Question about Crayola Toys
On the Crayola Trace n Draw Projector, how do I open the lamp bulb compartment to replace the bulb?
  • 4 Answers
SOURCE: sharp projector XV Z90U
I also had this issue - followed the On, Input, Undo, Left, Enter, Right, On button sequence several times. Then I decided to push them in that sequence very quickly and it worked. The lamp LED on the front changed to green and the projector started up. So the button sequence they provide in the manual works, you just have to push them in rapid succession. Hope that helps.
Posted on Apr 19, 2008
  • 3 Answers
SOURCE: Sanyo PLC - Z5 Lamp Replacement Light
Just had the same problem. Based on other suggestions on here I tried resetting the overheat switch, and IT WORKED!
So, you have to pull the 6 screws (one of them is shorter than the rest, remember where it goes) that hold the top on the projector. 3 are on the back, 3 on the bottom - look for the arrows next to the screws.
Put the projector on it's feet, and pull off the top. The button wires will still be connected, so just hold onto the top and find the black circle/shaft above where the lamp is. The shaft has white paint on the top/tip of it. Push it down with a light amount of force. You should hear/feel it click.
Put top back on, put screws in, and you should be good to go.
Don't forget to reset the lamp replacement counter in the menus.
Posted on Aug 01, 2008
daniel719
  • 240 Answers
SOURCE: EPSON POWERLITE BULB REPLACEMENT PROBLEMS
ok
look at your users manual.
all epson models need to have lamp life reset befor the lamp will light.
I have had this same problem befor.
Daniel.
Posted on Jan 11, 2009
SOURCE: I replaced the bulb in my projector and now it
You need to hold the help button on the remote control for ten seconds, that should reset the lamp hour. NEC decided to make it inoperable after 2100 hours on the bulb.
Posted on Nov 23, 2009
BlackOnyx
  • 102 Answers
SOURCE: sony vpl-hs20 cineza projector- reset lamp counter
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS3.
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
This is required, to reset the lamp timer.
Also, something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
Posted on Feb 06, 2010
Epson 7800P projector?
Please dont use cheap alternative Lamp Bulbs in Epson. There are issues where the cheap Bulbs draw more current and damaging the circuit board.
Apr 22, 2014 | Office Equipment & Supplies
We have a hitachi cpx260 projector. both the power light and the lamp light is red.
This usually means you need to replace the lamp.
1) To do this, power off the machine and disconnect the power cable.
2) Open the lamp compartment, and remove the lamp. You'll need a screwdriver for this. I recommend having both a flat-head and phillips-head as the screw on the compartment door and the screw holding the lamp in are not always the same type.
3) Replace with new lamp and fasten with screw.
4) Reattach lamp compartment door and fasten with screw.
5) Power on your projector and go into your menu.
6) Find the lamp timer setting and reset the timer to zero.
Oct 18, 2010 | Hitachi CP-X260 LCD Projector
How do I change the lamp? Lamp came with no directions. This is a HD72.
Hello there,If your movie projector light bulb has stopped working, there are some simple steps to take to get your movies playing again. The hardest part may be finding the correct replacement bulb. There are so many different models with their own specific bulb. Here are some steps to follow to replace your burned out light bulb.
  • Locate the bulb in the movie projector. You may need to use a screwdriver to open the bulb compartment. Check your owner's manual for proper procedures.
  • Step 2.Remove the movie projector light bulb or lamp. The bulb must be cool before you take it out. Use a tissue or cloth to remove the bulb because the glass bulb is very fragile. Do not throw away your bulb yet, you may need it to help find a replacement.
  • Step 3.Find replacement bulb. The Better Lamps website offers a wide variety of light bulb models. From their homepage select the brand of movie projector you have and using the model number from your old bulb, buy a replacement.
  • Step 4Replace the movie projector lamp or light bulb. Do not touch the bulb with your skin. This can transfer oils from you onto the bulb resulting in a hot spot which can make the bulb burst. Use a tissue or cloth to handle the new bulb to screw it back into place and then replace the cover.
  • Jul 31, 2010 | Optoma HD70 DLP Projector
    How do I open the top of the projector to replace the light bulb?
    Hi, Follow :- http://www.wikihow.com/Replace-a-Projector-Lamp There is a Video as well on the same page.If you wish to Purchase the Bulb, you could consider :- http://www.partstore.com/minisites/projectorLamps/HowToReplaceProjectorLamps.aspx Let me know, if needed further assistance, Hope i helped you. Thanks for using ' Fixya ' and have a nice day!!
    Feb 10, 2010 | Televison & Video
    Replace bulb in housing for Infocus IN24.. i want instructions how to remove old bulb from housing.
    1 Turn off the projector and unplug the power cord. 2 Wait 60 minutes to allow the projector to cool thoroughly. 3 Turn the projector upside down on a soft cloth so that the lamp door is facing you. 4 Slide the lamp door off. WARNING: Be extremely careful when removing the lamp housing. In the unlikely event that the bulb ruptures, small glass fragments may be generated. The lamp housing is designed to contain these fragments, but use caution when removing the lamp housing. Before replacing the lamp, clean the lamp compartment and dispose of cleaning materials. Wash hands after lamp replacement. Hg ? Lamp contains mercury. Manage in accordance with local disposal laws. 5 Detach the lamp connector from the projector by depressing the locking tab on the connector and lightly pulling it free. 6 Loosen the captive screw that attaches the lamp housing to the projector.Carefully remove the lamp housing. Dispose of the lamp in an environmentally proper manner. 7 Install the new lamp housing and tighten the screw. 8 Re-attach the lamp connector to the projector. The locking tab should engage when the connector is fully plugged in. 9 Replace the lamp door by sliding it into place. Be sure the lamp connector wires are not in the way. 10 Plug in the power cord and press the Power button to turn the projector back on. 11To reset the lamp hour timer, navigate to the Settings>Service menu and select Reset Lamp Hours.
    Nov 09, 2009 | InFocus Office Equipment & Supplies
    Want to change lamp
    after you remove the door, the lamp assembly should be right ther with the little wire handle. unscrew the 3 screws and pull the lamp out. if none of that is there, you have no lamp to replace.
    Sep 22, 2009 | Samsung Sp-H710AE Multimedia Projector
    Lp790 projector does not turn on
    it would still try to turn on even iff there wasn't a lamp in it. if it won't even turn on, see if the switch inside the lamp door is working. it won't turn on if the door is open. also, the thermoswitch on to of the lamp compartment (through the inside) may also be blown and needs replacement.
    May 12, 2009 | ASK Proxima InFocus LP790 and Proxima...
    Promima pro av 9400+ light dims slightly
    It may sound like the bulb needs replacing but first you should make sure that the outlet you plug it into has a constant 110 voltage. You may need to buy a voltage regulator to see if that works first. You can try a new outlet too. Sometimes other sources draw electricity from your wall outlet which cause the drop in voltage and poor lighting. Of coarse if that does not work, replacing the bulb would be the next logical solution. If your handy at opening it up, you could test the capacitors and connections for polarity and resistance with an ohm meter. Also check the current in the wall socket for constant voltage.
    Nov 20, 2007 | ASK Proxima Proxima LAMP-021 Replacement...
    Toys Logo
    389 people viewed this question
    Top Crayola Toys Experts
    Tom Chichester
    Lawrence Oravetz
    Pierre Legault
    Are you a Crayola Toy Expert? Answer questions, earn points and help others
