Question about Brother PT1880 - DELUXE HOME LABELER/TZ
White lever is down and I can not load Cartridge
  • Brother Master
  • 783 Answers
I Suggest You To Watch
To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On : Brother Printer Support
Posted on Jan 30, 2014
I need to change my toner cartridge, cant figure out how to get it out , Airborne
Hello
If you open the side cover on the right side of the machine then you will be able to open the front cover.The toner cartridge wil have a green lever if it is not broken off.lift the green lever gently.pull the lever to your side.(Out of the machine to the front). the toner botle is inside this cartridge.Now you wil be able to take it out.Make sure the top of the cartridge come out with the botle.If not it wil stil be in the cartridge. replace the toner botle in the cartridge and push it back in to the machine and push down the green lever,close the front door and the the side door.your machine should load toner to the pcu now.Good luck
Jun 13, 2011 | Gestetner DSm515pfd Digital Copier -...
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
Just need to know how to put in black ink in the z1300
Follow these steps on how to install the cartridge: 1. Make sure the printer is on. 2. Lift the access cover. The print cartridge carrier moves and stops at the loading position, unless the printer is busy. 3. Press down on the left cartridge carrier lever to raise the cartridge carrier lid. 4. Remove the used print cartridge(if you are replacing). Insert the new black cartridge in the left carrier. 5. Snap the lid closed.
3. Remove the used cartridge.
4. Load the new black cartridge. Close the cover.
Apr 29, 2011 | Lexmark Z1300 InkJet Photo Printer
How to change cartridge on Lexmark 2600 All in One Printer. How does the cartridge come in view so I can change it.
1. Make sure the All-In-One is on. 2. Lift the scanner unit until the scanner support keeps it open. The print cartridge carrier moves and stops at the loading position unless the All-In-One is busy.
3. Press down on the cartridge carrier levers. 4. Remove the old cartridges. 5. If you are installing new cartridges, remove the stickers and transparent tape from the bottom of the cartridges. 6. Insert the new cartridges. Make sure the black print cartridge is secure in the left carrier and the color cartridge is secure in the right carrier, and then close the carrier lid. 7. Lift the scanner unit and push the scanner support back while lowering the scanner unit until it is completely closed.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the cartridge carrier to the center of the printer. Remove the used cartridges. Load the new cartridges. Close the cover. Plug the printer back to the power source.
I hope this information has been helpful. Thanks.
Dec 02, 2010 | Lexmark X2500 All-In-One Printer
Where can i put lexmark ink?i can't see the place where should i put the new ink for lexkmark x2650
Make sure the Lexmark X2650 printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will move to the center automatically for the loading position.
Press the down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thanks.
Nov 06, 2010 | Lexmark X2650 All-In-One InkJet Printer
I would like to know how to install the cartridges for the x2650?
Make sure the printer is on. Lift the scanner unit to access the cartridge area. The cartridge carrier will automatically move to the center for the loading position.
Press down the carrier levers to open and remove the used cartridges. Load the new cartridges and close the cover. Close the scanner unit.
Oct 25, 2010 | Lexmark X2650 All-In-One InkJet Printer
HP 5550c Printer: install a toner cartridge and now the cartridge is jamed and unable to turn the toners as before. can not remove the cartridge.
The white plastic lever has broken and needs replacement. On the bottom left hand side bracket of the Transfer kit to it's left is a black plastic cover which pops off remove it and you will see a white plastic
lever which pivots on a bar with the transfer kit locking and unlocking the toner cartridges it often goes bad and tears. Hp should modify this and make this piece metal not plastic. You can manually pull and push down on the metal bar to lock unlock the toner cartridges for a temporary fix.
Mar 10, 2009 | HP Color LaserJet 5550hdn Printer
How do I change the ink cartridge in my Lexmark x2470
How to Install or Replace the Ink Cartridges in the Lexmark i3 ID: 810 This document does not apply directly to your Lexmark X2470
  1. Make sure that plain paper is loaded in the paper tray.
  2. Ensure that the power light is on.
  3. Open the cartridge door.
    The cartridge carrier may move slightly, and then return to the loading position.
  4. Push up on the cartridge lever.The cartridge holder springs open.
  5. Remove the old print cartridge and dispose of it.
  6. Remove the sticker and transparent tape from the new print cartridge.
    Warning! Do not touch the gold contact area on the print cartridge.
  7. Install the new print cartridge as illustrated below. Insert the cartridge into the carrier slot. Push the cartridge lever back to secure it under the cartridge hook. Press the cartridge lever down until it snaps into place.
    Insert the color cartridge in the front carrier slot.
    Insert the black cartridge in the back carrier slot.
  8. Close the cartridge door.
  9. On the PC, open the Lexmark i3 Solution Center and click Print Cartridges.
  10. Then click Print Cartridge Installation and follow the on-screen instructions to install the cartridges.
Please Rate the solution.
All the Best
Sammy
Sep 26, 2008 | Lexmark Office Equipment & Supplies
Hl 2040
You must have refilled the first (starter) cartridge or didn't reset the toner reset lever. There is a reset lever on the left side edge of the cartridge. Look at the left end of the cartidge (not the fill cap end) for a round white gear end and a white lever in a hal moon shaped slot. If you can see only the round white gear and the hlf moon is emty of a white lever, it's a non-restting starter. If you have two white spots we will be addressing the one in the half moon slot. The used cartidge will have the lever at the "3 O'clock" position. To reset the cartridge as new you must remove the two screws on that end cap and move the lever to the "11 O'clock" position. Put the scews back in and reinstall in the printer. The sweeper lever will turn in the machine and reset the toner count.
***Important For Brothers**
Make sure when refilling that ALL WASTE TONER is completely cleaned out of the cartridge before adding new toner to it. Brother re-uses its old waste toner and over time the toner hopper gets contaminated with paper dust and too much old toner inside causing them to fail. It you just add toner to the cartridge without thoughly cleaning out, you will soon have a bad cartridge again. You'll see it when dumping out the old as white specks in the toner. That's actually contamination from paper dust and talc from the paper.
Hope that helps you.
Jul 27, 2008 | Brother HL-2040 Laser Printer
Lexmark x3550
Changing print cartridges Changing print cartridges Removing a used print cartridge
  2. Lift the scanner unit.
  3. Press down on the cartridge carrier lever to raise the cartridge carrier lid.
  4. Remove the used print cartridge.
Note: If you are removing both cartridges, repeat step 3 and step 4 for the second cartridge. Installing print cartridges
  1. If you are installing new print cartridges, remove the sticker and tape from the back and bottom of the cartridges.
    cartridge_tape_remove_one_2.jpg Warning: Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
  2. Press down on the cartridge carrier levers to raise the cartridge carrier lids.
  3. Insert the black cartridge or the photo cartridge in the left carrier. Insert the color cartridge in the right carrier.
  4. Close the lids.
  5. Close the scanner unit, making sure to keep your hands out from underneath the scanner unit.
    scanner_unit_close_2.jpg The control panel display will prompt you to load paper and press button_select_0.jpg to print an alignment page.
    Note: The scanner unit must be closed to start a new scan, print, copy, or fax job.
Jul 22, 2008 | Lexmark X3550 All-In-One Printer
Brother PT1880 - DELUXE HOME LABELER/TZ Logo
35 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
