Question about Canon PIXMA MP780 All-In-One InkJet Printer
Canon MP 780 Started with error 336 now wrong cardridge in the display. I put new original ink cardriges but the same problem. Can i reset the printer ?
  • sholm May 27, 2011
    I followed the procedure but error wrong cardridge is still there in display ?
  • sholm May 28, 2011
    I could not try your second solution. when i press the power buttom nothing happens , the printer refuse to start.no ligt or anything in the display
    Genius:
  • 1,570 Answers
Hi
To Enter Service Mode : Menu - Scan - Copy - Scan
Screen reads "service mode"
Press right arrow until the screen shows #7 Printer - press OK
Press right arrow until it reads - # 5 INK ABS CAPA - press OK
The screen will read Suction (to the left)and 100 (or some lower number) to the bottom right -
Press the "0" key, whatever number was shown should now read "0"
press OK
press Cancel and then turn machine off and then turn it on again.
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Regards and thank you for using Fixya !
Posted on May 27, 2011
  • Benjamin Jr Singson May 27, 2011
    Try this manual resetting of error
    Try this manual resetting of error.
    Please try this solution.
    Remove the USB cable into the printer and leave the printer on.
    Remove all the cartridges.
    Close the cartridge door and wait for the INSERT INK MESSAGE to appear.
    Disconnect the power cable and from the power source supply.
    Now open again the printer door. Move the carriage using your hand from the original position to the other side of the printer and then move it back to original position. Wait for couple of minutes
    Reconnect power cord and turn on the printer.
    Return all the ink cartridges and close the door. Wait for the calibration process.
    Print the test page to check if it working.
    Reconnect the USB cable and try to print again.
    If still the same, are you using original CANON ink cartridges. Make sure because using compatible or remanufactured ink cartridge will cause damaged for printer. Or make sure you are using correct canon ink cartridge.
    Also, try to clean dry cotton swab the contact wires with at the printhead and in the ink cartridge.
    Another is that there is available in the market for small amount an ink resetter to detect the ink cartridge. If the ink cartridge is new, try to return to the manufacturer for free replacement telling them that is does not recognized the printer.
  • Benjamin Jr Singson May 28, 2011
    Make sure the power cable is connected, otherwise it will not light up or power up your printer.
MP 780 displays error message "Wrong Cartridge" How do I fix and reset this error message,
Wrong cartridge on Canon means the printhead has gone bad, nothing to do with the inks. You just need a new printhead. The part number is on the side of the printhead and starts with QY6-
Jan 28, 2010 | Office Equipment & Supplies
Won't print black ink text; looks like faint watermark print; ran all maintenance check several times (nozzle checks, etc)
Remove the black cartridge and soak it with an alcohol free window cleaner soaked paper towel let it sit on the towel for a good thirty minutes then wipe clean and put back in printer run nozzle check if necessary.
Oct 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Wrong cartridge display after fitting non-canon cardridges
Are the cartridges compatible? What are the code in the ink or box?
Sep 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma mp 145 E4 problem
Dear Sir,
Error Code E4 = No ink.
Generally printer doesnt recognise refilled ink.
Try the to reset the ink catridges
by mp tool software,mptool reset the printers canon pixma series like MP150, MP160, MP170, MP180, MP450 and MP460.And there also facility to write and read EEPROM in the printer. Other excess this software is detect automatically installing printers in the computer.
Download Mp tool
i think it solves your problem,But the actual procedure and best solution is replace the ink catridges,according to canon new genuine canon ink catridges save your printer life also.
if you find any difficulty leave a feedback,we will glad to assist you
good luck
Sep 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP 145 ink reset
If i am not mistaken error E4 is printer has NO INK. Check the cartridges first.
Jul 25, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Substitute ink cartridges no longer work
I have the same problem and many Canon users , i try a trick that mayby solve this and last but not least ... Mayby the only cheap solution for all print users !! jumping-smiley-004.gif
My problem .. was looking for a cardrige solution ( IP4300 ) because 4 (of 5) cardrige leds are dimmed off and need to be replaced . I just order 5 adopters and 5 new with chip for all the five cardrige . Problem : The chip uses memory and that makes it very hard to reset . But i have thinking .. mayby this is somthing ..
What you read is new, experimenting with this idea is all at your own risk !
Here is a simple markable solution Unique !!
A - First you need all 5 brandnew cardrige with chips ( please keep all ink preventions inplace )
B - You need is a 4 poles - 1.50 / 2.50 meter +/- telephone cable
C - (five) (new) OEM cardrige without chips
D - Tin and a somthing to solder
E - 5 old chips for adopting the connection outside the printer
F - A box for the 5 new chiped cardriges
Procudure :
1 ) Make of 1,5 / 2,5 meter a 5 pcs of 30 / 50 centimeter
2 ) Solder on each lengt a old chip (this is functioned as a adopter) but first remove all the (useless) electronic components and place them on the cardriges
3 ) Solder the other site of the cable to each new chiped cardrige cq / toner that still sits on the new orriginal cardriges ( our make a alternative contact if you dont want to solder )
4 ) Tape the 5 new cardriges together and *
5 ) Put it in the box and give it a save unremovable place **
6 ) Put the (5) oem cardriges with the empty old chips ) in the right ink location(s)
* ) Looking into the new cardriges : this needs a box because of the intervering with the led this not only makes it nicer but mostly because of the outside light influence .
** ) Dont turn the kid upside down our shake it . If you do , the led indicates that the cardriges are empthy our low and the countdown proces for the chip will start !
I wait for arrive of the new ones, anybody who try make a handshake !
See you soon
John
Netherlands
Jan 29, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Mp780 waste ink full
CANON MP 780 WASTE INK COUNTER RESET
Enter Service Mode : Menu – Scan – Copy – Scan
Select #7 PRINTER in the service mode, and
input “0” at # 5 INK ABS CAPA.
Jan 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780 Printer - black 3e fails to print
installed a new Print-Head, but that was no changes. I use refill ink, and it seams the BlackInkTank is not exactly on the Printhead and it is Air in the Pipe, i take the Printhead and the Ink-Cardridge in the Bathroom, and press the Ink-cardrige on the Printhead and take a hard breath and blow in the Air-Holes of the Ink-Cardrige until black ink come out of the Printhead, reinstall in the Printer, end it works well.
sorry about my bad english
Jan 08, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
259 people viewed this question
old marine
old marine
