Question about RCA F32450 32" TV
As I turn the TV on within seconds it turns off by itself.
  • haleyangel Aug 17, 2008
    I have an old RCA tv. I have cable television hooked up to my tv. instead of using my cable remote to change the chanels I hit one of the buttons on the tv. now my cable box is turned on and the wires are connected from the cable box to the tv. I have no picture on my tv
  • RCA Master
  • 1,550 Answers
The tv got a trouble on the horizontal side or the flyback maybe are damaged
Posted on Aug 16, 2008
Ario 42" hgtv I need the codes for my RCA universal 6 device rcu600dsn
Check these codes. 000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194 If you wish to get four digit or five digit codes, check this link.
Feb 20, 2013 | RCA F27442 27" TV
The unit turns on then powers off within 30 seconds?
There is a shortcircuit in the TV and it needs to be repaired.
Mar 15, 2011 | RCA TruFlat 27F520T 27" TV
When I try to turn my RCA PURFlat 27" TV on, either with the remote or main button a blue line shows up in the screen and like within 2 seconds it goes off. What's the solution for this problem)?
My rca purflat doesn't turn on with the remote, batteries are good, it however turns on when I press the power button and then the channel button.
Sep 16, 2010 | RCA TruFlat 27F520T 27" TV
Turned on the tv, heard sizzling sound and it immediately shut itself off. Won't turn on now. It had been turning itself off periodically now and then for the last couple of weeks with no noise and then...
sounds like dust collected on the internal parts which after enough time can cause it to stop working. either have tv repair specialists replace the mother board, or replace tv
Oct 28, 2017 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 27'' TV will not turn on.
Need to check T 401 for open Q 405 also could be a bad flyback transisformer.
Mar 12, 2009 | RCA 27V514T 27" TV
Rca tube tv
hi there, there is a problem at the horrizontal section, some mostfet transistor is defective, do some test at the horrizontal section. ty
Dec 29, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
RCA L32WD12 32in. HGTV LCD Television
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Nov 07, 2007 | RCA L32WD12 32 in. LCD HDTV
RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Jun 04, 2007 | RCA 27R410T 27" TV
RCA 27665 27"
check c14110 and c14122 off main b+
May 28, 2007 | RCA F27442 27" TV
RCA 27" TV F25432
You apparently have a high voltage arc. Possibly the anode lead to your picture tube. Also the flyback transformer could be arcing. If you're not experience with tv repair, you need to have a tech check it for you. The circuits operate at very high voltage and if you get into it you can get a possibly fatal electrical shock. Be careful !!! Stargazer
Jan 11, 2007 | RCA F27645 27" TV
RCA F32450 32" TV Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
