Question about Mitsubishi VS-50605 50" Rear Projection Television
VS-5061 -- BLACK SCREEN
While watching TV last night screen suddenly went comletely black. TV is avout 13 or so years old and I've had it serviced once to replace a video module?
  • Joe E Sep 09, 2008
    Screen intermiitnetly goes black. If I turn it off for a bit, returns just fine. Getting audio but no video.
  • 927 Answers
Good Day, petterk;
Try resetting TV by unplugging from the A/C outlet for3 to5 minutes. This a 1994 Model, you can't new boards from Mit's. Try this:
1). CHECK FOR 1200 VDC AT PIN 1 OF CONNECTOR "DK". IF LOW OR MISSING CHECK R5D9 100 OHM 1/2 OFF PIN 1 OF THE FLYBACK ON THE MAIN PCB. 2). CHECK IC401 PIN 8 FOR 28 VDC IF MISSING CHECK R510 1.2 OHM 1/2 W OFF PIN 5 OF THE FLYBACK. IF OPEN IC401 PART # 272P239050 MAY BE SHORTED. BOTH ARE ON THE MAIN PCB. 3). CHECK FOR SHORTED OR LEAKY Q2H0, IF BAD APPLY FOLLOWING CIRCUIT CHANGE TO CORRECT. ON FOIL SIDE OF PCB-SIGNAL, SOLDER A 1S2471 DIODE CATHODE TO BASE OF Q2H0 AND ANODE TO EMITTER. LOCATED ON PCB-SIGNAL AT IC201 PIN 2. PT # 264P045040 AND REPLACE Q2H0 PART # 260P559030. 4). CHECK C2H1 100 UFD 35 V C2H2 1 UFD 50 V AND C2H3 47 UFD 35 V OFF OF Q2H1 IN THE SPOT KILLER CIRCUIT ON THE SIGNAL PCB. Good Luck, big IRISH. PS: or call for service, Cost average repair about $500.00, you do the math maybe it's time for a new TV. G.L.
Posted on Aug 30, 2008
Good morning Sam. Last night while watching TV the
Hello Andrew, Could I get you to please post the model number and make of the set. I will be better able to assist you.
Dec 03, 2011 | Samsung 56" Slim-Depth LED DLP HDTV
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Watching rear projection tv. A flash and picture went away(Black screen) can still hear program. Is there an easy fix. tv is 13 years old
we have a sony rear projection tv and the picture went but sound is still there. Can you give me an idea what it might be.
Aug 13, 2008 | Sony KP-51HW40 51" Rear Projection...
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi vs 5043
I turned the set on and everything was fine, then the screen went black and mullti-colored horizontal (arched) lines were flashing across the screen. The next day I turned the set on and everything was fine for about 5 minutes then the problem reoccures again. Haven't looked for solutions till now.
Apr 06, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
Sony KF-50WE610
the color drive is going bad check with the sony service center it might be cover and repaired free.  my set went blue and the service tech is checking if it is covered.  good luck.
Sep 30, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
HELP! Fire Hazzard!
It sounds like your focus/screen block, the flyback transformer, or maybe a CRT anode lead is leaking high voltage. This could be a serious problem, or could be a simple one. You should not attempt this repair unless you know all of the high voltage safety issues involved with this TV set. Good Luck
Jun 20, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Mitsubishi VS-50605 50" Rear Projection Television Logo
160 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
