Question about Schwinn Cycling
Schwinn 201 exercise bike can't set electronic resistance
  • 108 Answers
SOURCE: No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
Posted on Dec 07, 2009
SOURCE: the resistance belt on my Schwinn 205p recumbent
http://www.fitnessrepairparts.com/equipment/SelectEquipment/100 lists all the parts for this model
Posted on Jan 03, 2010
SOURCE: battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
Posted on Apr 23, 2009
wfservices
  • 260 Answers
SOURCE: schwinn 201 recumbent bike makes clicking noise
Check the tightness of the crank bearings, also the crank fastening nuts (on axle) If its the gears you may have to turn the screws on the rear derailleur to adjust the tracking. The same as the front. Your question is kind of vague so its hard to pinpoint the clicking noise. Could even be a stone in the tire??lol
Posted on Feb 21, 2010
escapement
  • 2334 Answers
SOURCE: When can I get a
This is Schwinn phone number. Contact them and ask whatever you are interested into. (800) 868-5764
Posted on Feb 28, 2011
I've had a Schwinn 270 recumbent bike for 4 years. The resistance is completely gone. Suggestions?
I suggest you check the troubleshooting guide in the manual, as there are several causes for the resistance not changing. http://download.nautilus.com/supportdocs/AM_OM/Schwinn/SCH.270-MY17.AM-OM-W.EN.pdf I would suspect that no resistance at all might have to do with a failure of the servo motor, which appears to control resistance through interaction with magnets on the wheel.
Secondly, you can try contacting Schwinn Fitness: Customer Service
If you still can't figure out the problem you may need in-person help. Find a place that sells Schwinn exercise bikes or see if someone at a local gym that has recumbents can help you. The bike is apparently made by Nautilus.
Dec 06, 2017 | Schwinn Cycling
Does the schwinn recumbent 270 bike have a battery? It has an AC adaptor. The resistance will not increase when i press the higher resistance button.
It does not have a battery. Your resistance motor is most likely faulty. The only thing is, with schwinn, you will most likely have to replace the resistance motor, the console, and the wiring. All of this is very hard to find and will probably be more of a hassle than it's worth.
Jun 10, 2017 | Schwinn Exercise & Fitness
Where can I find the owners manual for the Schwinn 130 model stationary bike?
Schwinn has the manuals for most of their bikes here: http://www.schwinnfitness.com/schwinn_fitness_us/customerservice/manualsen.jsp . There are three Model 130 upright bikes listed. Do you know what year your exercise bike was built?
The Owner's manual for the 2007 model is currently here: http://download.nautilus.com/supportdocs/OM/Schwinn/SCH_130-230_OM_RevB_web.pdf . The assembly and owner's manual for the 2016 version is here: http://download.nautilus.com/supportdocs/AM_OM/Schwinn/SCH.130.MY16.AM-OM.WARR.EN.pdf .
I hope this helps.
Mar 30, 2017 | Schwinn Motorcycles
How do I connect a resistance motor on a schwinn 220 exercise bike?
You will have to remove the plastic housing by unscrewing several screws about the perimeter. Take your time with the housing and inserts as they can be awkward to maneuver. There are 2 circular plastic inserts for the pedals. These can be popped out of the housing with a bit of effort to allow the housing to be cleared of the motor area without having to remove the pedals. Be careful not to break the plastic tabs on the inserts otherwise you will have to tape or glue them back in place. It will be most helpful to take several detail photos of the existing motor set up in case a screw, bolt, nut, spring, etc., pops loose making it difficult to determine from where it came. When I replaced my motor, the factory rep. recommended for easier installation that I first unplug the existing motor and plug in the replacement motor, then set the resistance to high on the control panel. Once the replacement motor has adjusted to the high setting, unplug the power, unbolt the existing motor and then install the replacement motor. Check the photos taken to ensure the motor's base is in the same alignment as the original motor. Plug the power back in and use the control panel the adjust the resistance to ensure the motor is responding. Then replace the plastic housing and again carefully pedal inserts.
Feb 20, 2015 | Schwinn 220 Recumbent Exercise Bike - 2012...
What's the best exercise bike there is?
According to me, one of the best Exercise Bike is Fitness form S20 Indoor Cycle Bike. It has adjustable resistance level and adjustable horizontal or vertical seats also. It provides the pulse, distance and speed or has roller wheels to move around easily. In this bike, you can also get a warranty of 12 months.
Aug 09, 2012 | Exercise & Fitness
The tension does not increase on my schwinn 220
adjust the magnet very well, tigh the bolts if there loose the tension will be not o.k
Apr 24, 2012 | Schwinn 220 Recumbent Exercise Bike - 2012...
When can I get a replacement RESISTANCE BELT for my Schwinn 205p recumbent exercise bike?
Feb 28, 2011 | Cycling
Schwinn recumbent bike 203 Ac adapter or batteries?
It uses an AC adapter. You can visit:
This is where I am getting the AC parts for my 201.
Mar 21, 2009 | Cycling
Cycling Logo
121 people viewed this question
Top Schwinn Cycling Experts
Michial Gueffroy
Tony
michael
michael
Are you a Schwinn Cycling Expert? Answer questions, earn points and help others
