Question about Electrolux EWED65H Dryer
Why is my electrolux condenser drier overheating. have cleaned filters. will work for one load but needs a rest and cool down before the next load. If not ready and you turn it on too soon it appears to start then stops
  • 32 Answers
Have you checked the dryer vent tube that goes to the outside? It may have a clog in it (lint build-up). If it has a flex tube and it's bunched up behind the dryer it will clog and/or restrict the air flow causing heat build-up.
Posted on May 27, 2011
Fridge not cooling. Shifted house 2 days back. Before it was alright.
Your fridge systems under chocked. Whenever transport refrigerant unit you should not lift down wards on suction side which will lead compressor oil thr' discharge line. When compressor on, it will pump the oil.It get chocked on filter drier resulting to no cool.
Solution. Remove all gas, and also filter drier. Now flush out condenser side separate and evaporator side separately.Then replace filter drier and vacuum the system.Now do gas charging. Thanks. helpful?
Jan 30, 2011 | LG LRFD25850 French Door Refrigerator
Hi, the unit shuts down sometimes and the green light blinks five times. it usually starts up after ten to fifteen mins.
It's abnormal condition of out door unit or overcharged gas unit. If the unit is new or recently recharged, there is chances for over charged. Otherwise, it's due to non condensable gas. You have to remove all gas and replace filter drier, flush out system and then charge gas again.
Before doing this, please clean condenser coil and also check fan speed is o.k. Because this is also one of the reason for getting compressor overheated
Jan 14, 2011 | Heating & Cooling
REPLACED AIR COMPRESSOR AND NOW SOMETIMES AIR IS COLD AND MOST OF THE TIME IT IS JUST COOL.
In replaceing the a/c compressor you need to replace the a/c filter/drier. The drier is located on the right side of engine compartment,next to the radiator and condenser. The drier absorbes moisture out of the a/c system. If lines were open the drier is like a sponge and will **** up all the moisture from outside. Be sure when replaceing the drier that you pull a vacuum on the system to remove air and moisture from system before you refill with freon. By doing this it will correct your problem. Hope this will help you.
May 16, 2010 | 2005 Dodge Grand Caravan
I have 1.5 ton window air conditioner of Electrolux, same is not cooling, compressor is on and there is air blowing but no cooling, filters are clean. please advise solution
You may need to take the cover off and with it unplugged take a hose and clean the condensing coil ( the outside coil) they can get very dirty. Make sure it dries before plugging it in.
Apr 18, 2010 | Heating & Cooling
Hotpoint WD440 creases clothes badly & takes ages to dry
This sounds like excess steam in the drum. Check that the drain filter is clean as washer driers rely on cold water being taken in to cool the condenser tank during the drying cycle. If the filter is clear, the tank may be blocked with fluff. You have to open the machine a look for a big plastic tank, usually down the right hand side.
Dec 11, 2009 | Hotpoint Ariston WD440G Front Load...
Where do I cut the condenser coil to remove it
Anywhere between the compressor and the coil.
REMEMBER to leave yourself plenty of line on the compressor side.
It also may have a Filter Drier in the line, be sure to replace it also.
Depending on why your replacing the coil you may need to clean the rest of the system out.
Hope This Helped;
JSTACH
Sep 06, 2009 | Heating & Cooling
Asko T741 - Thermostat keeps cutting out
Ken from Mecheltec suggests removing condensate sump and pump assembly and servicing it. Clear condensate hoses from lint and debris then carefully reinstall assembly. You should be ok.
Oct 06, 2008 | Asko T741 Dryers
E50
It may mean that the washer is overheated.
Possibilities:
Too large of a load
Too much Detergent
Plugged drainage system
Or dirty filters at the washer end of the water hoses (easy to clean)
Check these things out please, and turn your machine off for at least an hour( to cool down) and then try again and see if the message comes back on.
Aug 22, 2008 | Electrolux Washing Machines
Electrolux EWED65H Dryer Logo
189 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
