I have a dru fireplace model richelieu, it was lit now for some reason the pilot is out i tried to re light according to the instructions provided here but the pilot seems to go out when i let go of the button that looks like a star, havent had a problem before
    Brigadier General:
  • 4,736 Answers
From what you have described, the problem can be related to three things: The pilot needs cleaning or the Thermocouple has failed. Or, you're not holding the gas control valve in long enough for the thermocouple to properly heat up. It usually requires at least 1 minute.
To clean the pilot all you need is a can of compressed air with a straw nozzle (like you clean your computer with) to blowout the pilot tip opening.
If none of the above solves the problem, then it's definitely a failed Thermocouple. Or your particular burner may use a Thermopile or Thermogenerator. Whichever it is, they all serve the same purpose. Which is allow the gas to flow to the pilot when it's lit or stop the flow if the pilot goes out unexpectedly.
Hope this helps you to troubleshoot and solve the problem. Please let me know. Thanks.
Posted on May 27, 2011
Procom pilot light wont light
Make sure the gas valve is on. The thermocouple may need to be cleaned in order for the pilot to stay lit.
Nov 26, 2013 | Procom Heating & Cooling
I also have a gas fireplace by DRU (Richeleiu). I accidentally turned the pilot flame off, but don't know how to get it ignited again. I tried the spark igniter and there is a spark, but nothing lights. I...
You need to push the gas supply knob inwards and HOLD it while lighting the ignitor.
Once lit keep holding for 15 seconds and release.
The gas thermo switch needs to warm up first before it will allow a constant flow of gas. Also called the gas fail save device.
Oct 23, 2013 | Heating & Cooling
Pilot light 5301
The Skytech 5301 does not control your pilot light. That is a function of your fireplace's valve. Complete instructions for lighting your pilot can be found in the owner's manual of your fireplace, or at the brand's website.
The 5301 should not need to be reset in any way. Once your pilot is re-lit it will operate normally.
If you need a new copy of the 5301 manual, it can be found at the bottom of the product page here: Skytech 5301 fireplace remote.
Mar 16, 2013 | Skytech 5301 Fireplace Remote Touch Screen...
Have winrich perfecta ventfree lp model 6380. Very hard to start. Ignition switch never worked correctly. Pilot and ods showing corrosion. Doesn't stay lit very long. Can I replace the pilot/ods a
First clean out pilot light with can of air , or blow down it with a tude.
Then brush electrode clean with a clean paint brush ,chech to see if electrode is in the right postion to light the gas not too far away and the spark is strong , Clean thermopile head if fitted, then check thermocuople /thermopile connections are tight . see if this helps .
Oct 28, 2012 | Heating & Cooling
When we built our home 6 years ago, Airtron installed a Majestic NVBR36RN vented fireplace system. We had to turn our gas off a while back and never thought about the fireplace until now when we wanted to...
It has a panel hidden under the white fiber hearth bricks at the front bottom of the unit. you need to clean the lava rock off of them, pull both of them up, and then you will see the hidden linear cover that allows you to access the valve and light.
Dec 02, 2010 | Heating & Cooling
Intertherm gas fireplace, model BDM 35, pilot goes out
could be thermocuple or pilot blocked clean pilot then try make sure you are turning to on and not back to off i was doing this the other day some go clockwise some anticlockwise
Jan 02, 2010 | Heating & Cooling
DRU fireplace, Model Richelieu Can't figure out how to start, which buttons and knops to turn, gas on, can see the starter sparking, pilot won't egnite. In a house I just purchased
Turn the gas knob to the PILOT position
Press down and hold whilst lighting the pilot
When the flame holds on its own turn the knob to the ON position. Then turn on the wall thermostat or whatever you have to control the fireplace.
Dec 17, 2009 | Washing Machines
Problem lighting gas fireplace
my fireplace lights up for a short time and goes out after 5 or 10 minutes, please help with this problem.
Dec 08, 2009 | Heating & Cooling
Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
Dec 27, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
518 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
