The starter turns over fine but no start. I don't know if it is igntion or fuel problem. I replace the...
Test for spark. Make sure the air filter is clean. Then make sure fuel is getting from the gas tank to the carb. Old rubber fuel line deteriorate and stop up small ports and parts in the carb. An inline fuel filter is a good idea on these larger engines. Sometimes, a larger B & S engine needs the OH valves adjusted to start easily and run properly. If after attempting to start, does the new plug get wet or even smell like gas? You should always use gas LESS than 30 day old. Gas goes stale like bread and milk. You can remove the fuel line from the fuel tank at the carb to drain old gas. You can also remove the carburetor bowl to check for water and sediment (which need to be cleaned out). Check these things and post back.
Sep 05, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Hard to start
Have we had a tune up on this tractor lately. Like changing spark plug, air filter, oil and may be even the gas in the tractor.
Clogged air filter, Bad gas, fouled spark plug may be your problem. Like everything they need maintenance one in a while to keep them running well.
You just can't get on them and ride.
HTH
Good Day.
Oct 28, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Lawn Tractor won't start Craftsman LT1000 17.5 OHV
The starter bendix is not engaging properly the bendix pushes the starter gear into the flywheel gear when the starter spools up, it may need minor lubrication.
It sounds like the engine is not getting fuel as it should, the main jet may be restricted from varnish if she stumbles under a load especially if the plug tips are white after running for 1/2 an hour.
Remove the float bowl and clean the jet, make sure the fuel is still good, gas that smells like a library is more like varnish and less like fuel.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Apr 24, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
76 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
