Question about Gateway P-6831FX Notebook
Monitor only works in safe mode, how can I do a recovery in safe mode. Recovery in a partition
    Sergeant:
    Champion:
  • 217 Answers
When you turn the computer on instead of hitting F8 to get into safe mode hit F11 to begin recovery from the recovery partition. (as soon as the computer begins to boot up)
Posted on May 27, 2011
    Scholar:
  • 59 Answers
If your monitor only works in safe mode, try to reinstall your video card driver while in safe mode.
Hope this helps.
\windows\system32\kdcom.dll Missing or corrupt Kernel debugger
Try tapping F8 at bootup to enter safe mode, read your manual to see if you have a recovery partition on your HDD. You didn't post the model so I have no clue.
If you can enter safe mode you need to try system restore, not last good know configuration.
If you see last know config on your screen, then you should also see safe mode.
So you need to run in safe mode, and run system restore, or run the recovery mode if you have a recovery partition on the HDD.
If none of these work, then you only have three options, go to Avira.com, download the rescue disk, burn it to a CD and run it in DOS, this is before windows boots. Now if malware corrupted the DLL, Avira will kill it, but there is a chance it can't clean it and will destroy the files,DLL, and windows won't boot. So now you have to do below.
The other option is you need to download windows, what ever version you have, if you have win 7 home 32bit, then you have to download it, and burn it to a DVD. Then try a repair, if a repair does not work then you need to reinstall windows, and then install all the drivers like, (chipset, video, sound, lan, wifi)
This option, you can contact Acer and see if they have a recovery disk for you.
Good luck.
Apr 01, 2013 | Computers & Internet
Operating system not found.
Now, this is a real embarassing fact of Sony computers. The error can occur even in out of box peice. Reset BIOS to default values, check if the computer is booting to Windows in safe mode and restore if yes. You can acess the safe mode by pressing the F8 key. If the issue persists, perform a system recovery using the recovery partition. You can acess the recovery partition by pressing the F10 key at startup. Selcet the Restore C drive option top recovery computer to its factory settings. If you want to backup and important data from the hard disk, use the rescue data feature option from the VAIO Care recovery partition. I could provide you with a more precise and direct article link if provided with the exact operating system and model # information.
Jun 08, 2011 | Sony VAIO Notebook
Unable to boot even with safe mode, safe mode with networking, safe mode with command prumpt and start windows normally
check your memory 1st by taking 1 out and restarting with only 1 in, if not put it back in and try the other 1, if not you might have to try reinstalling windows if you dont have a recovery partition installed. if so at start up click system recovery might be f10 key
May 24, 2011 | ASUS Eee 4G Notebook
How can I access the recovery partition on the hard drive? (note: F8 does not work and 0 does not work, but the partition exists)
I've found that the way to access the recovery partition on Toshiba's changes very frequently between different models and different years. If you have a partition the best solution would be to boot into Windows and create recovery discs with Toshiba's recovery utility, so if for some reason in the future something happens you have the discs. I believe you can use that same utility within Windows to restore your computer. If for some reason you can't log into normal mode, you can try doing this in safe mode. If Windows doesn't seem to work at all, I will need the model number and I will try to do a little research. Hope this helps!
Mar 26, 2011 | Toshiba Computers & Internet
My sony vaio laptop is always hang 5 to 7 mins. but mouse pointer is still moving. all application im working are stuck a few minutes. what are the possible solution for this problem. i do reformat but...
Please backup the data by logging in to Safe Mode, please restart and start pressing F8 key to select Safe Mode then re-install the Windows 7 Operating System using the Recovery Disc or recovery Partition of the Hard Drive. The Recovery Partition can be accessed by restarting the computer and try pressing F10 Key. The Windows XP Operating System is displaying an error because it does not have SATA Driver to detect the Hard Drive. As Windows 7 has it, you can re-install it from recovery partition.
