Question about Proview Pl513b (Black) 15 in. Flat Panel LCD Monitor
The monitor flashes when you first turn on computer then it goes black ???? model pl513b ser# F7AZ51087131U
  • Proview Master
  • 2,098 Answers
This kind of symptoms indicated that your monitor has a busted bulb already. When you first turn on the unit, it will power up but will automatically shuts off the inverter board once there's a busted bulb to avoid overload to this board. The unit must take apart and check the bulb. It can't be tested by the multimeter but has a physical indication of fault like blackened end.
Another caused is the faulty inverter board itself. Most common faulty parts are the high voltage transformers, driver transistor, open fusible resistor, leaky/dried electrolytic capacitor. You must know how to test this parts if you are going to DIY.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified technician to isolate the problem.
Also check if the unit is still under warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover, it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 27, 2011
My 1905FP Dell monitor powers up and the screen is normal for about 3 - 5 seconds and then goes black. Turn it off and then on and the screen goes thru the same routine as many times as you want to turn...
si al encenderlo dura unos cuantos segundos encendido y luego se apaga
revisa los condensadores en la fuente del alto voltage casi siempre se inchan y no dan el voltage correcto tambien podria ser una de las lamparas se quema el cable negativo de la lampara que es el mas delgado donde solda con ella.
Aug 16, 2011 | Dell UltraSharp 1905FP LCD Monitor
I turn on my computer and the monitor flashes on then goes black. If I turn the power to it off and then back on it will flash a pictues and then go black again.
You need to try another monitor to see if the problem is with the monitor itself or the video card in the computer. If the monitor is bad I suggest you just buy a new or used one. It cost more to repair them than to buy another one.
Aug 02, 2009 | Computers & Internet
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
L1932TQ monitor flashes on, then blacks out
I would try connecting it to another computer or Laptop if you can to see if the problem is the same. You might also try disconnecting it from you computer and turning it on, it should “banner”(show a logo and or a no signal message). If it behaves the same way just a quick flash…. Sounds like its toast.
Jun 20, 2009 | LG L1932TQ LCD Monitor
Monitor flashes on then goes black.
I think you have the display shut off. the button on the bottom left will shut screen off. It will come on for a few seconds if you touch the screen, but will shut off again. just push the display button again and it should stay on.
Apr 02, 2009 | ViewSonic OptiQuest Monitor
Monitor flashes on when I turn computer on, then screen black
Your monitor power supply or inverter board have gone bad. Its not your computer video card
Apr 17, 2008 | Westinghouse LCM-19v1 Monitor
"Desact.monitor"
my monitor says desact monitor and I dont know what it means.
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Proview Pl513b (Black) 15 in. Flat Panel LCD Monitor Logo
35 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
