Question about Compaq Presario Notebook
I got a error code 10008 what do i need to do
    President:
  • 1,607 Answers
Your hard drive has a problem. Contact Compaq for replacement if it is still under warranty.
Posted on May 27, 2011
Primary hardself test shows failed hard disk 1 (warranty id-error code 10008). it runs until it's 95% complete. however i have absolutely no problems with my computer/laptop. very confusing.
Your hard disk has a damaged area. Apparently this is close to the end of the storage area. Since there are no software in that area, you will have no problem. (Because the OS not trying to access any files in the damaged area).
Try not to fill the hard disk more than 80%. If files are written in the damaged area, you will experience problems with your laptop.
Sep 11, 2011 | HP Compaq Presario C700T
My laptob gives me error code 10008 when i turn it on what could i do ?
Glad to HELP YOU!
Usually that error [code 10008] appears when the hard drive has a SERIOUS PROBLEM!...
If your laptop [by the way... it's LAPTOP and not "LAPTOB"...] is under the warranty conditions get your hard drive replaced. If not - then buy a new hard drive for your machine.
A good and reliable hard drive is under $100 these days.
Go on Google [or any other search engine ] and check for a HARD DRIVE DIAGNOSTIC UTILITY; I've found for you a few HERE.
Download it, install it and run a test. It might be not only the HDD with problems; it could be some other components of the motherboard that might generate a hard drive failure...
GOOD LUCK!
Apr 15, 2011 | Compaq Presario Notebook
Erroor code 10008
According to Compaq tech support. That error code of 10008 indicates the hard drive has failed and should be replaced. I would recommend contacting HP/Compaq and finding out your warranty status. If it is still covered under warranty, they can replace the drive with a new one. You will need to contact them to find that out.
Apr 13, 2011 | Compaq Presario Notebook
Compaq Presario PC Notebook Error code 10008 hard disk 1
It means your hard drive has failed to boot, try reinstalling your operating system. If all else fails send it to the company.
Mar 04, 2011 | Compaq Presario Notebook
Laptop will not boot up warranty id error code 10008
Hello my friend.This is means that your hard disk is corrupted,has bad sectors.If you can boot at all to run the disk diagnostic program then your hard drive is dead and you must replace it.Is not difficult to replace it.Usually if you turn your computer you will see a small cover with screws,there is your disk and you can take it off and go to a shop and buy another one similar.Usually is 2.5inches and you choose the capacity you want.
Feb 08, 2010 | Compaq Presario Notebook
Asi gave mine laptop compaq c700 pc notebook to hp service centre for check up. they told me that there is a hard disk problem .so the problem was "HDD test fail & check with another HDD.& all...
Only Hp knows what that means in their diags. Get it shipped back and take it to a Locally owned PC shop and have them take a look at it. It is possible that you have just enough file fragmentation and file structure corruption that it is fail diags. Why did you take it in to be looked at anyways?
Sep 11, 2009 | Compaq Presario 700 470024-192 Notebook
Can't find boot manager.exe
Somehow you have aquired a boot sector virus and your have to reformatt the hard drive and reinstall the system in order to bring it back up.
Jul 12, 2009 | HP Pavilion dv6000z Notebook
Error message: Failed- Replace Hard Disk 1 (Warrany ID error code 10008) what does this mean I have a compaq Presario A900
It means that Hard Disk 1, which is either the first or second harddisk in the laptop, has failed. First open the BIOS on your latop. Before windows startup there should be a Compaq logo on screen. There also is some text saying which key to press to access BIOS. In BIOS, try opening some menus and look for a menu that shows your disk drive. In the same menu should be your harddisk. If it is there, go to A. If not, go to B. A: The disk is not broken, it just made a write error that destroyed WIndows. Insert the disk with your operating system on it into the laptop, and reinstall it. Your data is gone, but the laptop will work. If reinstalling the OS gives errors, and is unable to complete, go to B. B: Your harddisk is broken. There is no way to fix it, and you will need a new one. Contact Compaq if your warranty is still valid, and if not, take it to the nearest computer shop and ask for a new harddisk. If you have any more questions or trouble just post back here. I hope this helps, Yannick
Jun 07, 2009 | Compaq Presario Notebook
Failed Replace hard disk 1 warranty id code 10008
As the error message states you need to replace the hard drive as the hard drive is most likely dead ie not working / broken.
Apr 16, 2009 | Compaq Presario M2000 Notebook
Compaq Presario Notebook Logo
165 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
