Question about HP Photosmart 2575 All-In-One InkJet Printer
It is not possible to tick the 'Minimize margins' option. The checkbox is not grayed, but its behavior is as such... I have a PhotoSmart 2575 All-In-One with Windows 7 system. Hope you can help, because my page numbers are being printed badly... Kind regards, Jan Boersma
SOURCE: Will not feed paper. HP Photosmart 2575
This is a very common problem. Apparently HP changed the roller because of this fault.
I've tried cleaning, I've tried making the roller rough. I tried to get HP to send me a new roller but they didn't even reply.
HP are a rubbish company who don't care at all about customers (and their printer software (bloatware) is even more rubbish).
BUT - the solution I found:
The spring that holds the roller down onto the paper is too weak. I bent the end of a straightened out paper clip into a small hook then made another hook-like bend a bit further up (but kept the rest of the clip to use like a handle). the length between the two hook parts is just under 1/2 inch. Don't cut it yet - buy you will need to when it's in place.
ad74983.jpg Hold the handle end (the bit at the bottom of this sketch) so you can fiddle about in the small space and don't loose the spring altogether.
Find the spring that fixes onto the roller gadget, it hooks onto the printer body. Hook the spring off the hole in the printer body, and then catch the second (double) hook of the paperclip onto the small printed circuit board just by the roller (most of the board is empty - so hook it to the left end of the board).
Then, when it's all in place cut the rest of the paperclip off.
You can see the double hook part once I'd cut off the "handle" piece in the photo:
0e1481b.jpg and here you can see where the spring used to go, and where it fixes with the clip thingy I made.
Of course this is what I did (when I was about to throw the printer away so it was a last chance survival idea), if you loose the spring, stick it onto something that goes sparky-sparky or otherwise kill the machine or yourself I can't take responsibility!
Posted on Feb 22, 2008
  • 4 Answers
SOURCE: I have a HP 2575 photosmart 2575 All in one series
Are able to print? If yes, please tryy to scan by using Ms Paint. If you can scan from Ms Paint please reinstall the scanning driver software. You can download the full feature drivers and softwares from www.hp.com.
Posted on May 18, 2009
nalin_elliot
  • 224 Answers
SOURCE: hp 2575 wont print documents. 7 pages in queue
Ok now before hand I am warning you,this may just be a printer problem and so rate me as per the solution and not for the answer,cauz the printer ur using is a machine and Im a Human,two diffrent things altogether.
Copy and paste the link in the address bar of your browser and follow the document,its the same for all operating systems
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01893667&cc=us&lc=en&dlc=en&product=441240
if this doesn't work call up hp tech support at 1800-474-6836 ,cauz there may be something wrong with your printer hardware and see if you can get a hardware upgrade for a 30-40% discount with an extended service plan at a 60-70% discount
Posted on Dec 21, 2009
SOURCE: PHOTOSMART 2575 DISPLAYS "MEMORY CARD
Insert a memory card (in my case a SD CARD) and SLOWLY extract card until error message clears and normal screen images appear.I had to do this several times but it worked for me but cannot guarantee it will for everybody.GOOD LUCK.
Posted on Jun 22, 2011
SOURCE: Gray background only on odd number pages
print gets background
Posted on Sep 21, 2011
Please can you say me how to set correct margin size for Printer Zebra Xiiii plus
choose the "View > View Options" Menu with the BT document open and now enable the "Show Unprintable Region" checkbox. Will you now see the unprintable width margins covering part of the left margin of your label? If yes, then this means that due to the unprintable width of the printer you cannot print on this are (this the related to the printers print head tolerance).
With regards to the not being able to print on the bottom side, this could be a page setup issue. Please attach your BT document to this forum topic by using the "More Reply Options" button.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Techsupport Printer
Feb 26, 2014 | Zebra Xi Series 140Xi4 - label printer -...
How to delete AERO PEEK from taskbar option grayed
Click on Start, then type in Visual effects, click on Adjust appearance and performance of Windows and then uncheck the Aero peek checkbox.
Feb 14, 2013 | Microsoft Windows 7 Home Premium 64 Bit...
Can not enable java script
Hi maybe you need to go to java website and download it, if you havent already.
if you have, check which browser you are using and how to enable it.
