Question about Champion 2.4 HP Gasoline Generator
I have a 2.4kva generator, but some few days back it produces white smoke from the exhaust on start up which stops after 5 minutes. I don't know the cause of the problem and how to resolve it.
  • 122 Answers
White smoke means you burn oil.
You need to have it fixed, the springs need replaced. Most likely it run too hot. If the cylinder is scratched then repair is more expesive than replacement,
good luck
rene
Posted on May 27, 2011
White smoke out of exhaust
Regarding 2001 audi a6 quattro 2.7t....i was driving to work the car was fine then white smoke starting coming from under the hood and tail pipe. i stopped veilce and alot of oil was dripping from front of car. I towed it home and i looked under the hood and there was oil from valve cover gasket. i let the car sit for a few days, had it running again for a good hour and no white smoke was coming out. I removed the valve cover and gaskets are all bad. i want to know can the valve cover gasket leak cause the white smoke to come from exhaust pipe?
Jan 11, 2014 | Cars & Trucks
09 yamaha r6-Steam or white smoke on start up lasts for about 3-5 minutes
Hi, 123gevans your instrument gauges and lights can alert you to most electrical and engine issues they can not warn you about failed engine gaskets or seals so your engine has to resort to old fashion alert methods of colored "SMOKE SIGNALS" here is a breakdown of their meaning:
1. COLORLESS OR SLIGHTLY BLUE SMOKE on start-up means your air/fuel mixture is at the right composition and everything is well burnt in your combustion chamber.
2. BLUE SMOKE on start-up is usually caused by failed valve seals dripping oil into the combustion chamber when the engine is not running.
3. YELLOW OR BROWNISH SMOKE at start-up means your air/fuel mixture is too lean. Too lean means that there is low fuel but high air mixture in your combustion chamber.
4. WHITE SMOKE on start-up may be caused by a blown head gasket allowing coolant to enter the combustion chamber and may start dripping out of the exhaust pipes or mufflers. Smoke while riding is usually caused by worn out or damaged valves, seals, guides, pistons, rings, or cylinder walls.
5. BLACK SMOKE on start-up is usually caused by too much fuel in the combustion chamber this can be due to air/fuel mixture adjustment too rich, accelerator pump improperly adjusted, faulty choke/enrichner or not in the off position, air filter dirty and clogged, faulty carburetor float needle and seat, pilot jet too large, fuel injectors leaking, smoke while riding is usually caused by the main jet being too large or a damaged carburetor.
It should be noted that aggressive or abnormal throttle operation will cause these conditions to manifest themselves exponentially.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
07 08 white smoke in the exhaust
smoke from exhaust after oil change
Yamaha YZF R6 Service Manual
OEM parts for Yamaha
Yamaha YZF R6 Owner Manual
May 25, 2017 | 2009 Yamaha yZFR6
My mtd yard machine (leaf blower) started billowing white smoke. I shut it off and now it won't start again.
First check the oil level. If its overfilled correct it. Then remove the spark plug and turn the engine over. Replace the spark plug.
Start the engine. Use a prime ( squirt carb cleaner into carb) if you need to. It may start smoking again. Thats OK as long as you know there is oil in it and you dont hear any strange noises. Let the unit run for about 5-10 minutes and see if the smoke clears up. Once it quits smoking stop it and check the oil.
Nov 11, 2012 | Garden
Excessive exhaust smoke on the first start of the day
Sounds like the valve guides are leaking oil into the cylinders, or there is a coolant leak somewhere. Usually white smoke is coolant but could be oil.
Are you adding either fluid often ?
Aug 01, 2012 | 2004 Hyundai Santa Fe
Troubleshooting for a 1998 park avenue
White smoke usually means water in the cylinders. I would say you have blown head gasket or intake manifold gasket. Could be something cracked or something I don't know about. Unless it is something I don't know about will not be simple or cheap to fix.
Jun 21, 2012 | 1998 Buick Park Avenue
White smoke pours out of exhaust on my SV730 Kohler engine when I start it. Then it stops and the engine runs good. I think it is a bad valve guide or a valve isn't seated right and oil is running
If you filled it up with oil yourself, then you might have put in too much, Ive done that a few times myself,, try ansd drain a little, about two to three ounces, then try to start it, make sure to do this when its cold.
May 07, 2012 | Kohler 25HP Replacement Engine SV730-3001
When i start the engine i have like a white smoke behind me is just huge.i drive a toyota land cruiser 2006 manual gearbox.i don t know what is the problem?is happen in every morning and 4 max 10 sec all...
smoke indicates a weak engine, if it is only at start or beginning few minutes of driving then hopefully it is rings only which is weakened and needs replacement, as per your note it seems only at start and the vibration is it only at cold start and what about if after running a more then 5 miles even you stop the car and start in few second does it still vibrate or no, please let me know
Sep 19, 2011 | 2006 Toyota Land Cruiser
White smoke from Exhaust
hardly likely the exhaust job would cause that, but yes it sounds like you got a blown head gasket. badl lock stricks hmm! also preasure test cylinder head for leaks
Jul 22, 2009 | 2005 Renault R5
Morning White Smoke At Start-up (2003 4cyl Camry)
This problem is common but often over looked. Moisture vapor is a grayish white color but it dissipates very quickly. Smoke that is grayish white is caused specifically from burning oil. The problem you have is a small seal called a valve seal. It is very common in cars that sit a fair amount of the time. The seal gradually starts to leak and allow tiny drops of oil to drip into the combustion chamber. When the engine is started then it smokes until the oil is burned. Due to the amount of time that your car smokes after start tells me that the leak is very small. That is why there is no oil consumption. This is not going to harm the car unless it becomes very bad and then the only thing that would happen is more smoke and fouled plugs. You can start using a heavier weight oil and add an oil treatment to the oil when you have it changed. This may evin stop it all together. Hope this answered your question. Please rate this solution if you think it has helped. Good luck and thanks cj2176.
Jul 15, 2009 | 2003 Toyota Camry
Large amount of white smoke on first start of the day
Have you had the injector recall check carried out? There is a problem with these injectors and this produces the symptoms you are describing. I suggest that you contact Isuzu direct for help. They have been very helpful in the case of my trooper
Nov 12, 2008 | 1999 Isuzu Trooper
Champion 2.4 HP Gasoline Generator Logo
261 people viewed this question
Top Champion Electrical Supplies Experts
Steve
Gene Haynes
Are you a Champion Electrical Supply Expert? Answer questions, earn points and help others
