Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
I hasve a problem with my cratsman self propelled lawnmower. I can't seem to get it started or continue to run unless I spray gas into the carburetor. also, the primer button doesn't seem to make any su8ction noise.
  • 3 Answers
SOURCE: Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower: my engine will only stay running for about 3 secon...
Maybe the engine is running with the fuel from the primer bulb (about few seconds), the carburator is not working and need to be removed checked and cleaned, the most common fail is a jet clogged.
Posted on Dec 16, 2010
kel1guy2002
  • 3740 Answers
SOURCE: My 21" Mastercraft self-propelled, 3-in-1 mulching
There is a flywheel brake that is contolled by the safety bar of the handle. If the cable to the safety bar has broken or is no longer attached the the flywheel brake will be on. Not only that there is an ignition Kill switch as part of the flywheel brake. If the brake is on, the kill switch is activated.
Your mower needs some simple maintenence
1. Recoil assembly repaired or replaced.
2, Throttle cable and control repaired or replaced (Item 10 below link)
3. User Safety Bar cable adjustment or replacement. (Item 11 below link)
The above items are not a good reason to call your mower a parts source.
Without a model number I had to GUESS which model this was.
This is my best guess:
http://www.jackssmallengines.com/help.cfm#/MTD/125-478C054_(1995)/General_Assembly/0054900-E/00549000001
Thanks for choosing FixYa,
Kelly
Posted on Jun 07, 2011
2strokeJim
  • 577 Answers
SOURCE: i can not get my
pull carb apart and check float,,sounds like it is stuck shut
Posted on Jul 13, 2011
hunter19_46m
  • 7482 Answers
SOURCE: mower starts but won't stay running unless you
Hi
Sounds like you have dirt/debris in your caburetor jets,fuel passages.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one.
Make sure you are using fresh fuel.
If the moweris over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Once you have your carburetor rebuilt that should solve your problem.
Please take time to rate me
Posted on Aug 05, 2011
hunter19_46m
  • 7482 Answers
SOURCE: Lawnmower won't start. Was running then just
Hi kkeane20...
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting a bright blue spark at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope...watching the plug for spark.
If you are getting a nice blue spark then skip A below and go to B.
A...If you do not get a nice blue spark then you may need to replace the electronic module.
Note: If you have to replace the module be sure to measure the position it is in, it is critical to starting.
Take a picture for later reassembly.
B...Also take some fine grit sandpaper (not emery) and lightly sand the flywheel where the magnet is located to clean any rust or corrosion from the magnet area.
Then follow the procedure below:
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Write down on a piece of paper and or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of sharp instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Check you fuel line/s condition...after a while they will degrade and need replacement.
When you remove your fuel lines from the carburetor be sure to make a drawing or take a picture of how the lines are connected to the carburetor.
Also a good time to take a picture for later reference for reassembly.
If the mower is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me thumbs up
Posted on Sep 15, 2011
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Yardman 6.5 HP. Intek / 21" 6speed self propelled
its probably a tecuseh engine no fix for that other than put new primer ball on
Apr 28, 2013 | Garden
is there spark?does it fire on starting fluid
Apr 21, 2012 | John Deere JA65 Self Propelled Mower
My lawnmower starts but has no power
Make sure the bolt holding the mower blade hasn't loosened and check to be sure the blade is properly centered on the crankshaft end plate.
Feb 24, 2012 | Briggs & Stratton LawnBoy 20Inch 65 HP Gas...
Hi, I have a Craftsman lawnmower, sel propelled, over 10 years old. It doesn't seem to start unless I spray gasoline into the carburetor. Also, it will only keep runnning if I continue to spray into...
the Primer bulb most likely has a crack in it. If it does then there won't be sufficient suction to draw in the fuel. Also, if you remove the carburetor, separate the upper and lower halves so you can get to the fuel bowl, check that the float needle isn't sticking inside the hole. Look for dirt and other contaminates.
Do you by chance have the model # of the mower? It will be in the following format: XXX.XXXXXXX The model # sticker is usually located on the deck behind the engine. And what HP is the Engine? (It should be a Briggs and Stratton.
May 27, 2011 | Garden
I have a Craftsman self-propelled lawnmower that will not start.
first remove air filter and spray starting fluid in the carb? if it starts the fuel is the problem carbs are easily removed and cleaned make sure needel is not stuck? if it dosnt start chexk for spark pull rope hold screwdriver over wire touch it too plug end see if you see spark if not? then you must test zone conrol cable and grounds? did you hit something hard with the blade if so you could have a sheered flywheel key it will trow egine out of time ?
Aug 27, 2009 | Garden
Wont continue to run after prime and start
often the last ounce of gas in the tank has some crud in it. Get a can of carbeurator cleaner spray. Remove the air filter and squirt three short bursts of the cleaner spray into the air port and then start it. Keep giving it short bursts of carb. cleaner until it runs smoothly again.
Aug 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Checking the carberator
to see if its carburator spray some starting fluid in the throat it will start then die its not getting gas through thr volosity tubr take the bowl holder which is a hollow bolt try to keep the bowl on or the needle will come out clean the small holes to the sides and the top with a tip cleaner that they use for welding tips in the hollow bolt put back on should take care of problem unless its all gummed up in thr carburator
Aug 09, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Apr 25, 2009 | Poulan Pro " Pro" Self Propelled Mower
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
50 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