Internet Explorer (6.0)
1. Select 'Tools' from the top menu
2. Choose 'Internet Options'
3. Click on the 'Security' tab
4. Click on 'Custom Level'
5. Scroll down until you see section labled 'Scripting'
6. Under 'Active Scripting', select 'Enable' and click OK
Netscape Navigator (4.8)
1. Select 'Edit' from the top menu
2. Choose 'Preferences'
3. Choose 'Advanced'
4. Choose 'Scripts & Plugins'
5. Select the 'Enable JavaScript' checkbox and click OK
Mozilla Firefox (1.0)
2. Choose 'Options'
3. Choose 'Web Features' from the left navigation
4. Select the checkbox next to 'Enable JavaScript' and click OK
Mozilla Firefox (1.5)
2. Choose 'Options'
3. Choose 'Content' from the top navigation
Apple Safari (1.0)
1. Select 'Safari' from the top menu
3. Choose 'Security'
4. Select the checkbox next to 'Enable JavaScript'Source(s):https://www.google.com/adsense/support/b...
  • 3 years ago
Jun 13, 2012 | HP p2-1110 Amd 3GB 500GB
Dell inspiron right hand margin cut off
It is more likely that the window got moved to a point where the x, restore, and minimize buttons don't show than it is that a portion of the whole desktop is cut off. Right-click on the icon that represents this window in the task bar, and click maximize. If that's not an option, choose move, and then use the down and or left arrow keys to reposition the window where you can see the minimize, restore, and x buttons, and then hit enter on the keyboard.
Mar 02, 2012 | Computers & Internet
Motorola MC3190 can not get ip address from dhcp on wep wi-fi
To configure the terminal TSD on Windows Windows do the following:
1. at the bottom of the panel find the network icon (it can be crossed with a red cross or be a red exclamation mark)
2. click on it with the stylus and select Options Options
3. In the window, select the menu and set the following values:
OP Mode Filtering - leaving only a tick AP Networks, and remove Ad-Hoc Networks
Regulatory - select the country (you can USA) and remove the checkbox Enable 802.11d
Band Selection - I chose only 2.4 GHz Band, 5 GHz mark removed
System Options - all ticks left (Profile Roaming, Enable IPv4 Mgmt and Auto Time Config)
Auto PAC Settings - AllowProvision ing AllowRefreshin g and both set as No
IPv6 - Enable IPv6 checkbox removed
Change Password - leave blank
Export - click the button Export Options, a window to save, note that saving should be in the folder \ Application and contain letters and symbols with the extension. Reg
After that, push the Save button and
Feb 23, 2012 | Zebra Symbol MC3190G Handheld Mobile...
MY SPEAKERS PLAY NO SOUND
Yes, you might have turned off the sound in your PC. For Windows XP this is the procedure to turn it ON.
Go to 'Start'--->Settings---->Control Panel----->Sounds and Audio Devices. Here you will get a window where you will find all the sound related options. Here you will be able to modify the volume levels and check whether the mute checkbox is ticked, if yes then uncheck the box and click on OK.Your problem should be resolved.
Dec 05, 2011 | Computers & Internet
I am printing on 8 1/2 by 14 paper landscape. The document is not covering the entire paper.
Do you want the document to fill the page from corner to corner? You won't be able to do that due to the margin settings. The printer needs to be able to pull the page through the machine without touching the ink, so it can't print on every available inch of the page. You can minimize the margins as much as your printer will allow under the Page Settings menu, but it will always shrink the document to fit within the margins on the page.
Hope this helps!
Aug 25, 2011 | Epson Stylus 1400 InkJet Photo Printer
I want to print a brochure in word or psd and how I can print edge to edge, borderless.
Within MS Word, minimize the "left-margin" and "right-margin" settings/
Use "printer setup" to minimize the margins.
Oct 31, 2009 | Microsoft Office Word 2007 Full Version...
Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Jul 19, 2009 | HP Office Equipment & Supplies
MY HP PHOTOSMART DOES NOT GIVE OPTION TO SCAN TO PC
First make sure that the software is sucessfully installed in you computer and then try the steps metioned bellow.
Go To My computer>C:\Drive\windows>system32
Copy hpzipm12
minimize this window
Right click on Start button on the computer>Explore>Programs>Startup>edit>paste
minimize this window.
Go back to My computer>C:\Drive\windows>system32
Copy hpzinw12
Now you will see two new files in Startup
Now go to My Computer>C:\Drive\Program Files>HP>Digital Imaging>bin>
Copy hpqtra08
close this window
Restart the computer
Open Hp Solution Center> Settings>Scan settings and preferences> Scan to button>
check destination list> if available applications are not in the destination list then add them in the front panel destination
Tried to scan.
Dec 21, 2008 | HP Photosmart C5280 Printer
HP Photosmart 2575 All-In-One InkJet Printer Logo
49 people viewed this question
Seeker5211
Seeker5211
