Question about Oritron DAV3101 PROGRESSIVE SCAN DVD
Power supply board damaged by lightning would like to purchase another one
  • 10,594 Answers
Damage due to lightning would not be limited to power board only, in my opinion, other circuit board would have also been damaged so new home theater system would be good choice rather repairing this one.
Thanks.
Posted on May 27, 2011
I have a Samsung plasma tv that got struck by lightning and wont work. I replaced the power supply panel and it still wont come on. Do you know what else it could be.Could it be the actual power cord?
Chances of lightning damaging the power cord are slim to none, unfortunately it could be almost any board in the set, check the various power supply voltages on the boards and see if they are correct, almost every board has a power supply in it
Nov 09, 2017 | Samsung Televison & Video
Repair or Junk my Samsung UN55C6500VF TV?
Hi William,
Not necessary to junk your TV. Damages due to lightning are extensive at times but from what you have mentioned it appears that may be it is only the power supply board which has gone bad and rest of the TV is ok. Replacing power board may restore your TV.
Good Luck.
Aug 24, 2015 | Samsung Televison & Video
Vizio M420nv LCD TV Black Screen
lightning can do extensive damage to electronics equipment especially flat panel TV's. I would really recommend a professional diagnosis instead of board swapping. You could have several boards that are damaged!
Feb 13, 2013 | Vizio m420nv 42 in. LCD HDTV
Power surge caused by lightning strike, TV is dead, any Thoughtd/ does this damage every components?
Lightning can cause serious damage. You will surely want to get a professional diagnoses. What is damaged depends on where the surge came in at, and the intensity of the surge. If the surge came in through the power cable, most likely your power supply board has damage. But I have seen situations where the surge came in though an HDMI or coax connection and just take out the main board. But the moral of the story is to get a proper diagnoses, you could have several boards damaged.
Nov 24, 2012 | Astar LTV-2701 27 in. HD-Ready LCD...
Emerson TV Model #LC401EM2F Fix after lightning?
Lightning damage on LCD TV's can be a doozie. You really need to get it checked out by a qualified technician. I've repaired several TV's hit by lightning, most of the time the damage was limited to the power supply board. However, it is possible that multiple boards were damaged. If multiple boards were damaged, it's not worth repairing the set.
Jun 02, 2012 | LG Televison & Video
My desktop board is P5NSLI, suddenly when i'm working with it, a lightning splash because its raining, i turned off my computer 'cause i'm worried if what may happened, after the rain i get back to work...
This may have been due to power surge. Try replacing the power supply. Also, inspect the motherboard and other components for any physical damage. Motherboard may get damaged due to power fluctuations, which requires replacement.
CreativeTECH
Nov 23, 2010 | ASUS P5NSLI (0610839134670) Motherboard
Sanyo dp32648 possible lighting strike, whats needed to fix and a possible cost an can i repair myself?
It wont turn on? Well if it is damaged by lightning the only thing damaged would be the varactors on the power supply. They are there to absorb tremendous surge of electricity. The same way a surge protector works. A worse case scenario is the power supply board is fried up. Then being a non electronic technician you can purchase the whole board or order on line and install them yourself. If you brought it to a shop they will charged you for the labor and the board. Don't buy used boards on the internet because a lot of them are no good in my own experience. Get a new one for about a little over a hundred buck or so.
Jun 26, 2010 | Sanyo DP32648 32 in. LCD TV
My dell was hit by lightning and now i cant get it to boot up
hi there;
really,lightning has a great power voltages supply,thousand of volts was supplied in one strikes of lightning.this depend how much voltage was induces on your computer,mostly your avr and psu might be damage by checking if there is power determining the fans inside avr and psu if running maybe you have the power,and some led light are blinking ,some how to be sure you can use multi tester if you have knowledge on this.basic approach if you have black out screen and good power supply,pull out ide cable of hardisk and cd room from mother board,you can run pc w/o them to check your start windows if will open run your pc if still black screen,take another video card and memory card try to replace them and rn your pc,if windows open fine if not maybe you have damage the mother board from lightning.replacing defective devices can put back your windows open.best regards
Jul 24, 2009 | Dell Dimension 2400 PC Desktop
Televison & Video Logo
226 people viewed this question
Top Oritron Televison & Video Experts
jairo sanchez
 Grubhead
Grubhead
Mikee
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
