Question about Tefal UltraGlide Easycord FV4256 Iron
The plate of my Tefal Pro Express has got badly burned with a brown residue. How can I clean it?
  • johnjan4 May 30, 2011
    The solution that you gave was exactly what I would have used on my old iron (one of my granny's old cure-alls) but I was concerned that an abrasive substance might damage the plate so decided to ask advice. The vinegar solution alone did not move the burnt on debris but in combination with the bicarbonate of soda - and a lot of mucle power - I have a favourable result and an ironing plate that is much improved. As at this time of writing, the ironing plate appears to have been uneffected by all this effort. However, the bicarb powder blocked up most of the steam holes so I have also had the demanding occupation of unblocking them all!
    In essence, the solution created a new problem -- but it worked!
  • 910 Answers
You could try just cleaning it with Vinegar on a cloth. If this doesn't work then a little Baking Soda mixed with the Vinegar.
The third option is to buy a purpose made Iron Cleaning Cloth as in the link below.
http://www.betterware.co.uk/productdetails.aspx?pid=058927&cid=129&language=en-GB
Their should be something similar in whatever country you're from.
Posted on May 27, 2011
Tefal pro express steam iron heating up but producing no steam
Pipe is blocked open and clean the inside
Aug 25, 2016 | Tefal Irons
How do I clean the plate there is rust in the holes where steam come out
use the instruc manual for recomendation for the manufacturer , however you can use a little water with alcohol mixed to 50% and brush
God bless you
Jul 20, 2012 | Tefal Pro Express GV 8120 Iron
My tefal pro express which i have had for 6yrs and ive had no trouble has started leaking dirty brown water can you tell me where i can take it to get it fixed in birmingham please.
I opened the side valve, (not when there is hot water within as it will explode in your face) and rinse the water from here. That worked for me.
The problem is the limescale it think which needs to be regularly cleaned out.
hope this helps.
Mar 27, 2011 | Irons
Tefal Pro Express GV 8120 Iron. New Iron - will not heat up and turn itself on. Green light just keeps flashing.
If it is a new iron, take it back to the dealer. Any attempt to repair or adjust on it will void the guarantee.
Jan 26, 2011 | Tefal Pro Express GV 8120 Iron
Why does my Tefal Pro express stain my ironing with brown marks and scale, I fill the tank with softened household water, but I still get a sudden gush of brown scale water. We live in a very hard water...
Its a real pain, but use only distilled water.
Fill your iron with white vinegar and let it steam until empty.. face down on a towel on lowest steam setting.
Nov 26, 2009 | Tefal Irons
WE HAVE A TEFAL PRO EXPRESS TURBO FOR ABOUT A YEAR NOW AND EVEN AFTER DESCALING THE IRON BROWN STUFF STILL COMES OUT OF THE UNDERNEATH AND THE SIDES WHY ?
It is caused by minirals in the water being heated up and crystallising. Try using distilled water.
Failing that,
It may be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Irons
2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
Tefal express iron cleaning
Thankfully I was able to clean the boiler compartment, by unscrewing the large bolt on the boiler, cleaned with water only, loads of brown yuck came out, It would then not allow me to use the steamer, Waited until the next morning tried again and working brilliantly again.
Jopey
Aug 19, 2008 | Tefal Irons
Tefal Pro Express
  1. solenoid valve blocked
  2. swich for steam broken
  3. you forget it in turbo steam mode and you have steam all the time
ps see below on link turbo button
http://www.gostore.com.au/~ebay/krups/tefal/proexpressturbo/TefalProTurboAuction(3).jpg
Jun 22, 2008 | Tefal Ultraglide 1549 Iron
Tefal Pro Express Steam Generator doesn't.
OK... so I have fixed my problem of NO STEAM, just lots of water coming out of the iron press plate itself... I had already cleaned the boiler, so I tried adding 1/4 tsp - 1/2 tsp bicarbonate soda to the water and flushing it through. From what came out of the iron press plate, I would say the problem was caused by a build up of goop (technical term) inside the iron. Once cleared, the iron is steaming away again. Please note, u will need to have an old towel handy if this is ur problem, 'cos until it starts getting better, there is a fair amount of water coming out of the iron press plate. Just add the bicarb to the water reserve and use the steam buttons to bring the bicarb through. Do not attempt to iron clothing with the bicarb in the water!!! Carolyn ;)
Nov 12, 2007 | Tefal Ultraglide 1549 Iron
Tefal UltraGlide Easycord FV4256 Iron Logo
651 people viewed this question
Top Tefal Irons Experts
Henry  Thomas
Henry Thomas
Are you a Tefal Iron Expert? Answer questions, earn points and help others
