Question about Pioneer CDJ-800 Turntable
Round lcd? The main Lcd screen on my Cdj-800 works perfectly but the round Lcd screen in the middle of the turntable is out. Although when I accidentally bumped my cdj once the lcd turn back on and work perfectly untill I turned it back on the next time...
  • Anonymous Feb 28, 2009
    i have dropped the dek and now the cds want play and the lcd light in the middle isnt working and the que button is stuck in
Unfortinetly i cant recommend to you a quick fix or a quick check as the fault seems to be intermittent,
i would suggest taking the player to your cdj pioneer dealer.
email: info@audiovisualservices.info for all your dj equipment repairs.
Thanks.
Posted on Oct 02, 2008
Not reading cd's
First clean the laser head with a Qtip and alcohol. It gotta be perfectly clean, so wipe with fresh brand name qtip and make sure there is not a single dust particle on it. You gotta remove the cabinet with star screwdriver. Your beam might be tired. First try with the clean up! You can get a replacement unit, here http://1200s.com/Store/PARTS-PIONEER-CDJ-800/c271_461_491/p320015/Pioneer_-_CDJ800_CD_Mechanism_w/Pick-up_Assembly/product_info.html
You might want to bring this to a pro sound shop for repair. I'd order the part by myself and bring everything at the repair shop...
Oct 10, 2009 | Pioneer CDJ-800 Turntable
Hi I have a Pioneer cdj 800 mk1 and the cue button is stuck
i had my decks fixed by these guys they are in london.
thier websites is www.technics1210repair.co.uk
they do PIONNER CDJ REPAIRS AND SERVICING
check them out.
im only spreading the word due it i had my decks fixed their and i am so pleased im telling everyone so they can get the same service i did, rather than paying over the odds at some **** toster repair shop.
alan
Sep 28, 2009 | Pioneer CDJ-800 Turntable
Cdj 800 mk1 error code 83 02...no movement from deck at all. same discs worked perfectly 2 days ago...they work fine on my sl dz 1200
Chances are you have a defective laser mechism assembly as the error your getting is a focus and tracking error from the assembly
Sep 16, 2009 | Pioneer CDJ-800 Turntable
Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 28, 2009 | Pioneer CDJ-800MK2 Turntable
Can you help me
Sounds like you have a broken Sheet Switch. Basically, there is a circular piece of plastic which goes underneath the jog wheel, so that when you press the wheel, it activates the switch and stops the track / slows it down, and also puts the indicator on in the middle of the wheel. The part is readily available from Pioneer, and is a bit of a tricky fit, however is not the hardest thing to fit on the unit. However, it is the most fragile part of the player, and most common to fail if the unit has had physical trauma, eg dropping, spillage etc.
Feb 28, 2009 | Pioneer CDJ-800 Turntable
My pioneer cdj 800 simply wont work!!
Your traverse assembly is damaged, and will need to be replaced. Although self-repair is not recommended, you can buy the part and bring it with you to a service center for replacement.
Pioneer CDJ800 Part - CD Reader for CDJ800MK1
Pioneer CDJ800MK2 Part - CD Reader for CDJ800MK2
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 02, 2009 | Pioneer CDJ-800 Turntable
LCD Display!!!!!!!!
More than likely the ribbon cable is bad - unless there is damage to the LCD PC Board. Any knowledgeable repair shop should be able to replace this very easily.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Aug 04, 2008 | Pioneer CDJ-800 Turntable
My LCD Display
Well, one of 2 things may have gone bad...
1) Ribbon Cable
2) LCD PC Board
The first is easily fixed. The second, is not. As for service centers, I suggest you contact Pioneer - www.pioneerelectronics.com
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
No sound from CDJ-800 MK2
Are you getting error messages? Running in thru LINE? Is not on mute? The possiblity of both not playing would lead to process of elimination.
Keep me posted.
Oct 19, 2007 | Pioneer CDJ-800 Turntable
Pioneer CDJ-800 Turntable Logo
135 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
