Question about Curtis DVD7026 7 in. Portable DVD Player with Screen
The player will not load the disc. I have tried several DVD's (inc. one new one) I used a cleaning disc...it will play the music at the end of the cleaning, but it just searches and searches and then comes up with the message that there is no disc. Just before that it makes a grinding sound. It is not very old and it is not used that often. Can it be repaired economically? How? Where? Thank you
  • 998 Answers
The lens of your dvd is weak or just dirty. Try to open the cover of your dvd there you will see the optical lens try to clean it using a cotton buds but wipe it gently and never touch the lens. It might help
Posted on May 27, 2011
Why does my digitec dvd player say NO DISC?
Usually, you either have dust on the laser, so it can't see anything, or you have something on your disc (or damage to the inside part of the disc, which tells the player where all the files are). You can try cleaning your disc, but if you've already tried more than one disc, you might be able to find a CD or DVD cleaning disc at an electronics store. If your DVD player plays CDs, either one might work, but if it doesn't play CDs, then you will have to look for a DVD cleaner. As a last resort, you could try getting a can of electronics dusting spray (don't use a vacuum, as the static from a vacuum can damage electronics) and use several quick sprays, while the DVD player is unplugged. Give it a few minutes to dry out, then give the DVD one more try.
Jul 19, 2014 | Televison & Video
Toshoba tv/dvd combo. won't play many dvd's. makes clicking sound as it tries to load movie?
Dear Lesley!
It looks, like your DVD lens might get contaminated with dust and/or dirt, which is being picked up off DVDs. Let's try to load music CD, instead or DVD. If it loads well, I will suggest, that your DVD player is at fault and you must give up using it. External basic DVD players are quite inexpensive and easy to connect to your TV. But: if no CD, nor DVD load, the solution might be much simpler: use lens cleaner CD with brushes. good ones might even have a special fluid, which applied to brushes(alcohol based). Just load it into your TV's player and follow audible directions. After couple attempts, your lens should be clean enough to play DVDs. Please, don't try to use any "ear swabs", instead. The lengths is not long enough, plus it may damage load mechanism or get stuck inside. I've seen such a cases lately.
Good luck,
Thank you,
Alex.
Dec 15, 2011 | Toshiba 32CV100U 32 in. TV/DVD Combo
The digital labs k715 portable dvd player says no disk when there is a disk inside.have tried several disks.please help
how long have you been using this player and when did this begin?
Remove the disc and try another. If the player refuses to eject the disc, remove it from the wall and fix it back and fix it back again. Then turn the player on.
If the player still gets stuck on "loading" mode for other disc, then it means the laser is weak.
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Good luck.
Sep 09, 2011 | Insignia NS-PDVD8 Portable DVD Player
My Curtis dvd player 1046 won't play dvd's, it says its loading then it says bad disc
First, try playing a regular music CD and see if that works. Next step would be to get a laser lens cleaner disc and run that in the machine. They come in both CD and DVD styles. You most likely won't get a DVD version to work since it's not reading DVDs, but you might get lucky and get a CD version to work, thus the reason for trying a music CD in the player.
If the cleaning doesn't work, or you can't play a CD either, then something has most likely died. There are really only two things that could go wrong with a DVD player, either the spindle motor (spins the disc) dies, or the laser dies. Both are somewhat common problems on low-end electronics. They can be fixed, but with low-end units, like those made by Curtis, it would cost you less to toss it out and buy a new unit.
Apr 05, 2011 | Curtis Televison & Video
Tried to use a laser lens cleaner disc to clean my player, once loaded and inside the player I went to press play and follow the instructions, but my player stopped running and a (check disc) appeared on...
I have this DVD Cleaner from All sop Inc as well,this disc only do very miner cleaning to the DVD player Laser eye.Did not work on my DVD player.I have to take the DVD player aparts,littery take some Q tips and dips it in with some rubbing alchahol to clean the DVD laser eye itself.After littery take the DVD player aparts and clean the laser eye itself.If the DVD player still doesn't read and play any DVD discs?The DVD player laser eye is bad,not worth repairing,the brand new DVD player is cheap,cost only like $40 brand new one.
Nov 23, 2010 | LG DN798
When a disc is loaded, it reads no disc, and disc cannot be played.
It is very possible that the lens motor has burnt out. Sometimes the capacitors on the motherborard short out causing the gear timing to go out..
The only thing you can do to fix this is to take the cover off. Get cotton swab and dip it rubbing alcohol and clean the glass laser eye with it.
Jun 03, 2009 | Samsung DVD-HD850 DVD Player
DVD player won't play DVD, says "load"
The unit can recognize that a disc has been loaded but can not read the contents. This can be as simple as a dirty lens or more drastic like failing optics. Try cleaning the lens using a cotton swab and alcohol. If that fails to correct the problem and a music CD will play OK, then the optics are failing. DVDs require more laser power to read than a music CD.
Dan
Feb 04, 2009 | Toshiba SD-3990 DVD Player
Dvd player refuses to read any disc I load into the machine
Hello I was looking to try and help you with your DVD player, we will start by loading a music cd store purchased, no burned cds please, if the cd loads and plays then your dvd player is either out of adjustment or going bad, most dvd players, i have worked on, will load and play a music cd, but will show loading errors when trying DVD's. If the music cd dosen't load then there could be an issue with the drive or tray. If the music cd plays just fine, then your laser is either out of adjustment or going bad. You can call the manufacuter to see if there is a process for resetting the DVD player, not all DVD players have this option, if resetting the DVD player dosen't work, but music cd's do then your laser lens is dirty or going bad. At this point you have three options 1) Take it to a repair shop, 2) Get an new one, 3) Get your hands dirty if your really handy and know what your doing to clean and replace the laser. I hope I can be of further assitance and I look forward to helping in the future, Thank You and have a nice day.
Jan 14, 2009 | Televison & Video
DVD player isn't loading and playing properly
Since it will play eventualy, I'd suspect a dirty lens. Open up the unit and carefully clean the lens using a cotton swab and alcohol. Also, try a music CD. If the CD works flawlessly but DVDs still fail occasssionally, the optics are starting to fail and will need to be replaced.
Dan
May 13, 2008 | Samsung HC-P4363W 43 in. TV/DVD Combo
Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Oct 29, 2007 | Toshiba SD-K860 DVD Player
Curtis DVD7026 7 in. Portable DVD Player with Screen Logo
Top Curtis Televison & Video Experts
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
