Question about Toshiba Satellite L655-S5101 Laptop
I received a toshiba update. I did a diagnostic check. It states hard drive fail. Sometimes my laptop fans make a noice. What can I do?
  • 93 Answers
For starters you need to start backing up everything you want to keep. Photos, music, files, passwords, etc... Saving it all to an external hard drive is the simplest way to do this especially if you have a lot of stuff. You can also use thumb drives or burn it to DVD's if you want. Your computer is telling you that it's about to **** out on you. Once you get all your files backed up, you'll need a new (internal) hard drive for the computer. Once it's in, pop in your Windows install disc & follow the prompts. Keep in mind that you'll need to put in the windows disc before you shut the computer off to change the hard drive, this way after you've installed the hard drive and start back up, the windows installer will run.
Posted on May 27, 2011
Computer got into a permanent state after some windowns updates, it keep booting and comes to a screens saying:
From your description the hard drive has failed, have it tested before it is replaced. One tip remove hardware and reseat it back in place, sometimes this get it working.
Jun 10, 2012 | Toshiba Tecra A5 Notebook
Crackling noice on my laptop
Crackling or clacking? If it is continuous loud clacking, it might be your hard drive.
Sometimes you can hear the drive making noise which is normal because an update or something might be running in the background.
May 12, 2012 | Computers & Internet
Making noice like it wont start up and computer not reconicing it hte light goes on and off but power is going through it
Try using Seatools, a free diagnostic and repair utility which can be downloaded from Seagate. If the disc fails the tests it may also be able to automatically check your warranty and advise on return
Nov 18, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
My laptop is saying no hard drive and sometimes has a black screen I can't get the backup disk to work
Please remove and reseat the hard drive and also check if the hard drive has not failed, sometime the hard drive connector also fail..
Jun 09, 2010 | Toshiba Satellite A135-S4527 Notebook
Laptop gives no response after reboot/restart
how old is the laptop
if it has a disc hard drive it could be that the motor in the hard drive is failing
go into device manager and do a systems check
Apr 03, 2017 | Toshiba Computers & Internet
30days out of of warrentu dont figure. Issue:
hi there i have the dv8000 i put a 500 gig ide drive in mine and never got any problems you say that you have several (9) issues most of them stated Failed Devices do you mean drivers for laptop as thats all i think you need.
also any 2.5 hd should work..
if its drivers you can go to hp site
Oct 23, 2009 | HP Pavilion DV6700T Notebook PC
I have a toshiba p205d-s7436 when you turn the laptop on a black sceen reads toshiba leading innovation i tryed putting recovery discs in will not reboot tryed f12 and f2 it will not boot up PLEASE ANY...
The first step is to check the BIOS to see if your hard drive is listed. If so, is it set to be the first boot device. To enter the BIOS, use the F2 option when prompted.
If the hard drive is not present, it's either come loose, or the drive's controller has failed.
Also, if you can use the F12 option to boot to a CD/DVD drive, use another computer to download the Ultimate Boot CD iso from http://ultimatebootcd.com, and then burn it to a CD. This will create a bootable diagnostic CD that you can use to run diagnostics of your hard drive.
Let me know how this works for you.
Sincerely,
James O'Brien
Oct 04, 2009 | Toshiba Computers & Internet
Hi, my laptop is having problems starting up it loads up the the loading screen before u put your password in and it just stops there, i've tried a toshiba reboot to out of box state and it still doesn't...
If you hav ethe Toshiba reinstall disc, check to see if it has any kind of diagnostics loaded with it. Try starting the computer, and keep tapping the F2 key, this should load the setup BIOS screen. Go to the section in setup where you can change which boots first. Set it for the CDROM to boot first. Save the settings, and restart. Once the computer loads the disc first, look for hard drive diagnostic tools. run the diagnostics to check the hardware on the computer, it should tell you what is good, and what is not. If it is the hard drive that has failed, than that is an easy fix. The only hard part is having to shell out the cash for the new drive. Hard drives on laptops are easy to get to. They are under a door on the underside of the computer. There is probably a couple screws, and the hard drive compartment will open up. Just remove the old one, and plug in the new one. Hope this helps!
Jun 04, 2009 | Toshiba Satellite A200-0ET00X Notebook
Toshiba 5205-s503 won't start up
have you tried taking the new battery out and then booting it up? if it does boot up the new battery is not compatibly with the laptop.
Dec 16, 2008 | Toshiba Satellite 5205-S503 Notebook
Toshiba Satellite L655-S5101 Laptop Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
