Question about Dryers
I have a Maytag MDET336AYW dryer, the motor will run but the drum doesn't turn....How do I even open the thing up to get in and look at it?..Rich
  • Dryers Master
  • 7,482 Answers
Hi rnjgibson...
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please take time to rate me
To see the parts for your dryer to to this web page
http://www.partselect.com/ModelFrames.aspx?ModelID=150034&ModelNum=MDET336AYW&mfgModelNum=&ManufactureID=1&Selected=58906&Position=2&mfg=Maytag&Type=&Mark=2
Posted on May 27, 2011
Dryer drum doesn't spin
If the motor runs and the drum doesn't turn then most likely the belt is broken.
Oct 23, 2012 | GE DBVH512EFWW Dryer
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
HOW DO I FIX MY MAYTAG DRYER. IT DOES NOT START WHEN I PUSH
There are a few things that come to mind why your dryer may not start: -Check to make sure there is power going to the dryer -Check that the door switch is working -The motor may have overheated -There may be an electrical fault or loose wire -If the motor turns but the drum doesn't, check that the belt is still on the drum.
For some of these checks you may have to remove the control panel or the front panel. Depending on your skills and experience you may want to have some of these checks done by a qualified professional due to the danger of live electricity.
Jul 29, 2011 | Maytag Dryers
Maytag dryer hye3657ayw does not run. When I open the door the light doesn't come on but there is power at the outlet.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 07, 2011 | Maytag Dryers
Heatman - you comments are always dead on. You've help me extend the life of my dry twice. My current problem is this: When starting the dryer, the drum will not rotate, and the motor makes an...
it could be the extra weight on the motor and the motor is bad,try this,open the door,push the door switch in with one hand and spin the drum with the other hand and have someone push the start button,if it runs and most of the time it does because you're helping it along you need a new motor.one more thing,if the filter is in front,remove the duct that the lint filter slides into and spin the drum,if the blower wheel moves with the drum you have a bad motor,if it doesn't you have something stuck in the blower wheel and it jams up the motor because it's attached to the motor shaft.
Jun 10, 2011 | Dryers
Our Maytag gas dryer drum doesn't turn. Replaced belt. Heats up but drum isn't turning
There are three possible reasons why the drum doesn't turn.
  1. Broken belt. You replaced the so in this case it's not.
  2. Door switch. The dryer will not operate if teh door switch is defective. It is inside the drier main housing near the door frame. You need to raise or open the top or front of the dryer to reach the switch. Replace if defective.
  3. Motor. If the motor hums when the start button is pressed, the motor maybe burned-out. Check the dryer motor:
  • Check the blower fan housing for obstruction and manually turn the motor shaft.
  • If the motor is very stiff or cannot be turned manually, you need to replace the motor.
  • If the motor rotate freely, run the motor without the belt. If it runs fine, there maybe problem with the idler pulley or the clothes drum.
  • Rotate the drum by hand. If it is difficult to rotate it, correct any problem with the rollers or pulley. Reassemble the dryer and try it again.
  • If the motor hums but does not run on it's own even without the belt,but can be turned freely by hand, you need to replace the motor start capacitor or the motor itself.
Sep 25, 2009 | Maytag Dryers
My maytag dryer MDET336AYW won't come on
probably have a back door switch. look and see if when you close the door it closes the switch
Jan 04, 2009 | Dryers
Dryers Logo
225 people viewed this question
Top Dryers Experts
