Question about Intermatic T104P 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw
I have a T104P,it is hard wired to hayward I hp pump,the breaker in panel is 2 together which i believe = 240...I am putting a dolphin 115 amp with a plug. i want to run the intermatic to a outdoor receptacle for the plugin dolphin. I beleive i need to remove one breaker and run the green ground to the new outlet, but there are 2 black wire ,one in 2nd position from left and one at 4th or last postion from left(facing timer).. the schmatic is missing. please advise the positive - neutral for these two since they are both black and appear to be like 8 guage. thanks robert
So you want to wire a 115 volt outlet to T104 240volt timer?
Open following link to see how to wire outlet so it turns on-off with timer.
If you do not want outlet to turn on-off with timer, connect 120Volt hot to terminal 1 instead of terminal2
http://waterheatertimer.org/images/Main-breaker-box-1-500.jpg
Open following link for general wiring information:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
What concerns me is the 8 gauge wire.
If the timer has 8 gauge wire, it is not code to connect smaller wire to outlet without putting 15 amp in-line fuse on 120Volt hot.
http://www.grainger.com/Grainger/COOPER-BUSSMANN-Fuse-Holder-1CV90?Pid=search
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 27, 2011
I need to wire a SP2607x10
look on motor should be a diagram pump is wired from factory for 240 volts if wiring 120 volts you have to chenge the brown and white wire see diagram then black goes to F1 white goes to F2 where white wire is
Jul 08, 2014 | Hayward SUPERPUMP 2.0 HP, 115/230V
Pool pump breaker tripping
1) Not likely the timer is problem, unless there was fire or overheating in timer box. Use nose and eyes to inspect for signs of high heat.
2) Eliminate timer as suspect:
Move wires on timer to test if timer relays have gone bad.
Move terminal 4 to terminal 3
Move terminal 2 to terminal 1
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
3) Check watt rating of Hayward pump, and voltage.
1Hp motor at 240Volt draws 8 amp, and can draw 6 to 8 times that amount when starting. Up to 100 feet, should be at least 12 gauge wire and double-pole 20 amp breaker. Over 100 feet, 10 gauge wire and 30 amp double-pole breaker is best.
http://waterheatertimer.org/Color-codewire.html#motor
4) Intermatic T104 240V timer is rated 40 amps
Can safely handle 1 Hp motor without nearing heat-rating capacity of timer
5) Make sure the motor is wired correctly for 240Volts.
If motor is wired for 120, and 240 is applied, then tripped breaker can result.
Apr 14, 2013 | Intermatic 220v T104p Swimming Pool Pump...
New hayward super pump trips 20 amp breaker after a few seconds
Use an ammeter that clamps around the wire to see how many amps it pulls. It sounds like a weak breaker.
Apr 01, 2013 | Hayward SUPERPUMP 2.0 HP, 115/230V
White whire
if 220 2 hots and a ground 120 volt black to L1 white to L2 see side of motor for wiring must change to 120 volt
Feb 17, 2013 | Hayward SUPERPUMP 2.0 HP, 115/230V
I have a Hayward Power-Flo LX SP1515-Z2-EBK3 that is being used to pump water through 2-4x8 solar water heater panels. The pump intake is 1 1/2 inch, discharge out is also 1 1/2 inch. The pump is located...
I have a 3/4 hp hayward pumping thru solar panels, too. 1-1/2 discharge thru 50 ft of 2inch pipe, up 12 ft then thru (4) 4x12 panels. Mine is on 115 volts ac.
You have plenty of pump and when you run a pump with low flow, amperage is low. You are not tripping your breakers, it sounds like the pump is overheating. Is it hot to the touch when it shuts down?
Do you have an ammeter so you could check your amps?
What size wire is running the 60 ft to the pump?
I don't have any other ideas to share.
Gary
Sep 06, 2011 | Hayward Power Flo Lx
Just purchased new Super pump 1&1/2 HP. power is 115v. The pump with wiring set to 115 trips the breaker immediately. When I switche the wiring to 230 the pump runs but has limited power. i have...
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you.
Aug 24, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
I am replacing my Hayward 1 HP superpump. The old pump had the 230/115 conversion plug on line 1. The new pump has it on line 2. Do I jusst connect the 115 v(hot) wire to line 2? That would be oppisite of...
It will not matter where you put the hot and neautral as long as one goes on line 1 and the other on line 2. Just be sure to reset the voltage indicator to read the 115V like before and your all set.
Oct 19, 2009 | Hayward 1.5hp 230v 2 Speed Uprated Super...
Motor wsurges on and off only one speed was purchased as 2 speed
Do NOT listen to your 'technician'. Is the motor rated for both 115 and 230 or just 230? If it says both voltages on the nameplate it will also tell you how to reset the motor for 115. Follow those directions and you should be all set.
Jul 13, 2009 | Hayward 1.5 Hp Northstar High Performance...
Wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
Jun 13, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Intermatic T104P 208-277Volt 40-amp Timer Switch-Double Pole / Single Throw Logo
189 people viewed this question
Top Intermatic Electrical Supplies Experts
Hippy_dd
Gene Haynes
Craig Butler
Craig Butler
Are you an Intermatic Electrical Supply Expert? Answer questions, earn points and help others
