Question about Panasonic DP-C264 Copier
Error code 717 scanner issues - Panasonic DP-C264 Copier
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
2007 chevy colorada code p0700 and p0717
input speed sensor for transmission is faulty which will throw the 717 code and when it does it will also tell "root" TCM (transaxle control module) to include the 700 code.
700 happens when it detects an issue with the TCM.
717 happens when the sensor is bad.
- Faulty Transmission Speed Sensor
- Transmission Speed Sensor harness is open or shorted
- Transmission Speed Sensor circuit poor electrical connection
Read more: http://engine-codes.com/p0717.html#ixzz37DlgiCBK
Mar 02, 2014 | Chevrolet Cars & Trucks
Dell error code 2000-0145
Bassam,
The error code 2000-0145 represents a failed hard drive and will need to be replaced. If you are still within your warranty period and are in the US you can email me at my email address below with your name, address, system service tag, email address and a brief description of the issue. If you are not within the warranty period you can call the dell spare parts department in the US the number is 1-877-717-3355.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email-jesse_leonard@dell.com
Sep 16, 2013 | Dell Computers & Internet
Error code msg2000-0141
hey luis,
This error means the hard drive has died and will need to be replaced. You can call Dell Spare Parts Department at 1-877-717-3355.
Thank You,
Dell-Jesse L
Jul 25, 2013 | Dell Inspiron 1420 Notebook
I got a P O 717 code what is it ???
P0717: Input/Turbine Speed Sensor Circuit No Signal.
This code shows because the computer isn't getting any signal from the sensor. Either the sensor is dead or there's a circuit issue (bad wiring, etc).
The Input/Turbine Speed Sensor is the sensor the computer uses to to monitor the the efficiency of the transmission. The computer reads the speed from the input shaft and compares it to the speed of the output shaft. If the speed is off it attempts to correct it by boosting the fluid pressure to compensate. When that fails it trips the P0717 error code. In most cases either the sensor is dead or there's a problem in the wiring harness.
There are issue of intermittent connection trouble with this circuit. That would cause the on off problem.
Hope this helps.
Nov 11, 2009 | 2003 Buick LeSabre
Umax Astra 6700 download driver error code 129
here is your code mines
101: EXPOSURE LAMP PROBLEM
120:SCANNER HOME PROBLEM
121:SCANNER HOME
124:SCANNER MOTOR PROBLEM
125:SCANNER MOTOR PROBLEM
126:SCANNER MOTOR PROBLEM
127:SCANNER MOTOR PROBLEM
129:SCANNER MOTOR PROBLEM
130:SICU / SBU PROBLEMS
300:CHARGE CORONA PROBLEMS
301:CHARGE CORONA PROBLEM
303:CHARGE GRID PROBLEM
304:CHARGE GRID PROBLEM
305:CHARGER UNIT WIRE CLEANER PROBLEM
306:CHARGER UNIT WIRE CLEANER PROBLEM
310-316:DRUM POTENTIAL SENSOR ERROR ISSUES
321:LASER UNIT WRITE PROBLEM
322:LASER UNIT 1 SYNCH. PROBLEM
323:LASER UNIT DRIVE PROBLEM
335-338:POLYGON MOTOR PROBLEMS
340-342:TONER DENSITY SENSOR ERROR ISSUES
345:DEVELOPER BIAS PROBLEM
350-355:IMAGE DENSITY SENSOR PROBLEMS
360:HARD DISK 1 PROBLEM
361:HARD DISK 2 PROBLEM
362:HARD DISK 1 PROBLEM
363:HARD DISK 2 PROBLEM
364:HARD DISK 1 PROBLEM
365:HARD DISK 2 PROBLEM
366:HARD DISK 1 PROBLEM
367:HARD DISK 2 PROBLEM
370-375:IMAGE COMPRESSION ERROR
376-377: SICU,IMAGE COMPRESSION ERROR
380-383:IMAGE DATA TRANSFER PROBLEM(SICU, SBU,PRINT CONTROLLER
Jul 01, 2008 | Umax Astra 6700 Flatbed Scanner
Panasonic DP-C264 Copier Logo
266 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
