I have a pda hp hx2110 and i can not turn it on anymore i bought a new batter but still no result is there something else i can do
    Master:
  • 377 Answers
It is better to check the switch button of your unit, it could be defective or faulty now.
Posted on Aug 16, 2008
My ipaq 214 wont boot up. it just freezes on the HP screen. Ive tried pressing the reset button like over 100 times but it just freezes again. Ive also tried hard reset and that dosent work either. I have...
You could have a corrupted program on your PDA. You need to contact HP and have them re-flash or upgrade the firmware of your PDA and it should work much better than before.
Have a great day!
Oct 11, 2009 | HP iPAQ 214 Pocket PC
Touchscreen problems (HP RX or HX series)
If I understand correctly your problem, the touch screen of your PDA is not working.
Well, this is a common IPAQ failure. When happens, the only options to repair it are:
1. Soft reset of the PDA. If still does not work, then go to next step.
2. Replace the top digitizer glass.
It requires a very skillful person to do it. If you have not experience with fixing electronic devices, then I do suggest you to send it to repair.
Besides that is necessary to open it, you will require a soldering iron, and desolder the digitizer part and remove it from the LCD screen, which if is not done properly with the right tools, it's easy to damage the LCD screen assembly.
Also, if it's not opened right, is possible to damage permanently the mainboard if is bent or warped.
Also, even though there are a lot of cheap digitizer replacement parts on-line (mainly from China), they have a compatibility issue that prevents to use them in the RX3715 (or RX3115) PDAs.
I have nothing against Chinese manufactured parts, but after buy around 10 digitizers in the last couple of years for different Ipaq PDAs, I found out that only 3 worked fine, so I know what I am talking about.
Best regards,
May 25, 2009 | HP iPAQ HX2110 Pocket PC
HELP!!!
I think the battery may be fully dead, test it with a meter, and if it wont charge through the device, take it out, find a charger with a similar output and jam the wires into the correct terminals on the battery (+to+) it'll get red hot but you need only do it once. (I've done it to my psp battery and it worked fine) careful though, don't leave it on overnight or unattended.
May 03, 2008 | HP iPAQ HX2110 Pocket PC
IPAQ hx 2110
does it matter if usb charging is enabled? just looked through the menus and it has a slow/fast charge option etc?
Dec 22, 2007 | HP iPAQ HX2110 Pocket PC
H1910
GO TO http://www.pdastreet.com/forums/forumdisplay.php?s=&forumid=12 OR PDA STREET. THAT IS THE BEST SITE FOR ALL PDA ISSUES!
Nov 13, 2007 | HP iPAQ H1910 Pocket PC
Toshiba e755 pda
Hello I'm sorry to say but this looks like a corrupted ROM issue. The ROM memory stores your operating system and some parts of the firmware. If it becomes corrupted (various reasons) the PDA can't boot up the operating system, resulting in the strage situation you are experiencing. You can't connect it via active sync because it can't be detected as it can't boot anymore. It is very weird that this occured because of running an oficial upgrade. This leads me to suspect that there is something phisically rong with the wi-fi module on the pda's mainboard. You will need to take it to a service center to have it examined first. They will also put a specially made bootable sd card to reinstall the operating system is a way similar with computer windows instalation by booting from a cd. Most logically the wi-fi module has a problem and when trying to acces it by rewriting it's firmware (part of ROM) this resulted in the corruption of some ROM sectors. I'm sorry that this isn't a do-it-yourself type of fix, but it would be safest to ask a service center to examine your PDA's mainboard.
Mar 15, 2007 | Toshiba e755 Pocket PC
HP HX2110 wireless connection
nstall new ROM from this page ==== http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/download/22776.htm l and all will be OK !!!
Sep 11, 2005 | HP iPAQ HX2110 Pocket PC
Reinstallation of app onto iPAQ upon hard reset
In activesync under Tools/Add REmove programs you can check the box and click "ok" that will install the program. For the most part it's best to do it one program at a time. Obviously your PDA should be cradled or this. Most programs will re-install fine this way. Some programs though do require you to re-install from the installtion program directly since active sync doesn't pick up some important parts of the program. The two programs I have that require the special install are: CLC Journal since it has an outlook component and sets up a sync for the Outlook Journal. The Stowaway Keyboard driver since it had to ask me what language (the new driver doesn't do this...) The other 30 odd programs I have install straight from active sync.
Gps?
there are many,many options. I have the IPAQ Navigation System with my 4700 which I like.
Sep 08, 2005 | HP iPAQ HX2110 Pocket PC
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
