Question about Garden
My worx trimmer/edger battery does not charge. It continues to flash red on the charger. What do I do?
  • 8,404 Answers
The battery behavior you describe is typical of a battery that has done its job and now needs to be replaced. Find a replacement at your lawn and garden shop or at a FixYa.com advertiser.
Posted on May 27, 2011
  • A Miller Jun 05, 2011
    Thank you for the positive evaluation of 4 thumbs up
WORX BATTERY CHARGER. when i PUT THE CHARGER ON THE GREEN LIGHT COMES ON.
Mike, The red LED is suppose to be on when you insert battery, the LED will go green when battery is charged. Look in your manual, Pg. 11 charging instructions. Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://pdfstream.manualsonline.com/7/72bd8a7a-cf98-43d4-92b7-a15bc78eb6bb.pdf
Battery Driven String Trimmers
How to Check Li ion Battery
Jul 15, 2016 | Worx Gt Wg151.5 18v Cordless Electric...
WORX 24V charger won't charge
I'm having the same problem. Worked great then didn't last as long. Now I'm stuck with this piece of crap useless piece of equipment. I'm back to spending too much time trimming with scissors since I can't afford a new battery non the less a new trimmer. Thanks a lot WORX! It doesn't Work! I'll never buy another of their product!
Aug 26, 2012 | Worx 24-volt Cordless Electric Lithium-ion...
BATTERY IS COMPLETELY RUN DOWN, PLUG INTO CHARGER BUT LIGHT STAYS GREEN NEVER TURNS RED & DOES NOT CHARGE BATTERY???? ONLY 1 YR OLD. WHATZ THE FIXXXXX?
I had a similar issue with my Worx battery.
Check to see if you are eligible to receive a free battery replacement:
www.worxbattery.com
Good Luck!
Aug 03, 2011 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
The battery will only blink on red. It won't charge.
Your battery is probably shot. The batteries for the Worx trimmers are terrible. They sell replacement batteries on ebay, but if you can afford it i highly recommend buying a quality trimmer from your local hardware store, either plug in or gas.
Jun 06, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Battery charger on a Worx Gt Trimmer Battery is blinking red what is the problem
Flashing red light indicates battery is bad. Flashing green light indicates charger is bad.
Feb 21, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Charger light blinks red never goes to solid red which is charging mood Had a friend charge the battery it does charge problem is with the charger not the battery
Worx has had issues with their chargers and their batteries. They don't seem to last as long as the machine does. A simple voltmeter test of the charger and any battery will tell the story. The charger's output rating should be printed on it and the battery also. Touch test leads from voltmeter to the two and check.
Oct 31, 2010 | Worx GT WG150 10 in. 18 Volt Cordless...
Why is the red light blinking on the charger??
Either the battery charger or the battery itself is bad. The charger can be easily tested with a volt meter to see if it is producing the correct voltage to charge the battery. The batttery voltage can also be checked the same way. Some other users have had this same issue.
Oct 13, 2010 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
