Question about HP w1907 LCD Monitor
Everytime i put a picture for the background on the desktop it doesnt come out clear its all fuzzy/blurry anyone know what's happenin?
    Guru:
  • 767 Answers
It's because your resolution(size) of your desktop is larger than the resolution(size) of the picture. If for example you are running a resolution of 1280x1024 then a picture with the dimentions of 1280x1024 would fit perfectly and not be stretched. See my tip on setting the desktop background here for further details: http://www.fixya.com/support/r6775332-change_desktop_background_image
If you want a smaller image to be centered and not stretched then right click on your desktop and go to Properties. Then click on the Desktop tab. To the middle right there is a heading that says Position. Click the little selection to Center. This will center a smaller image instead of making it all blurry and stretched.
Posted on May 31, 2011
Print on screen is hard to read
When you say its hard to read are you meaning its sort of 3-D looking or is it like a glowing that makes it fuzzy only in certain areas. Let me know and I will assist you with the issue.
Jan 25, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Some of my pictures are blurry using a cannon rebel 3. how can i fix this problem?
There are several possible causes for blurry pictures.
1) Camera motion. If everything is blurry, it's most likely because the camera moved while the picture was being taken. Make sure your shutter speed is fast enough if you're handholding the camera (longer lenses require faster shutter speed). Alternatively, put your camera on a stable surface, such as a tripod or a tabletop.
2) Subject motion. If the subject is blurry but the background is sharper, then the subject may have moved while the picture was being taken. Use a faster shutter speed. Raise the ISO if needed. There are limits, of course. If you're trying to photograph a fast-moving object in the dark, you probably won't be able to.
3) Improper focus. If the subject is blurry but something else in the picture is sharp, then the camera probably focused on the wrong object. Move the focus selector to the subject you want in focus. Alternatively, center the viewfinder on the subject, press the shutter button halfway to lock focus, then reframe and shoot.
Without any more specific information as to what and how your pictures are blurry, I'm afraid the above is all I can give you.
Jan 13, 2012 | Canon Cameras
I have a ViviCam X014N. Everytime I take a close up pictures, the images comes up fuzzy. What am I doing wrong? I follow Macro setting recommending 30-45 cm away, but still no luch.
Sounds like you're not using a tripod. Macro pictures have a very small area that can be in focus....the slightest movement can cause the blurry pics.
Sep 19, 2011 | Vivitar X014 Digital Camera
When I turn on the TV, the picture is fuzzy. After five minutes, the picture is clear but any words are out of focus even the menu for adjustments is out of focus. The convergence for red is clear but...
Below are some troubleshooting tips for a TV that has a fuzzy or blurry picture;
If your Plasma or LCD TV picture is blurry or fuzzy there are several things that may be causing the problem. It's worth running through the following list before seeking service. You may find yourself saving the full cost of a TV repair.
Make sure you are using the appropriate cable box for your TV. If you have a high-definition TV you should also be using a high-def channel box from your cable provider. Watching standard definition channels on a high-def TV can make the picture look distorted and fuzzy.
Not all cable channels are broadcast in high-definition. When you stretch a standard definition picture to fill the full frame of your wide-screen TV it may look distorted. You can try changing your TV display settings to show standard-def channels at their native resolution. This will create black or gray bands on either side of your picture.
Ideally all of your video components will be connected to your TV with HDMI cables. Your next best option will be component video cables. If your cable box does not have HDMI capabilities, contact your cable company about upgrading your box to one that does include HDMI.
Make sure there is no glare on your TV from a window or other strong light source. This can significantly degrade the quality of the image you are watching.
If your TV has digital noise reduction, try turning that feature on.
You can adjust your TV's sharpness and picture modes to see if that improves picture quality.
Try plugging the power cord into a different electrical outlet and/or surge protector. You may be receiving electrical interference through your power cord.
Trying moving any nearby electrical devices away from the TV. They may be creating interference that can degrade the picture quality.
Let me know if the above helps or not, so that I can direct you further on what do next.....
Best regards.
Apr 14, 2011 | Zenith IQB50M90W 50" Rear Projection...
We just purchased an Samsung Plasma model #PN50B1D
unfortunately these newer tvs do not display the standard definition analog channels very well. the picture gets better when viewing digital channels but doesnt display at its best untill u place it on a high definition channel
Feb 07, 2010 | Televison & Video
My camera takes blurry pictures
If you dropped the camera then the lense is out of alignment from when you dropped if mabey it can be fixed or not. It will cost much to fix the camera.it has a gear mechanisim so if its out of line its fuzzy pics.
Dec 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Fuzzy pictures
The blurry pictures are due to movement. Sometimes adjusting the flash helps.
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
TV took a dump
Sounds like a problem with the Hyper Board.
Dec 13, 2007 | Toshiba 65H81 65" Rear Projection...
Multiple problems, hoping for one solution
sounds like it is probably worth trying to degauss check this excellent site; http://woil.ws/fixmonitor/ for details of how to try this on the cheap - it works If it doesnt solve your problem, the fact that you are getting different quality from different crt s suggests that they could be the root cause - see if you can get the part number, and get a price you may find it is cheap enough to be worth trying - check also the power supply - poor voltage output can sometimes cause these type of symptoms. Hope this helps, if not post again - some of the other guys know tvs much better than me :)
Mar 08, 2007 | Sony KP-53S65 53" Rear Projection...
HP w1907 LCD Monitor Logo
83 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
