Question about Coleman Grilling
I have a cast iron portable twin gas ring burner that is not functioning very well. I aim looking for instruction on how to diagnose problem solve and then put right this challenge. Please help
    Brigadier General:
  • 4,736 Answers
Without knowing the brand of grill you have and the model number, it's impossible to provide you with an Owners Manual. However, most burner problems are related to a need for cleaning and/or the gas regulator may be partially locked up. In which case, turning the tank valve OFF, disconnecting the hose from the tank and waiting 5 minutes before reconnecting, will generally solve the problem. But, only if you turn the tank valve ON VERY, VERY Slowly (Slow motion, slow).
If after you have completed the above and you're still having problems and need an Owner's Manual, please furnish the Brand & Model Number. Thanks.....
Posted on May 27, 2011
Adjust flame
Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
Wfg361lvd
If you have a standing pilot (always lit), the adjustment screw is normally located behind the burner control knobs.
Dec 22, 2012 | Whirlpool WFG361LVD - 5.0 Cu Ft,...
Which is best porcelain or cast iron grates? I am
Cast Iron by far, ceramic grates chip and are VERY difficult to clean!!!
Nov 14, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Looking for the rubber feet that fit on the
You can get these feet at www.repairclinic.com
May 11, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Cannot ignite central gas ring on smeg 5-ring kitchen hob
I had a similar problem on a different gas range but your problem seems the same as mine was.
I examined the underside of the burner and saw a little 'flash' left from the casting process and I filed it off. This made the problem worse; it wouldn't light at all anymore.
I tried the opposite, blocking off the burner channel from the gas feed pipe to the spark gap; problem solved. It hasn't had a hiccough since.
I can only imagine that the flow of gas toward the spark gap was so strong, the gas was blowing itself out.
Not knowing exactly how the underside of your burner looks or how the gas is partially diverted to the spark gap but I drilled a small hole in the casting, inserted a length of copper wire (the gauge used in house wiring), then 'tuned' the flow by clipping part of the wire off and trying it. It might have taken all of 15 minutes to correct the annoying problem.
Nov 24, 2008 | Smeg 23 in. SE64 Gas Cooktop
Grilling Logo
74 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
paulcarew
Raymond Ramirez
Raymond Ramirez
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
