On switching my Hp laseret 3800, after initializing, it will show red light and said "59.f0 error switch off and on to continue"
  • 48 Answers
1. Turn the printer off, and then turn the printer on. 2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train. 3. Check the main motor's cable to ensure that it is seated properly. 4. If the error persists, replace the main motor.
Posted on May 27, 2011
  • 91 Answers
Check on the optional paper tray if there is still a piece of orange tape , remove all orange tape from the printer , is it the first installation?
My printer is showing error 59.0F Hp laserjet cp 2025
see some articles below for similar errors.
It does not appear to be user fixable error unless it is that debris to be cleaned. Printer HP Laser Jet CP4525 59 F0 Printer Error
Apr 28, 2016 | Office Equipment & Supplies
What is the 59 co.error turn off turn on ? printer modle is hp 1215 colour laserjet pcl
I presume you are referring to the HP Model CP1215. The error 59.C0 error appears to refer to a mechanical error: Developer motor rotation error.
The recommended action is 1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize. 2. If the problem continues, contact HP Customer Support Center for technical assistance.
Your printer could be about 5 years old by now, so if this is a recurring problem you might be nearing the time for a replacement which might be less costly than taking your printer to be serviced.
You
Sep 09, 2014 | HP LaserJet CP1215 Color Printer
What is the 59 CO error?
59.C0 Developer motor rotation error
Sep 09, 2014 | HP CC377AABU Color Laserjet Cp1515n...
When i sand a test page the printer show an error 59.f0 what can i do
Pull the transfer unit out, and turn the white gear on the side. Not the one that turns the transfer belt--the one that causes the belt to push up against the toner cartridges. If the gear turns somewhat freely (it's not stuck), then reseat the transfer unit and see if the error goes away.
More comprehensive troubleshooting guide is here:
http://www.partsondemand.co.nz/uploads/97806/files/Feb_14_59.F0_error_Tech_Talk.pdf
But if it passes all the "checks" and you still have the error, check this out:
http://cincinnatiprinterrepair.com/hp-cp3525-59-f0
Apr 22, 2014 | HP CP3525N Color LaserJet Printer
I have a HP 44" Z3100 and after switching and saying "Initializing, please wait" it gives error 79-04 " Help needed urgently please!!!
Firmware issue:
1. Cancel all pending/que jobs
2. Disable nesting option
3. Dis connect data cable, restart the machine.. check...
4. Up load latest firmware.( read carefully read me file before up loading the firmware)
Jan 18, 2013 | HP DesignJet 1050c InkJet Printer
After paper jam, printer won't initialize
try to switch it off unplug leave for 15 min and switch back on.
Jun 30, 2012 | HP P2055DN LaserJet Monochrome Printer
Laserjet cp3525 error 59.f0
If it helps, I solved the error 59.F0 blowing on the sensors that are on the outer side (right door) under the edge of the transfer belt. You must remove the fuser and transfer. To locate the place to blow, craft and close the door stations toners, we see a long plastic slide guide in the machine with the door movement. Must blow into the small holes that are filled with dust with compressed dry air.
Good luck.
Jan 09, 2012 | HP CP3525N Color LaserJet Printer
HP Color LaserJet CP352dn 59.fo error
59.F0 ERROR
The primary transfer-alienation motor has experienced an error.
1. Check to ensure the ITB is installed correctly.
2. Run a sensor test to verify that the primary transfer disengagement roller is functioning. If not replace the sensor (SR17).
3. Run the primary transfer drive test in actuator drive mode. If not functioning replace the ITB (Intermediate transfer belt).
Jul 27, 2011 | HP Laserjet Cp2025n Printer
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
151 people viewed this question
jasbo
jasbo
