Question about Garden
Hi, I have a Craftsman lawnmower, sel propelled, over 10 years old. It doesn't seem to start unless I spray gasoline into the carburetor. Also, it will only keep runnning if I continue to spray into the carburetor, if I stop spraying the motor will eventually stop. An added problem I have is that when use the primer button you don';t seem to hear anything (No suction noise). Can you help me?
    Problem Solver:
  • 17 Answers
The Primer bulb most likely has a crack in it. If it does then there won't be sufficient suction to draw in the fuel. Also, if you remove the carburetor, separate the upper and lower halves so you can get to the fuel bowl, check that the float needle isn't sticking inside the hole. Look for dirt and other contaminates.
Do you by chance have the model # of the mower? It will be in the following format: XXX.XXXXXXX The model # sticker is usually located on the deck behind the engine. And what HP is the Engine? (It should be a Briggs and Stratton.
Posted on May 27, 2011
  • Gerald Lombardi
    Gerald Lombardi Jun 12, 2011
    craftsman mower startes the stops prim bulb dosent seem to work if prim ckt or bulb leaking air will the stop carb from drawing fuel i have cleaned carb twice
  • Daniel Morgan Jun 12, 2011
    If when you press the primer bulb and you do not get gasoline to go into the carb, then you have a crack or leak there in the fuel system. The fuel system is supposed to be a closed system. Any air leaks will cause the carburetor to not draw fuel. Hence why you have to keep spraying fuel into the air intake to keep it running.
    Make sure your fuel lines do not have any cracks or splits, make sure the primer bulb is not cracked. If your plastic fuel lines are hard and brittle then they likely will leak.
Craftsman 6.0 eager-1 self propelled lawnmower starts then stalla after 3 seconds
there is a fuel problem somewhere. more likely the carburetor bowl has water or debris in it. clean it real good.
Apr 30, 2017 | Craftsman Garden
Have a self-starting, self propelled toro lawn mower about 5 years old, I ran it out of gas by accident & now it won't start
It seems to be an obstruction in your fuel delivery system. Get a can of ether and a spray a short burst of it into the breather area near the carburetor, if the mower starts up and then stalls out, then you may need to get your carburetor serviced.
Dec 18, 2013 | Toro Lawn Boy Self Propelled CARB Walk...
Lawnmower starting problems
Clean or replace air filter. Fill oil, 30w. Clean & gap plug or replace.
Remove carb bowl from bottom of carb & clean. If gas is 30 days or more old, use fresh gas with Stabile.
Jun 19, 2013 | Garden
Model EG5000, one year old;last fire up in March, now it doesn't start. Has fresh gasoline
i'm sure you primed it - or go get a can of ether spray in carburetor
Oct 28, 2012 | Honda EG5000 Generator
Engine will not turn over
A FUEL PROBLEM. It doesn't over or doesn't keep running when gas is gone. Doesn't turn over, remove spark plug to let fuel out.
Nov 12, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Self propelled lawnmower starts and then stops after two minutes mowing lawn
clean the carburetor jets out thoroughly with carburetor cleaner and a strand of wire through all openings. this is a common problem with the engine dies a minute or so after it starts up
Jul 03, 2011 | Craftsman Garden
When I try to start my Craftsman Model # 917.388861 lawnmower, it will start and then dies right away, then Iit would start unless I prime it. Before it started doing this, the lawnmower was running very...
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me,
Thanks
Good Luck,
I hope this helped
Aug 16, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
I have a Craftsman self-propelled lawnmower that will not start.
first remove air filter and spray starting fluid in the carb? if it starts the fuel is the problem carbs are easily removed and cleaned make sure needel is not stuck? if it dosnt start chexk for spark pull rope hold screwdriver over wire touch it too plug end see if you see spark if not? then you must test zone conrol cable and grounds? did you hit something hard with the blade if so you could have a sheered flywheel key it will trow egine out of time ?
Aug 27, 2009 | Garden
Garden Logo
415 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
