Question about GE Microwave Ovens
Vent goes on. digital pad no sound no function
    Guru:
  • 1,833 Answers
It seems like you need a Digital pad replacement, you can check the connection between the touch pad and the PCB. For repair and replacement please contact GE Support at " http://www.geappliances.com/service_and_support/contact/". Hope this will help you.
Posted on May 27, 2011
My Panasonic microwave oven'S digital pad is not showing power when the power switch in on , why ?\
There is a transformer which powers the front panel. Normally attached to the front panel bord. If the transformer is faulty the such problems can occur.
If you wish to get some more details about microwave oven repair then check the below added link http://electro-medical.blogspot.com/
Jul 06, 2016 | Panasonic NN-T888S Convection/Microwave...
How do I get the microwave to stop beeping.It"s beeping and locking the controls by itself.
The touch pad sounds like it is trying to tell you it has a stuck pad. The touch pad will need replacing.
Oct 01, 2014 | GE Microwave Ovens
What's your problem?key pad locks up
when you push the vent button it goes from mhigh to low then high to low will not shut off
Oct 28, 2011 | General Electric Microwave Oven
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Lights under micro do not turn off all of the time but some of the time. Finger sensitive pad does not register 0, 7, 8.; most of the time.
sounds like your touch pad is bad. if its under a year old. call for warranty service.if not you may need to order a touch pad. its not too hard to replace. remove power, take tho screws off the top of the micro holding the top vent cover on. remove the vent cover. above the touch pad is a screw, remove that screw and lift the Assembly up and it will tip out. be careful because you don't want to damage any wires. you can label and disconnect the wires to completely remove the Assembly.good luck!
Jan 18, 2010 | Samsung Microwave Ovens
In October 2007 I purchased a microwave oven Model # JVM1540DM2WW Serial # RM900254U. In the past week it has become overzealous. After use, instead of the vent fan turning off, it kicks into a REALLY...
This can happen when there is high heat on the stovetop (or the underside of the microwave).
Otherwise, it sounds like the fan control on your control panel is shorting or sticking.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
GE Customer Service is here.
Aug 10, 2008 | GE Microwave Ovens
I have an LG LMVH1750ST microwave convection oven. When I activate the fan for cooking purposes and then try to turn off, it does not respond. I have to pull electrical plug and reprogram for one minute....
From the owner's manual under OPERATION "VENT FAN":
"If the temperature from the range or cooktop below the oven gets too hot, the vent fan in the vent hood will automatically turn on at the 4-Speed setting to protect the oven. When this occurs, the VENT ON/OFF pad will not turn the fan off."
You should check your "vent fan auto time set" setting.
Here's one thing to try to set it to turn off after 10 minutes:
Touch the Vent ON/OFF pad, then touch the "5-SPEED VENT" pad until "level 4" appears in the display, then touch "AUTO TIME SET" the desired number of times.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 19, 2008 | LG Microwave Ovens
Microwave Ovens Logo
16 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
