Question about StarTech.com Star TSP143, USB, Future Print Printer
How do I install Star TSP143, USB printer in my winxp computer?Guide me through the steps.
    Sergeant:
  • 186 Answers
Just insert the installation disk then fallow the step...
Posted on May 27, 2011
Printer come to ready then error led flashing constantly
This is a critical issue which needs constant monitoring of the device and continuous chat / email exchange.
Thus it is advised to please avail paid fixya services for better support and quick solution.
Thanks
Oct 21, 2011 | StarTech.com Star TSP143, USB, Future...
Hi, How can I use two cash drawers with one Star TSP143 ECO futurePRNT receipt printer. Star support say it can be done 'unofficially'. Therefore they will not say how it can be done! I use the...
Hi Gordon
There are 2 cash drawer circuits in available to be fired using the printer. You may need to purchase an adaptor to use this function or wire the cashdrawes yourself. Please contact support@star-emea.com for further help.
Star Technical Support.
Aug 09, 2011 | Star Micronics TSP100 Thermal Printer
My window 7 doesnt recognize my star tsp100future print or tsp143 printer :(
Did you check the windows 7 compatibility listing for your Star printer? Find out here: http://www.microsoft.com/windows/compatibility/windows-7/en-us/
If it is not listed, it will not run under 7. I hope this helps you with your trouble.
Thanks for your interest in FixYa.com
Feb 14, 2011 | Star Manufacturing Star TSP143 Receipt...
Need Driver under WinXp Sp1 for AceeScan 620P
WIA driver for AcerScan 620P
*Follow this link from mirxosoft to download the latest driver.
*This page provides a list of Windows Image Acquisition (WIA) devices with built-in drivers in the Microsoft Windows XP operating system. There is no need for additional drivers to get the WIA experience out of the box when installing these devices.
Apr 22, 2010 | AcerScan 620P Flatbed Scanner
Star TSP 100 do not print in access 2003, access said is over the 22.75" limit
Miguel963,
I hope you have solved your problem in the mean time (9 months ago!).
I just bought the same printer and ran into the same problem. After looking on the internet for a solution and finding none I read the software manual a couple of times again and came up with this solution.
Access is right when it claims that the report's length is over the 22.75'' limit. The paper size of the 72 mm x Receipt is 72 mm wide and 3,000 mm tall; 22.75 being 577.85 mm. This means that the selected paper size is more than 5 times too tall.
The simplest solution is to choose the 72 mm x 200 mm paper size.
Next you need to go to the properties of your printer (Start > Settings > Printers and Faxes > Star TSP100 Cutter (TSP143)). Select Printer > Properties. In the Properties dialog select the Device Settings tab. Under Installable Options, set the Paper Type to Receipt. Setting the paper type to Receipt will cause the pages to have a variable length.
While you're there you might set the Page Cut Type to No Cut and set the Document Cut Type to Partial Cut.
Works like a charm for me.
If you really want you can even add Access's favorite paper length to the list of paper sizes. To do that you need to go to My Computer > Control Panel > Printers and Faxes. The best way to go there is to use the Windows Explorer or something similar. Under the File menu in Windows Explorer you'll find an option Server Properties. The Print Server Properties Dialog Box is shown. On the Forms tab you'll see a Forms on: <ComputerName> list. Locate the Star paper size of e.g. 72 mm x 200 mm and select it in the list. Once you check the Create a new form check box you can give it a new name. I called mine 72 mm x Access and modified the paper height to the 22.75'' or 577.8 mm.
However, I ran some tests and it doesn't seem like this last step is really necessary. Even with the 72 mm x 200 mm paper size selected for my Access report I printed tickets that were 5,000 mm tall without any problem.
Hth,
Jan 28, 2010 | Star Manufacturing International Star...
Won't print at all
I have the same printer. It can be hooked to a network using an RJ-45 cable - which looks like a wide modular phone jack - or a USB cable.
It can be hooked up such that both cables are installed, but it is much better to pick one type of communications method and stick with that.
If you use USB, it is better, simply because you need to choose a network (IP) address for the printer.
Follow the installation guide, and don't plug in the USB cable until that step is called for by the install guide.
Best of all, you can also plug it into an earlier USB link, like 1.0 or 1.1 and, of course, 2.0.
I have mine plugged into an older computer which uses a 1.1 USB jack, and the communication is perfect, and prints without any problems.
So, I would say that you may have missed one simple step in the install procedure which, when remedied, will allow that printer to work like a charm. You will love the quality of the output, especially when you use a good quality photo paper, either glossy or matte.
Make certain you choose a paper specifically for a color laser jet printer. Color paper for an ink jet printer, when used on a laser jet printer, may cause unnecessary smearing of the image.
-a.
Nov 23, 2009 | HP Color LaserJet 2600n Printer
I want install windows98 with xp in a computer
HEllo,
if you know the installation of winxp and win98 then it is possible to create a system with mercury board with 98 and xp.
firstly you install win xp in your computer. it's automatically located in c drive. then you intall win 98 custom install and then choose the installation directory of another drive like d. you use any boot manager to boot the pc with win98 and winxp. i don't tell you the installation process step by step. so don't mind.
thanking you
ramesh
Nov 14, 2008 | Intel 865 S478 8X 10/100 Lan Motherboard
Installed with enclosed disc
Looking at the setup guide, it does indeed tell you to not connect the usb cable until prompted by the software. It is Step 7.
Here a link to the setup guide:
Kodak 5100 AIO Setup
Kodak Support has step-by-step instructions for uninstalling and reinstalling the software. Just make sure you remove the USB cable from the computer and reboot before you reinstall.
Here is the support page to begin on:
Kodak Support 5100 Reinstall
Comment back to let me know how it went.
Nov 13, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Problem installing drivers x5470 all-in-one
Hi, Try uninstalling all the software and unplug the printer and then restart your machine befoer trying to reinstall the printer. If using WinXP your PC should see the printer and then want to install the software. If you have the original instalation manual then follow it for a complete new install, as some printers require you to install the software before you plug in and turn on the printer.
Nov 07, 2007 | Lexmark X5470 All-In-One InkJet Printer
StarTech.com Star TSP143, USB, Future Print Printer Logo
181 people viewed this question
Top StarTech.com Office Equipment & Supplies Experts
jasbo
jasbo
Are you a StarTech.com Office Equipment and Supply Expert? Answer questions, earn points and help others
