Question about Refrigerators
Hi we have no idea how to get into the casing around the bulb to change it !! regards Denise
  • 32 Answers
If it's made of plastic, you can usually sqeeze or pinch or flex the plastic to release the prongs that are usually on the side of the cover.
Posted on May 27, 2011
Where can I get a free manual for a VW Panel Van 1996 Model.
the manual will still be available from a auto technical book shop
go google and type in --workshop manual for vw 1996 and if there is a pdf version ,it will be around 200 pages long
Sep 22, 2016 | Volkswagen Cars & Trucks
Only printing bottom half of all the lines, recently changed the ink but dont think that is the problem, any ideas please?
Hi Denise,
This is not because of faulty ink cartridge or faulty printer. You need to uninstall and reinstall the printer software. this issue will be resolved
Regards,
Sean
Apr 09, 2013 | HP Deskjet 3050A J611G Inkjet...
Avensis bulb replacement
hi
changing tail light on toyota avensis 2008 is a simple affair like the first love. if you access trunk and take the side little pockets you are able to check the hole and insert your hand in ti. now the tricky part, to change the brake light and the helplight they both sit on the same stock. to check this you have to move and see around from outside to check that you are touching the right stock. just when youre sure you can feel a little plastic handle on the top side of the stock this has to be pressed while you press one on the lower end of the stock, it takes time and patience but is achieveable,as in case of every success story, the two bulbs and stock can come out and you can change it.
the second part is of changing the signal bulb this has to be done very simple as it does not have a stock and the bulb comes out but just moving clockwise or anticlockwise dont remember so accurately and this is very simple to change.
to achieve all this there are some points that need to be kept in mind
1. daylight or a torch to check get the idea what we are upto and how the assembly looks, as you will not be able to change the bulb but through a mind picture of the assembly.
2. patience and go easy dont rush it may break some valueable parts and may cause extra money.
3. hope for the best
Feb 21, 2013 | 2005 Toyota Avensis 2.0
How do you change the light bulb in microwave
Hi, concerning your microwave. The wrap around case on this unit has to be removed to get to the light bulb. Be sure the microw. is unplugged. Hope this helps.
Jan 18, 2011 | KitchenAid KCMS135 Microwave Oven
I changed the bubble on my gas homelite mightlight trimmer and
I assume you are talking a primer bulb. Did you get the correct bulb? I ask because we carry over 20 different ones here on the shelf and some look close to each other but still will not work because of the lip seal and size. The other thing is that you don't want to over tighten because you will cause more damage than good. We do not usually change the gasket when changing the bulb unless the gasket was the culprit in the first place...try a new gasket. www.nnyparts.com
Jun 01, 2010 | Homelite Mighty Lite Lawn Trimmer
How do you change the rear window brake light bulb on a 93 Honda
unscrew the case from around the light pull the case off and then youll have access to the bulb take the bulb out usually turns counter clockwise replace with new one reverse the process.
Nov 14, 2009 | 1993 Honda Accord
Headlight change
He is right you do have a belt that works the timing chain that is located in the block attached to the cam. but all cars have timing chains in the block so you may want to look into that with the dealership or ask around if it would be a good idea to replace it. I know neons need them but i think Kias may also need it also.
And Q 2 is there a wiring harness on the back of the light assembly Cus with the new cars they just need to replace the bulb in side the light housing and if thats the case then you need the get the light bulb for your car and then just twist out the harness part it should be a black area with wires going into it and then twist it to get it out.
May 07, 2009 | 2004 Kia Optima
Super mario 64 for nintendo ds
None at all!!a rating would suffice!can mail it to u in a minute if u give me the add!regards!
Nov 27, 2008 | Nintendo DS Console
Buttons on the front of the monitor don't work
rosener
Rank:wizard_s.gif Wiz
Rating: 81%, 65 votes
Hi Denise,
Hope this helps; If you can control this before, ask for asisstance in opening monitor chassis with certified technician due to High Voltage Shock risk. Resolder the menu buttons and the control circuits. Resolder also SMPS module driving voltage to control circuit.
Best regards,
you are an idiot i have the same problem several times with this unit too. and it has nothing to do with a burnt wire you ********* stupid ********.
Jan 29, 2008 | TDV Vison TDV FV19B 19" Flat Panel LCD...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
