Question about Minolta Office Equipment & Supplies
What does this mean on my BizHub 200? !!ABORT!! CODE = 0x0000999a TASK ID = MIO-CREATE
  • Minolta Master
  • 6,680 Answers
MFBS Board, FAX Board, Memory Board*
one of the above boards or they have a connection problem. check the cable each one seperately check each one for a bent pin or worse case the board or boards are bad
Posted on Nov 22, 2015
3 Suggested Answers
SOURCE: Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Posted on Jun 05, 2008
  • 340 Answers
SOURCE: C200 powers on and reboots
Sounds like you will need to uninstall your printer and software and then reinstall it. You can do this by going to start, click on printers and devices, right click on your printer and click delete. Next you will need to go to start, control panel and then programs. Under programs you will see uninstall programs, click on this. You will need to scroll down and look for anything relating to your printer and uninstall each one, one at a time. There will be at least one, most likely 2 that you will need to remove. Once you have done this, unplug your printer from your computer and leave it unplugged until you are instructed to plug it back in during your installation of the software. You can use your cd that came with your printer, if you do not have it you can download the software from the following link
http://onyxftp.mykonicaminolta.com/download/Search.aspx?ht=
Download the correct driver for your operating system, the full driver version and software is what you need. Once you get that downloaded, go through the installation process and you should then be able to print. If you need further assistance or for some reason the above does not help the issue, please let me know and we will move on to step 2.
Good luck and I hope this helps!
Lori
Posted on Nov 04, 2010
What dose code C3451 mean
Id say the easiest thing to do would be to replace your fuser.
Oct 14, 2014 | Konica Minolta Toner For Bizhub 200 222...
Bizhub Konica Minolta - Error Code E002
Sir/ma could not find that code for a Bizhub 200
Jan 15, 2014 | Minolta bizhub 200 All-In-One Printer
BIZHUB KNOCA MINOTAL ERROR CODE CB116
Could not find that error code for a Bizhub 200.
Dec 14, 2013 | Minolta bizhub 200 All-In-One Printer
Bizhub 350 manual de servicio codigo de error el c0500
In correct code for a Bizhub 350. What is the model # Bizhub Fuser errors start with 34, 37 ,38 for the Bizhub 200/350
May 11, 2013 | Minolta bizhub 200 Copier
Bizhub 200 error 107
Could not find that code on the Bizhub 200 service manual< normally a C will be the start of the code.
Feb 11, 2013 | Minolta bizhub 200 All-In-One Printer
Abort code
contact service use go to www.konicaminolta.com
Oct 06, 2012 | Genuine Konica Minolta Konica Minolta...
My bizhub 200 has message to change pc drum what does this mean?
This means that imaging unit of your photocopier machine should be replaced.its life is over now.
Oct 06, 2010 | Minolta bizhub 200 Copier
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
Scanning Problems
mail server issue. check your outgoing mail server. Most smtp depends on your isp. for instance, use smtp.sbcglobal.net for at&t isp. if you have an exchange server use your exchange server's outgoing mail.
Hope this helps!
chris
www.willhelpu.com
Jan 22, 2008 | Konica Minolta Bizhub-200 Minolta Printer
198 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
