Question about LG Washing Machines
My LG washing machine, model WF-764STP is giving an HE error. The book says it is the water level sensor. Where do I find this and how do I repair it. Thank you
    President:
  • 842 Answers
If you take the top of the unit, you will find it strapped to the side of the chasis about level with the top of the drum. Ots white and round, about the size if a child's palm. YouMAY find that removing the unit, blowing down the plastic feed pipe and then putting the unit back fixes your problem. My personal experience with these things though is that once they fail they call all sorts of problems. Very nice of your machine to warn you. It's not unusual for these things to fail in a manner that just tells the machine that there's not enough water and they just fill and fill and fill until water comes out of your soap drawer!
Needless to say therefore, if you do remove and refit, or even if you buy a new one to fit.... WATCH the machine for the first couple of loads and make sure that it's not under or over filling before you walk away and leave it to its own devices.
Posted on May 27, 2011
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
LG wf-t652a displays an error "PE" & dinging when turned on. Any suggestions.
Pressure sensor error. Check also the pressure hose. The pressure sensor stops the water at a set level depending on the cycle you choose.
Jul 16, 2014 | Washing Machines
Dear expert of LG WF-F783PC (washing machine). i am using an LG washing machine model LG WF-F783PC.its giving a warning alarm after 3-5 seconds of operation (wash & spin mode)
Possible that the inlet flow is low , check the inlet valve and filter. Also try using the manual settings and if all the cycle works well then it is possible that the fault is with the controller unit or a possible errors from the level controller or the inlet valve.
It is best to remove them , check reset after cleaning.
Nov 02, 2011 | LG WFT1071TP Top Load Washer
My washing machine model is LG WF-660.. it cannot function due to failure indicator at water level.... it keep on "beeeping" cannot do other operation.... plz help....tq...
pl check the bp sensor or the conector of the wire harness.according to my knowledge there is no door sensor in wf-660.if bp sensor is ok change the P.C.B
Feb 03, 2011 | LG Washing Machines
Display says error
I have give the same solution in other post, here it is :
usually problem with semi auto washing machine is on the sensors , exactly in the water level sensor, please check the hose that connected to water level sensor, make sure no dirt blocking or clogging the hose. also you can clean the tube under the pulsator, usually there is many dirt blocking the hose line.
the problem is in the hose leading to the water level sensor, if there is no dirt and looks normal, water level sensor must be replaced
Jul 24, 2010 | LG WM2487H Front Load Washer
LG WF T6517TC Washing Machine does not fill water
sir
my washing machine WF-T6517TC
when it start to wash get Alarm "dE" beep and stop machine.
what need to do.
call me 91080843
Apr 10, 2010 | LG Washing Machines
I have a LG WF-764STP which wont spin the clothes or drain properly after. Where is the filter?
THE NUMBERS YOU HAVE PSOTED YEILD RESULTS FOR ALL TYPES OF APPLIANCES AND IS DIFFICULT TO HELP. SEE AND POST THE CORRECT MODEL NUMBER OF YOUR WASHER FOR FURTHER ASSISTANCE.THANK YOU
Apr 24, 2009 | LG WFT1071TP Top Load Washer
I have Model WF-S6607?WF-S6607TC. Washing Machine. Loaded the clothes, pressed the POWER button, pressed the WATER LEVEL button, pressed the PROCESS button, and pressed the START/PAUSE button, But few...
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Apr 04, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WF-764STP
Washer capacity- 7.2kg · 8 Washing Programmes · Child Lock · 53 cm Wide x 54 cm Deep x 85 cm High
Sep 12, 2007 | LG WFT1071TP Top Load Washer
LG WF-764STP
Remove the belt and check whether the motor spins and let us know with your result. Good luck !
Aug 16, 2007 | LG WFT1071TP Top Load Washer
Washing Machines Logo
87 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