Mar 24, 2011 | Sony VAIO (PCWA-A200)
Key note book vaio cr failed to start because some recent hardware or software change might have screwed it up, any way to solve ? Without a windows installation disc?
Hi kevin_yomama,
This issue may occur due to any Software or Hardware changes in the Computer. Restoring the Computer to an earlier date when the Computer was working correctly should fix the issue. However, it is required to restore the Computer in the Safe Mode.
Please restart the Computer, press and hold the F8 key to access the Safe Mode. Once you are there in Safe Mode, please click All Programs, Accessores, System Tools and System Restore. This will open the System Restore window, there, please select a date when the Computer was working correctly. Performing the System Restore to an earlier date should fix the issue.
If the issue still perists even after performing the System Restore in the Computer, you will need to perform the System Recovery in the Computer. Your Computer is shipped with a recovery partition which is present in the hidden part of the Hard Drive. You can use the Recovery Partition to re-install the Operating System in the Computer. Performing the System Recovery using the Recovery Partition will erase all the User Data in the Computer.
To access the Recovery Partition, please restart the Computer, press and hold the F10 Key. This will boot the Computer to an Edit Boot Options screen, please press the Enter Key there. This will launch the VAIO Recovery Center. Please select the "Restore C: Drive" option at the VAIO Recovery Center to perform the System Recovery. Performing the System Recovery will re-install the pre-installed Operating System, Drivers and Applications to restore the Computer to the factory settings.
Good Luck!
Please let me know if you have any further questions or require any further assistance.
Thank you for using FixYa.
Dec 15, 2010 | Sony VAIO VGN-CR220E/P Notebook
1.Try restarting the computer in safe mode, keep tapping the F8 key as soon as you restart the computer and then from the advance boot options select the safe mode option to boot the computer to safe mode.
2. If the computer boots to safe mode perform a system restore.
3. If issue persists, reset the BIOS to defaults and then try again.
4. Verify if the hard is detected and listed in the BIOS setup. (press F2 at startup to enter BIOS).
5. If hard drive is detected and listed with its capacity such as 300/5oo GB, then, perform system recovery using the F10 recovery partition.
6. Restart the computer and start tapping the F10 key immediately to enter the system recovery partition, then, select the Rescue data option to backup the data from computer if any available or select the restore C drive option to perform system recovery and restore computer to factory settings.
You can also perform a memory diagnostics before performing the recovery.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C1000582
If the hard drive is not listed in BIOS with its capacity, contact Sony service team to get the hard drive replaced.
If the computer is brand new, you can try exchanging the notebook with a new one.
Nov 09, 2010 | Sony VAIO Notebook
After rcovery keeps trying to reboot
Is it a recovery (from a recovery partition) you did or you installed from DVD or CD?
If from latter--cd or dvd...then reinstall or have the cd burned at a lower speed.
Dec 18, 2009 | Microsoft Windows XP Professional
How to get to recovery partition when booting up HP Pavillion MX
The same problem happened to me today on my hp Pavillion a1600n.
Try pressing the F10 key as the computer is powering on. This may allow the computer to access the recovery partition on the hard disk. If you get that far, then you can restore the user partition from the recovery partition. If it is like the a1600n, then you can do a restore of all the content and either leave your own data files intact, or, have it reformat the user partition and then you WILL have to restore all the data files. In either case, you will likely need to reinstall any applications that were added AFTER you got the PC. (Or, in my case, some apps were still kinda working...).
If F10 does not work, you may be able to create a PC Recovery Tools CD from a different hp XP machine, and boot that CD. During part of that boot up process you may get the opportunity to run the Recovery program.
Hope that helps!
Apr 19, 2009 | HP Computers & Internet
Screen goes blank after windows loads
Hi there
If you tried in safe mode and still no joy you will have to perform a system recovery with the recovery disk you got with the laptop or the recovery partition, Please be aware that you will loose data.
Good luck
Jan 19, 2009 | HP Compaq Presario V2000 Notebook
Gateway P-6831FX Notebook Logo
185 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
