Question about Samsung DV219AE Dryer
I have a Samsung DV219AE dryer. This morning when removing clothes I rotated the drum. Hear a loud clunk/clang. Now the drum will not turn, but everything else turns on. No error message on display. Is this a belt?
SOURCE: the drum will not rotate
I did the same thing this morning... It was going to take a couple of days before repair technician was going to be able to repair it. So, I took the back cover off, and the idler pulley tensioner spring had fell off (that was the sound you heard... Then, I had to re-index the belt back to its groove on the drum. When I did that, I realized that the idler pulley had to be pulled all the way to the right and actually held the belt around the drive pulley. Hope that helps someone.
Posted on Oct 06, 2010
  • 291 Answers
SOURCE: have a samsung dryer model DV209AEW/XAA. I "hand
Check to make sure your child lock is off first. Hold the time and signal buttons simultaneously for three seconds. Unlikely, but do check. Some of these dryers have a safety switch that the idler pulley has to engage to allow the dryer to run. I tried to find a schematic for this model but could not get one to tell if you do have a safety switch. Look at the arm of the idler pulley and see if it is contacting the switch actuator correctly. When a belt breaks or pops off, sometimes the arm of the pulley will move to the other side of the switch actuator and will not allow the dryer to run once a belt is reistalled. I would also look to see if a wire was knocked off of the motor switch when your belt came off. Good Luck, Appliance Specialists
Posted on Dec 03, 2010
  • 3074 Answers
SOURCE: drum not going round,burning smell when it
belt and possible drum rollers:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Posted on Mar 16, 2011
Macmarkus
  • 2605 Answers
SOURCE: My Samsung dryer drum will
Welcome to FixYa.
Based on your description and my experience, I'd say possibly the belt has come off, thus activating the "kill switch".
I've seen this many, many times...though the belt usually doesn't break it just comes off. Very common for Samsung dryers for whatever reason.
**Unplug the unit before proceeding...safety first**...
The good news is if it's accessible from the back you can simply remove the small panel around the exhaust tube as shown here,
if it's not you'll need to go from the front...do-able just a little more involved, let me know.
Once in the back the belt should look like this when routed properly, with the "V" grooves towards the drum and motor pulley.
i.e.
Hope that moves you forward...or even better, to the finish line, lol.
Let me know what you find. If this is something you think is not within' your scope of expertise please call a pro.
I will try to help in any manner I can of course as well. Good luck.
Regards,
Macmarkus :)
Posted on Mar 30, 2011
jumptrout51
  • 3361 Answers
SOURCE: I manually rotated my dryer
You made the belt come loose.
Replace the drive belt.
Posted on Apr 04, 2011
Got clothes out my dryer and turned the drum clockwise to get a lint. Heard a loud clunk noise and now it wont spin. Please help
check for a broken drive belt for the drum
the clunk may have been from the belt as it broke and hit the cabinet
Apr 07, 2015 | Dryers
Drum will not turn
Remove the back panel to access the belt
Mar 24, 2013 | Samsung DV219AE Dryer
Samsung dv219AE drum won't turn
sounds like your drive belt has broken, you may be able to access that from the back, taking cover off, (after you unplug it of course)
Mar 09, 2013 | Samsung Dryers
Went to dry clothes and the dryer doesn't tumble and all I hear is a click comming from the back of the dryer
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 20, 2011 | Samsung DV219AE Dryer
I have a loud noise coming from the bottom right side of my dryer. I am trying to figure out how to open the cabinet up to see what the actual problem is but I can not tell how to open it. There seems to...
maybe the drum rollers,Tim:
http://www.partselect.com/dryer+maytag-atlantis-drum-removal+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
May 29, 2011 | Maytag PYE2300AY Electric Dryer
Drum not going round,burning smell when it started, when started it again it clanged really loud then stopped
Mar 16, 2011 | Samsung DV218AEW Electric Dryer
Dryer making a grinding noise when turned on. How do you get the top off to check the barrel motor?
Clanging Sound
1. If the noise coming from your dryer can be described as a clanging sound, the solution is probably well within your grasp. This common sound is typically the result of loose debris accidentally put in with the load of laundry. Change may be left in pockets of pants or other objects may be dropped in the laundry basket by children --- perhaps a toy car. The objects may not be noticed when put into the wash, and the water in the washer may have dampened the sound. Simply remove these items, and restart the dryer to resolve the issue.
Sometimes the clanging is from snaps or buttons that are actually part of the clothing. If you are drying a jacket with metal snaps or another garment with metal attached, you should expect this clanging sound as they tumble and strike the inside of the dryer tub.
Humming or Whistling
2. Many Roper dryer models are equipped with a safety feature known as a lint signal, which is usually a light that often accompanies a warning signal, telling the machine owner that the lint trap has become clogged. When the dryer cannot pull adequate air through the lint filter, it can overheat and become a fire hazard. The warning alarm may sound like a hum or whistle to get your attention. Look at the lint signal light, clean out the trap and the noise should stop.
Thumping or Grinding
3. If the noise you are hearing can be described as a thumping sound or a metal grinding sound, the device that turns the dryer drum, known as the drum rollers or glides, can be worn out. As the drum turns, there may be a constant and rhythmic thump each time the drum rotates. A severely worn or broken roller could cause the metal of the drum to rub against the metal housing of the machine, causing a louder grinding noise. The rollers will need to be replaced to remedy the problem.
Squeaking or Squealing
4. Most dryers work by using belts to turn the rollers, which in turn make the drum rotate and tumble the clothes dry. When these belts get loose, a worn belt or a malfunctioning tensioner spring may keep the belt tight. In either case, belt slippage may occur and will produce a squeaking or squealing sound that is easily recognized. The problem is likely to be the tension on the belt since most belts will break before wearing out to this degree.
Feb 24, 2011 | Whirlpool Dryers
We have a Hoover Elecron Dryer De Luxe D6292 and the drum will not turn. There is a loud clang and the belt is no longer on the pulley arms. We have tried replacing the belt, but each time the drum rotates...
here is a picture of some belt diagrams:
http://www.applianceaid.com/images/belt-config.JPG
Now there may be a problem with the drum rollers/glides or idler arm:
rollers/glides:
idler pulley(third on list right under motor):
Hope this helped Tim
Jan 09, 2011 | Dryers
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Samsung DV219AE Dryer Logo
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
