Question about Bose Wave Radio
During the day the LEDs are not bright enough to read the time. Is there an adjustment?
    Brigadier General:
  • 8,546 Answers
Actually, no. The brightness adjustment is for its automatic low-light situational dimming mode.
It's in the manual, page 18. get it at Bose.com.
Posted on May 27, 2011
Faint picture screen
Press the reset switch to reset the garmin, is the backlight turned off in the settings or is it possibly faulty?
Oct 27, 2008 | Garmin StreetPilot c530 GPS Receiver
50 watt led flood light isnt bright enough to illuminate the ground. It just barely lights up the actual leds. I.E. cant tell its on during the day can just barely see glow at night. Is it the leds o
actually you need to first confirm the wattage and lumes from the supplier.. mostly its a lack of power that causes this.. YOu can build Joule thiefs for each LED (very very impractical) or you can replace thw poer supply which most likely has a problem..
Dec 27, 2012 | Computers & Internet
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
Looking at a clear bright sky at night and we can't see a thing - it is at if lowest eyepiece - got it from sears Dec. 29th - it is the Bushnell 3" reflector telescope w/talking guide and tripod
Can you focus during the day time on a distant object. If you can nothing is wrong with the scope. Objects in the night sky are tiny, smaller than the tip of your finger held at arms length.
Practice focusing during the day time, and read my TIPS on my profile page.
Jan 10, 2011 | Bushnell 3" Reflector Telescope w/Talking...
Lcd display is what seem to be to bright hard to read black info .or the black symbols are very light hard to read with bright orange lighted display thanks Mark
You don't say what device this is on, HOWEVER most thngs have a "contrast" control that will adjust the visibility.
Sometimes they call this a viewing angle control and sometimes it is a small shaft from the back of a unit, OTHER times it is a setting available through a menu... if you can read the display enough to find it...
Oct 12, 2010 | Music
Can I program the automatic headlights to always shut off when the ignition is shut off - day or night?
I have a 1997 cadillac deville that has both 'daytime running lamps' when put into gear and 'twilight sentinel' which turns the headlamps and parking lamps on at night, and goes off during the day or when it is bright enough.
There is an adjustable delay for the twilight sentinel to turn the headlights off after the ignition key is removed and it is night time.
I had the 'daytime running lamps' installed on a 1990 Cadillac Deville that turns the headlamps only on when the ignition key is switched to on with an aftermarket module. The headlamps are about 70% or so as bright as the regular twiilight sentinel headlamps and parking lights and are designed to go on during the day.
The twilight sentinel overrides this feature when it gets dark outside.
I had the daytime running lamps installed by an auto electric shop that specializes in electrical systems, alarms, stereos, etc.
Does this help?
Jul 10, 2010 | 1998 Buick LeSabre
Screen is Extremely Dark!
Good Day, Cary;
PICTURE IS DARK WHEN OSD CONTRAST MENU ADJUST LEVEL CHANGES.
Cause: SHORTED ZD-309.
Also, increase Screen controls at front of TV and see what pix brightness does . Hopefully you did check brighteness & contast levels. When adjusting Sreen controls set contrast control at about 90% and brightness at about 50%.
Good Luck, big IRISH.
Aug 20, 2008 | Hitachi 53UWX10B 53" Rear Projection...
The digital display is very dim and hard to read even in the dark. Is there a way to adjust the brightness?
I have a Sharp Carousel 1.5kW microwave oven with model number R-310F(W)C. The LCD dispaly on my unit recently became very dim. After check the small circuit board on the front panel, I found that the problem is caused by the LCD backlight driver which drives three surface mount LEDs. As the LED driver is inside a chip built on a small daughter card, it requires a replacement daughter card, or the entire circuit board for display and keyboard. A simple alternative solution is to cut the link between the three LEDs and their driver, then build a small circuit to drive the LEDs. I can provide the circuit diagram if interested.
Apr 13, 2008 | Microwave Ovens
Images too dark or too bright
Metering has gone on the .Can you set the camera to Aperture priority or speed priority?Set to either permanently if you cane then you should get a standard exposure. The inside shots may appear dark, but all the information is there and a treak in an image editor will brighten them up. Cant do the same for too bright images though if they burnout then that's it. a repair is not likely got a birthday any time soon Got some one that luvs you enough to buy you the next one.?
May 20, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Bose Wave Radio Logo
260 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
