Question about McCulloch MC1246 Handheld Steam Cleaner
I have had an Aquamark AM680 steam cleaner for some time without opening the box. Now I can't find instructions for it.
  • 2 more comments
  • shirley williams Nov 14, 2012
    I have had an aquamark am680 for at least 3 yrs and have just tried to use it but nosteam will come through
  • Sarah crouch May 19, 2013
    Hi Shirley, I have the same problem, did you ever get an answer, filled it with water, waited for it to heat up but no steam started!
  • Skana Aug 04, 2013
    Hello Dears, I have the same problem. Are yours solved? Please for your help.
    Hello Dear, I have the same problem. Have you got a solution for yours? Thanks fo your help.
It sounds like the pump that pumps the water to the heater is faulty. Try the non-return valve on the pump it may be sticking.
Posted on Aug 29, 2014
4 Suggested Answers
RockyNR1
  • 324 Answers
SOURCE: instructions for a kirby steam cleaner
Take a look HERE. It should help
Good Luck
Rocky
Posted on Dec 05, 2008
  • 6 Answers
SOURCE: i bought my euro-pro steam cleaner
I have the manual in a pdf file. Email me and I'll forward it to you
Rich
Posted on Feb 23, 2009
  • 29 Answers
SOURCE: I used my new proheat 2x steam cleaner the first
You may have mislaid a piece when you took your Bissell apart to clean it after using it the first time.
I experimented with mine to try and reproduce your issue. On the bottom of the water tank, there are two pieces that can be removed from it. One of them looks like a black plug at one end, with a red rubber flange piece on the other end. If you push your finger inside the red rubber piece, you can feel a spring move up and down. This is the first piece you place on the bottom of the water tank. I suspect you have this piece, because if you didn't, water would gush out of the water tank as soon as you turned it over after filling it.
The other piece, which is the one I think you may have have mislaid, is a larger black, plastic ring with screw threads. This piece goes over the top of the first plug piece, screws onto the water tank, and holds the plug in place. The words "RECLOSE TIGHTLY" appear on mine. If this piece is missing, the water tank does not sit flat on the base of the Bissell, but kind of flops around, out-of-place, and the unit will not dispense water properly, though it may leak it.
If ithat piece is gone, it should be possible to reorder it. Start here:
http://www.bissell.com/Customer_Service.aspx
If that's not the problem, if you have all the water tank pieces, I wonder if perhaps you unscrewed one black screw to remove the clear front plastic piece from the base of the unit-- the piece through which water is drawn up off the carpet-- to clean it, and didn't get it back into place properly. Make sure the two hooks at the bottom of this piece are inserted, one per side, into the clear plastic side pieces at the bottom. If the hooks are not secured properly, before trying to reinsert them, unscrew the black plastic screw so you don't break the tab. It's easy to miss getting these one of those hooks back in right, but it's important to do that before trying to screw the clear front plastic piece into place.
Posted on Jun 12, 2009
How can I obtain an instruction manual?
Go to the manufacturer website and look for the support section.
Alternately, contact customer support through email or the number on the website.
Aug 12, 2014 | Vacuums
Aquamark AM680 potable steam cleaning System. I tried it but the steam is not coming out. Kindly, anyone has a solution? Thanks
hi there sorry i dont have a solution i'm looking for one, did you manage to know the problem, i have the exact same one with the same cleaning steamer, thanks
Aug 04, 2013 | McCulloch MC1246 Handheld Steam Cleaner
Aquamark hand held mod.am680 not steaming why
hi there did you find a solution i have the same problem thanks
Mar 01, 2013 | McCulloch MC1246 Handheld Steam Cleaner
I can't take lid off steam cleaner!
need more information like make and model of steam cleaner
Jan 14, 2013 | Vacuums
No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on a steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly
  • Sep 22, 2012 | H2o TR220002 Steam Cleaner
    Hoover steam carpet cleaner - turbine needed for F7458-900
    Once you get the turbine out, open it up by unlatching the three latches and unscrewing two screws. Pull the gears out and WD40 everything. Let it sit for a bit and start turning the solver gear at the back with a pair of pliers. Once it is loose, put all the gears back together and return everything to it's place. FIXED! without buying a new turbine....
    May 30, 2012 | Hoover Steam Vac Dual V w/ SpinScrub...
    My h2o mop won't steam. How do i fix it?
    If your H2O mop will not steam:
    1. Ensure you have followed the operating instructions.
    2. Ensure you have followed the troubleshooting instructions.
    If the unit fails to produce steam:
    3. Switch off the power at the outlet.
    4. Look at the water reservoir. Inside you will see a flexible tube with a cone on the end. Tilt the unit or give it a gentle shake to submerge the cone in water.
    5. With the cone submerged, switch on the power supply and follow the normal instructions. The unit should produce steam as normal.
    Note: Unless the cone is submerged in water, the unit will not steam.
    Apr 21, 2012 | H2o TR220002 Steam Cleaner
    Hi -- For my White Wing Steam Cleaner: After I plug in the unit, and wait over 10 minutes, the Pressure gauge shows that the pressure at 2 (maybe 2.5, I can't recall as I'm typing today) -- not...
    Re: Low pressure on WhiteWing steam cleaner
    1. Make sure the safety switch for the hose handle on the right side of the hose handle is turned to the closed position. To do that, push it away form the hose.
    2. Make sure the steam release button (next to the on/off button on the control panel on the steamer) is in the Off position.
    3. Make sure the safety cap is tightened.
    4. Make sure you have enough water in the tank (at least half a bottle of water)
    I hope this helps.
    Jul 31, 2011 | Vapor WhiteWing Steamer Canister Vacuum
    I have the Euro Pro Steam Caddy #S3325H. I have had it for years and have never used it. Now I have a ceramic bathroom and dirty grout. There are no instructions in the box, and I can't get the steam to...
    dont steem this grout,,,it will only fall out or you could crack a tile,,,wipe on some strong bleach/loo cleaner and scrub it with a stiff brush its a lot safer than steeming it
    Aug 21, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
    Need instruction manual for goblin 1400 2in1
    I have a hoover steam cleaner (f5835)didnt get instruction-I tried to use it with water(hot) and cleaner- >>when I finished nothing in the bottom- I did use water and cleaner??what I did do wrong? Could I get manual- I thought I had it in the box- but it instruction how to put it together Betty Smith- BJ_SMITH@ATT.Net
    Dec 02, 2008 | Vacuums
    McCulloch MC1246 Handheld Steam Cleaner Logo
    1,053 people viewed this question
    Top McCulloch Vacuums Experts
    JoeVacs
    Are you a McCulloch Vacuum Expert? Answer questions, earn points and help others
