Question about Bush 5693D 24" TV
BUSH 7693D WORKING BUT INTERMITTENTLY GOING TO STANBY.ALWAYS COMES BACK ON, BUT GOES TO STANDBY AFTER A WHILE.
  • GRANTLEY BEST May 29, 2011
    BUSH7693D: THE UNIT ALWAYS POWER UP AT SWITCH ON AND SOMETIMES WORK FOR
    HOURS AND OTHER TIMES GOES BACK TO STANDBY STRAITAWAY, BUT WILL ALWAYS COME BACK ON LATER.
  • 2,098 Answers
Please let me know how long it will takes to do this symptoms and if the unit will power up fine after some times.
Jdvillanueva
Posted on May 27, 2011
  • Jdvillanueva
    Jdvillanueva May 29, 2011
    This kind of symptoms is commonly caused of the following :
    1. Low voltage power supply gone to out-of-regulation condition. The supply voltage is not stable which sensed by the processor and trigger the symptoms. Leaky/dried filter electrolytic capacitor in the power supply section will dropped the normal voltage. Leaky capacitor has a physical indication of fault like bulged/dome at the top and can easily be identify. Dried capacitor has no physical indication of fault, you must have a capacitor checker to determine its condition.
    2. Bad solder joints (cracked/dried/cold solder) in the power supply section, microcontroller circuitry, and horizontal deflection circuitry will do the same symtoms. You must work in the brightest area or you may used table/portable lamp and magnifying glass because this is hard to spot.
    3. Faulty microcontroller circuitry. This may caused by leaky/dried electrolytic capacitor and/or bad solder joints in its circuitry.
    4. Horizontal deflection malfunction - This section is quite technical because lots of parts are going to check aside from working in the flyback circuitry. High voltage output of the flyback will trigger the x-ray protection circuit to enable.
    I would advice you to look for a qualified technician to troubleshoot the unit or send it in.
    Also, check if your unit is still under warranty/extended warranty, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover because it will void the warranty.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
The camera saids stanby why is thid ?
Standby means it is ready when you want to use. When you select the camera and don't push the button for some time it goes to Standby. Lot of appliances do that.
luciana44
Dec 04, 2009 | Nokia Consumer Headset
My sony xbr 60 picture turns off and on
No solution for you...but I have the same problem. I also had the green blob problem which sony fixed earlier this year. It happens on an intermittent basis. Screen goes off, standby light blinks green, then comes back on. Its off for maybe 1-2 min.
Nov 07, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Turn off tv power
First your tv will always go into "Standby" when it receives a "Power off" signal. Made that way. Second, It is never a good thing to have your tv power plugged into a "Switched" outlet on a Cable ot Sat box or some other Component. The tv should be always be plugged into the wall outlet or through a very good surge protector.
Jul 12, 2009 | Televison & Video
Idlcd32tv27hd comes on for 1 second then goes to standby
REPLACE 2-4 BULGING CAPACITORS IN THE POWER SUPPLY BOARD, PLEASE LET ME KNOW IF FIXED. THANKS
Mar 15, 2009 | Televison & Video
Bush lcd 37 inch tv keeps going to stanby
my bush lcd tv keeps staying in standby mode and wont go on if it does go on its only for a minute or two....
Help please
Mar 04, 2009 | Televison & Video
Fujitsu 52" plasma stays in standby
I think you have a fault on the power supply board. If you can check this for yourself if not find a competant technician. Hope this helps.
Oct 02, 2008 | Televison & Video
Stuck in Standby
change the horizontal output transistor .its busted.
Aug 14, 2008 | Bush 5693D 24" TV
Monitor goes to standby mode intermittent.
make sure the video cable is inserted firmly. is it is, the video cable wires are loose inside the monitor which it is not getting the signal, telling it to go on standby mode.
Jun 12, 2008 | LaCie Electron III 22" CRT Monitor
Stanby
you might need to balance the standby with the screen saver settings.
Jun 07, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Bush 5693D 24" TV Logo
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
