Question about Panasonic Lumix DMC-TZ50 Digital Camera
HI! I have a one year old Lumix DMC-FS15 that I barely used for some personal photos, I bought a 4 GB SDHC memory card with it, it used to work just fine but now whenever I turn o the camera I message saying that the pictures will be saved on built in memory. Any solutions? is it the memory card or the camera itself? the memory card works well on my PC. thanks!
    Scholar:
  • 59 Answers
If the memory card works on your pc, chances are it is fine.
So you have two things to do : first backup on your computer any picture on your card.
Secondly put it back in the camera, go into the menu and find where to Format the card.
Once the card is formated by the camera try to take a picture to see if the problem is solved. If not, look through your camera menu, certainly under "memory setting" or something similar, then you will have an option to choose on wich memeory the pictures are recorded: the internal one or the card.
Make sure your 4gb card is selected. This shoul solve the issue.
Hope this helps.
Posted on May 27, 2011
I have a Panasonic Lumix DMC-FS15 when I switch on it says "built in memory card full" even though I have a 4GB memory card in the camera which is not full. The camera doesn't seem to detect...
Hi, Move the internal pictures to your card and then switch it to record to the card...
Here is a tip that may help you with your problem.... I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer...
The process for your camera may not be exactly the same, but should be similar.
How toTransfer Internal Camera Memory Pictures heatman101
Aug 26, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
When pictures are taken they are being stored on the camera. They do not go to the SD card.
You need to get rid of the pictures in the internal memory. If you want to save any of them, go into the menu and find "copy". You will find the option to copy them to a memory card. Then, with no card in the camera, go into the menu and find "format"....follow the on-screen instructions to erase the internal memory. Then your card should work properly.
Dec 28, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
How big a memory card can you put in a DMC-FZ20 camera? I just got an 8 GB card and get "Memory Card Error" all the time.The old 256 MB card works fine.
An 8GB card is not SD, but SDHC (High Capacity). SDHC cards fit the same slot as SD cards, but they are slightly different and many cameras do not work with them.
I have a DMC-FZ20 myself, and use a 1GB card. That is really plenty of space. If you want more (going on holiday?) then just carry a couple of spares. The manual doesn't mention memory cards larger than 1GB. Probably there weren't any when it was written.
Dec 05, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
Cannot format a maxwell class 2 4 gb card for my lumix dmc-lc33
The DMC-LC33 is designed to work with SD cards. Your 4GB card is actually an SDHC (Secure Digital High Capacity) card. While it fits into the slot it will not work. You need to use SD cards, 2GB and smaller.
Aug 24, 2010 | Panasonic Lumix DMC-LC20 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
I just bought the Lumix DMC-ZR1 (yesterday April 3rd) When I put the memory card in, and it's blank, the camera reads that the memory card is full....how can I fix it??
In the instruction manual - see links below
  • It says DO NOT format on PC - you need to format in camera - have you done this? on Page 29 of the Manual http://panasonic.com.au/content/library/files/F002413.pdf
About cards that can be used in this unit You can use an SD Memory Card and SDHC Memory Card. •When the term card is used in these operating instructions this refers to the following types of Memory Cards. – SD Memory Card (8 MB to 2 GB) – SDHC Memory Card (4 GB to 32 GB) More specific information about memory cards that can be used with this unit. • You can only use an SDHC Memory Card if using cards with 4 GB or more capacity. • A 4 GB (or more) Memory Card without an SDHC logo is not based on the SD Standard and will not work in this product.
This is the instructions for the ZR1/ZX1 model http://panasonic.jp/support/global/cs/mpi/dsc/zx1/menu01.html
A number of manuals available from this site http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-ZR1K
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 04, 2010 | Panasonic Lumix DMC-ZR1 / DMC-ZX1 Digital...
Panasonic lumix DMC fs15 memory card parameter error
Has this card worked before in your camera?
If so, have you formatted it on a PC by any chance?
Try to format the card in camera, this should help. If it still doesn't work then the card might be damaged (unlikely but possible).
Good luck,
Raf
Oct 22, 2009 | Panasonic Lumix DMC-FZ28 Digital Camera
Is lumix dmc-fx33 compatible with sandisk ultraII 8gb sdhc cards?
No, 8 GB is too large. According to page 5 of the manual, 4 GB is maximum:
– SDHC Memory Card (4 GB)
–MultiMediaCard (still pictures only)
• A 4 GB Memory Card without an SDHC
The manual can be had below:
http://service.us.panasonic.com/OPERMANPDF/DMCFX33.pdf
Oct 05, 2009 | Cameras
Update to 8 gig card
try to use lesser memory cards like 4 GB or 2 GB
Dec 17, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Panasonic Lumix DMC-TZ50 Digital Camera Logo
113 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
