Question about Dell 1201MP Projector
My Dell 1201MP turns off after a few minutes of use with a blinking temperature light. I'm trying to get it open so I can check the fan and am having a problem. One corner, on the side next to the lens, it catches and will not come apart. I looked and it seems that there is a clip held in by a circular piece of plastic on the side. I suppose my question is twofold, then: One, what could be wrong with it and two, how do I get the case open without breaking it.
  • 624 Answers
SOURCE: Is there an easy way to open this monitor?
-Flip the LCD face down and remove the screws that hold the base in place. -looking at the top edge of the LCD monitor you should see a small notch on each end between the front bezel and the back cover. -Using a plastic tool or a flat blade screw driver insert the tip and gently pop the case open. -Work your way around the edge of the case. -Once the LCD monitor is open unplug the control panel connector from the right side and remove the front bezel. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Mar 08, 2007
  • 624 Answers
This is a duplicate post, click on the following link to go to the active posting: http://www.fixya.com/support/t128460-easy_way_open_monitor
  • 4 Answers
SOURCE: opening the case
I am repairing my E173FPc Dell Monitor and to take off the back cover you must look on edge of frame to the lcd and you will see little Pry Slots. Get a flat head or knife and stick it in there, then give it a twist and "snap!!"..continue along the frame at about 4 inches apart till the whole frame is off (but dont take the frame off just yet. lay the panel down on the LCD on a Towel or somthing soft, then unscrew the 4 phillips screws to the stand and remove. then pull the back off. Now on the sides of the tin you will see 4 more screws,...remove and lift but be carful you must unplug about 7 plugs before you can get to take out the circut board but that has screws also that need removing.(((seperate and label your screws)))) or (((take a few digital Photos as you go)))).. THATS IT.. I WILL POST PHOTOS SOON SOMEWHERE THAT GOOGLE WILL PICK UP LABLED DELL E173FPc LCD Monitor repair Blank screen blinking green light specific>
Posted on Sep 18, 2007
campus
  • 56 Answers
SOURCE: Can't open case
dell optiplex have very tight casings, dont be afraid to use force.
I have one myself and it is a struggle to get the casing off.
as long as those 2 side buttons are pushed in just give it a good tug and hopefully it should come off.
Posted on Dec 04, 2007
SOURCE: Dell latitude d600- won't boot up!!!
Try this. Press down hard on the f7 and f8 keys while trying to turn it on. Some if it does turn on then odds are that the solder joints on the bios chip (which is below the f7/f8 keys) are bad. You can try to touch it up yourself, but it is not an easy job.
As far as I can tell the d600/600m have this issue a lot.
Posted on Nov 17, 2008
TV turned off by itself one day. I pressed reset, timer light blinked green for a minute, then I pressed power and it sounded like it wanted to boot up, but nothing happened and the status light turn
Two thoughts:
First is this is a DLP set and the lamp may have failed
Second is it should have the self check which reads error codes---most of these sets that is the same:
" After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
(then release both)
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
This is for a earlier Mitsubishi DLP but should be the same as your set as Mitsubishi rarely changes things like this.
If you get the lamp abnormal it is likely your problem.
Dec 06, 2012 | Mitsubishi WD-Y65 65" HDTV
Wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
Oct 25, 2012 | Mitsubishi WD-60737 TV
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Tv doesnt show anything
Got (if model listed is correct) any blinking lights?
Set has a self check:
Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
May 29, 2012 | Mitsubishi WD65737 65" DLP TV
1201MP Projector in my daughter's classroom. The power button lights up the blue buttons on the top, but the lamp does not come on. We changed the bulb, same result. After a minute or so (we thought...
Clean the filters. Make sure that the vents are not blocked. fan are working? Make sure the lamp door is secured, Projector manufacturers will make the projector inoperable if the door isn't secured tightly. Reset the lamp timer. email me at info@allprojectorlamps.com if you need a manual.
Aug 17, 2010 | Dell 1201MP Projector
How do I know if the lcd projector lamp is bad?
  1. The unit will not come on
  2. The fan inside will constantly be running
  3. You would get a blinking light.
9 times out of ten its the lamp or the balast inside.
Please rate with postive rating Thanks for allowing me the oppertunity.
Oct 09, 2009 | Dell 1201MP Projector
I have a wd65100 when powered on i get steady orange light then status blinks red & green,unpluged for 1 hour tv is working but dark picture
Hi
This issue can be due to ballast fan, lamp or high temperature. However, to figure out this we'll need to check for the TV from inside(wiring & testing the components) or the other way is when the lights blink again then follow the procedure given. After you turn on the set, and get the red blinking lights, hold down the Device and Menu buttons together for about 5 seconds.
For example, 4 flashes, then 1 flash = 41.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 28, 2009 | Televison & Video
With necessary connections of my laptop with my dell projector 1201MP my laptop is unable to see my dell projector 1201MP
Try pressing the Fn + F8 keys on the laptop, once the projector is connected and powered on.
Mar 10, 2009 | Dell 1201MP Projector
Tv keeps turning off?
cutta, you will most often hear a click on boot then the fans start up and lamp will then fire. The picture will start to show up....at what point does it shut off? and do you hear a click when the tv is turning off? Is it the complete tv shutting down, fans and everything that turns off? Do you see any lights on the the front panel "POWER", "STATUS" or "LAMP", what are they doing? If you see a Power, Status or Lamp light after it shuts off the below are what they mean if there is an issue. POWER - STATUS - LAMP - CONDITION/ISSUE: Off - Yellow - Off - Temp. high/dirty filter/excess room temp Off - Off - Yellow - 4000 hrs. Lamp usage warning Off - Off - Blink Yellow - Lamp Cover open Off - Blink Yellow - Off - Air Filter Cover open Off - Off - Red - Lamp failure (failed to turn On or broken) Off - Blink Red - Off - Fan Has Stopped Off - Red - Off - Circuit failure (short) or DVI cable disconnected If you want to check for the last "Error Code", after you first turn the TV on, by pressing the front panel ?DEVICE? and ?MENU? buttons at the same time and holding them for 5 seconds, it activates the Error Code Mode. The ?Power LED Light? blinks/flashes (1/2 sec delay) and then flashes again denoting a two digit Error Code indicating no problem or an error has occured since the last Initalization. i.e. "Power light" blinks 3 times (1/2 second delay) and then blinks 4 times then 1 sec delay and repeats a few times. This would mean "Error 34 - Lamp abnormality". See below for error codes..... Error Code - Description or issue 12 - No Error detected, check Power Supply 32 - Lamp Cover is open 33 - Air Filter Cover is open 34 - Lamp abnormality 36 - Light Engine (DMD or LAMP Fan stopped) 37 - Exhaust or Lamp Ballast Fan stopped 38 - Lamp temperature high 39 - DMD temperature high 41 - Short is detected 44 - DVI cable between FMT & Engine disconnected. Sorry for the long answer but it was an open ended question.
Jul 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Dell 1201MP Projector Logo
104 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
