Question about Brother MFC 7300C InkJet Printer
Error 33 on my brother 7300c what does it mean
What does error code 20 mean when printting
take the paper towel and add 20 weight oil to clean crap off the carriage then try again
Apr 21, 2015 | Brother MFC 7300C InkJet Printer
Hi, I lost my manual for my Brother PS-33 (16
I went to the Brother site, (link below) follow the directions and insert relative information to receive information from the manufacturer.
http://www.brother-usa.com/manuals/default.aspx?PGID=3
Hope it helps, good luck
Joe
Aug 29, 2011 | Brother PS-1250 Pacesetter
Have error code 33 on dash what does it mean 08 model r1
Error Code 33 means that there is problem an
Open circuit detected in the
primary lead of the cylinder-
#1 ignition coil.
• Open circuit in wire harness.
• Malfunction in ignition coil.
• Malfunction in ECU.
Hope this helps
Mar 02, 2010 | 2008 Yamaha YZF-R1
I have a brothers mfc 9200c and it shows me error 33. What is this
Check your owners manual or users guide. It may be available for download from Brother, check the portion of the page for the country or region that the printer was purchased in.
There is some information about error 33 in the FAQ section of the site for the MFC 5100, check if it applies to your product. It seems to have something to do with the motion of the print heads.
Good Luck!
Feb 05, 2010 | Brother Office Equipment & Supplies
Will not print
 ARE YOU USING BROTHER INK??? I MEAN BROTHER OEM INK.? WHAT YOU CAN TRY IS TAKE A PAPER CLIP AND INSERT IT ABOUT 1/4 OF INCH INTO THE AIR HOLE ON THE CARTRIDGE, SOUNDS LIKE WHEN THE SEAL WAS TAKEN OFF, THE ADHESIVE FROM THE SEAL STAYED ON THE CARTRIDGE BLOCKING THE HOLDE. GOOD LUCK SR BROTHER TECH
Dec 01, 2008 | Brother MFC 7300C InkJet Printer
MFC 7300C
IT SOUNFDS LIKE THERE IS SOMETHING IN THE WAY OF THE PAPER PATH THAT IS CATCHINH THE CORNER OF THE PAPER, WHAT WE USUALLY DO IS TAKE A 8X10 FILE FOLDER AND MANUALY PUSH IT THRU THE PAPER PATHE TO SEE IF ANYTHING IS IN SIDE THEN REPLUG THE MACHINE AND SEE WHAT HAPPENS, GOOD LUCK BROTHER SR TECH
Nov 06, 2008 | Brother MFC 7300C InkJet Printer
Fax machine isn't recognized by other fax machines
Are you trying to send from a DSL or any other kind of digital line?
Oct 05, 2008 | Office Equipment & Supplies
Scanning with the brother mfc 7300c
FIRST OF ALL YOU WILL NEED TO INSTALL THE BROTHER MFC SUITES CD THAT CAME WITH YOUR MACHINE, WHEN YOU HAVE DONE THE INSTALLATION, BRING UO THE PROGRAM PAPER PORT OF YOUR MONITOR, PUT THE COPY THAT YOU WANT SCAN ON THE FLAT BED, IN THE UPPER LEFT HAND YOU WILL SEE PHOTO OR TEXT CLICK WHICH EVER YOU ARE SCANNING, NOW CLICK SCAN ANOTHER SCREE WILL COME UP AND ASK YOU IF YOU ARE USING THE FKAT BED( THE GLASS OR THE DOCUMENT FEEDER. CLICK THAT, NEXT TELL IT AGAIN PHOTO OR TEXT OR WHAT EVER THEN CLICK SCAN, ON THE SCREEN YOU WILL SEE THE SCANNING TAKING PLACE, THEN YOU WILL SEE THE SCANNED ITEM  EITHER IN MY DOCUMENTS OR MY PICTYRES DEPENDING WHERE YOU TOLD YOUR COMPUTER TO PUT THEM HOPE THIS HELPS, GOOD LUCK BROTHER SR TECH
Nov 13, 2007 | Brother MFC 7300C InkJet Printer
Printing Problem
SOUNDS LIKE YOU ARE REFILLING YOUR OWN CART. THEY DO NOT WORK WITH BROTHER MACHINE, THE BROTHER MACGHINES ARE SET TO WORK WITH OEM PRODUCTS, CHANGE YOUR INK GOOD LUCK BROTHER TECH
Jan 24, 2007 | Brother MFC 7300C InkJet Printer
Printhead
TRUST ME , IF YOU HAVE NEVER PUT A PRINT HEAD IN YOU ARE IN DEEP S--T. MAYBE THE SERVICE CENTER OR WHO EVER SOLD THE PRINT HEAD TO YOU WILL DOWN LOAD THE INSTRUCTION SHEET. MAYBEEEEEEEEEEEEEEEEEEEEEEE THEY WILL DO IT I DO NOT KNOW AS THIS PRIORITY INFO, GOOD LUCK BROTHER SR TECH
Aug 29, 2006 | Brother MFC 7300C InkJet Printer
Brother MFC 7300C InkJet Printer Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
