Question about IBM Netfinity 5100 8658 Server
Hi, ...j have a netfinity 5100 (type 8658 modell 61y), but it at the startup don't able the cd rom. If remove the ide cable it start...the eject button is active, but if reinsert the ide cable it not responde! Thank's for help
2 Suggested Answers
SOURCE: IBM Netfinity 5100 8658 Server Problem
Chang it to an alpha server, you are in US.
Posted on Sep 18, 2008
Netfinity 5000 bios password unknown - I got a IBM Netfinity 5000 for free from my schoo and they had a BIOS/Admin password set. The school hasn't used these computers for a long time so no one knows...
****. IBM just wants your money. In most cases, the bios password can be disabled by removing the CMOS battery. Remove the CMOS, pull out the power cord, and hold the power button for 10 seconds to drain any residual charge. Boot the computer without the CMOS and it should say password disabled. Turn it off, unplug it, and slap it back together. You should be fine. Let me know how it goes.
Aug 06, 2011 | IBM Netfinity 5000 61Y (865961Y) Server
Emachine ET1331G-03w Documentation
To install an IDE CD rom, you will need to open your computer and you will see an IDE Slot, your computer usually has two of them either directly next to each other or under each other, there is usually one white one and one blue one. IDE Slots look like this:
The white IDE Slot is usually for the Hard Disks and the blue IDE Slot id usually for the CD Roms.
The white IDE Slot is the Primary Slot and the blue is the secondary.
You will need an IDE cable to plug in to your blue IDE Slot then you will need to plug the cable in to your CD Rom and make sure that your CD Rom is set to run/work as the master. If your computer only has one IDE Slot or you do not have an extra IDE Cable you can plug the CD Rom in to the Primary IDE Slot with the Hard Disk assuming you are only using one Hard Disk.
If you are going to use the Primary IDE Slot you will need to make sure that your CD Rom is set to run/work as a slave and it must not be set as the master. The way to change it is by moving the pins at the back of the CD Rom, they are found at the back next to the place where you plug the IDE Cable in to or next to the power input. You will be able to tell if your CD Rom is set as a slave or as a master by checking the image on the top part of the CD Rom, this image will tell you how to set your CD Rom as a master or as a slave.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Jan 09, 2010 | E-Machines eMachines Desktop PC
I forgoot the password for the administrator bios of ibm netfinity 5100 is there any solutions
You need to temporarily remote the CMOS battery from the motherboard to reset the bootup password.
Dec 03, 2009 | IBM Netfinity 5100 8658 Server
Trying to boot from windows CD and not working
If its the full windows xp cd by booting it from the cd drive it will erase everything and ask if you want to upgrade or advanced install I think. Your correct in choosing the atapi cd-rom as 1st boot device. The cd should be in the drive on startup. IDE is the type of hard disk drive. I'm guessing the FDD stands for floppy disk drive which you might not have that many but you have that many bay windows available.
Put disk in, shut down computer, Start computer and it should give you the xp disk contents. Be aware of data loss though.
Nov 14, 2009 | Microsoft Windows XP Home Edition
Problem woth IBM netfinity 3000
You definitely should be able to boot from cd. I used to have a netfinity 3000 and regularly booted off cd. However, there are 2 possibilities here:
a. your cd-rom is faulty
b. your cd disc is seen not bootable
I would suggest checking whether you can boot from this cd disc on another machine-if so, I would try swappin cdrom in the netfinity.
Good luck,
Raf
Nov 08, 2009 | IBM Netfinity 3000 80U (847680U) Server
Aug 21, 2008 | IBM Netfinity 5100 8658 Server
Ide data interface connector problem
Hi Ryk,
I remember that I have suggested you to use three point IDE cable. But I don't know what type of cable you have purchased.
Anyway here is picture of the IDE cable which i was suggested.
915667e.gif I think it will help you in better ways.
I have suggested to connect the point, but you can use any combination which is comfirtable for you.
If any problem just Ask me
Thanks
Iqbal
Apr 11, 2008 | Computers & Internet
CD ROM TS-H192C/SH-C522C Gets off When Connected
Check that the power plug is getting both the +5v and +12v and there is not a fault with the power plug.
Oct 07, 2007 | Sony CDU5211/5221 Internal 52x CD-ROM...
Cd rom will not display on monitor
U must set jumper on you'r HDD and CD-ROM, so you have primary and slave IDE controlet, remove HDD and CD-ROM and set HDD jumper master and CD-ROM jumper on slave. If is posilbe use two IDE cables one for HDD and one for CD-ROM. Have luck.
Sep 08, 2007 | Computers & Internet
IBM starting problem.
Hi , if your dont have any data, try to get the IBM Netfinity CD for 4000r which supporting the OS 2003. Usually IBM provide a cd on each NEtfinity server. Check on the IBM website for more details about your Server Compatibility on 2003 server. then proceed to re-intalled the OS.
Aug 10, 2007 | IBM Netfinity 4000R 8652 Server
IBM Netfinity 5100 8658 Server Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
